Baru Chip Xx Power Toyota Fortunner VNT Diesel Turbo & Petrol Engine
  • Short URL:  http://modifika.si/564564
    7 Hrs 14 Mins 16 Secs
    Increase in power by *20 - 50 in BHP (Brake horse power) Diesel Engine
    *15 - 30 PS Petrol Engine
    Increase in torque by *60 - 85 Torque NM Diesel Engine
    *30 - 45 Torque NM petrol engine
    Harder acceleration, spraying fuel optimization and combustion Efficiency
    Eliminating flat spot and lag so called "turbo Hole", the car accelerates well in the lower RPM range
    Improve driving dynamics, higher Top speed of the car
    Smooth and faster gear shifting in Automatic transmission
    Easier acceleration throughout the Rev range, even in the higher gears.
    Plug & Play connectors the mounting is easy and takes only a few minutes. ( Diesel engine)
    After dismounting factory settings are restored
    Correction the hole of power in Low rpm range, better than a remap.
    Chip is not visible to the on board computer and service computer
    Saving Fuel in Balance driving. Does not excessive smoke.
    Fully compatible with all types of manual & automatic gearbox incld. CVT Xtronic
    it has a motor protection function ( prevents overheating of the engine under heavy load )
    Note: * The increase in power depend on the capacity and the initial power of the engine
    IDR 2.950.000 ( DIESEL ENGINE )
    Pls Call for details. 08161913116
    1 Hr 16 Mins 6 Secs
    lokasi mana bos?
    Quote Originally Posted by tawisohandsome View Post
    lokasi mana bos?
    lokasi di Jl.KH Mas Mansyur Pls contact 08161913116 dng perjanjian
    2 Days 1 Hr 50 Mins 25 Secs
    Benar nih utk fortuner bensin bisa? Plug and playkan Pm harganya?
  1. BEKAS Pre Order Toyota 1KD - FTV Diesel Turbo Engine
    By Powerboost in forum Engine & Parts
    Last Post: 14th November 2014, 15:57
  2. BARU Chip Digital Xx Power Modul Toyota Innova, Avanza, Rush, Yaris
    By Wiegeht in forum ECU, Piggyback, Electronic Parts
    Last Post: 2nd October 2014, 09:23
  3. WTS : Mesin Toyota Fortuner 3000cc Diesel Turbo....
    Last Post: 1st July 2013, 10:38
  4. FS : Mesin TOYOTA DIESEL TURBO 12HT (6 Cylinder) 12 VOLT
    By Gramlights in forum Jual Beli Mesin Lainnya
    Last Post: 14th June 2009, 19:07
