Bekas WTS Power High end LUXMAN CM-2100 mulussss dan ori....
Results 1 to 10 of 29
  • Short URL:  http://modifika.si/564512
    1 Mth 2 Wks 16 Hrs 28 Mins 21 Secs
    Dijual Power High End Luxman CM-2100
    Feel the music. Power amplifier to listen to sense. Brand New next.
    CM Series 3 models, starting.
    Luxman that luxury in the home audio scene meticulous sound, always keep at the forefront.
    Taking advantage of the technology and history of making sense amplifier more than 75 years, we have cultivated So I challenged the new field of car audio. Fully utilizing the space in the passenger compartment of the harsh sound quality of home audio overwhelming. Buyer's choice of CM winning magazine series, which was announced in 1999 as a result thereof, (as of 2004) and No.1 for five consecutive years. However, do not hang on Luxman. Completely recast in detail the previous CM series, I was introduced plenty of state-of-the-art technology that goes into home audio. Next Age of CM series, the three models. Its form reminiscent of a flight recorder of the aircraft, its scale, its sound, creating a different dimension to the passenger compartment more than anything else.
    CM-2100 di Singapore pernah diadu head to head dengan power mobil ternama "tidak etis menyebutnya" seharga 70jt dan judge di singapore memilih Luxman CM-2100 sebagai "the Winner"
    Karakter suaranya sangat natural,wide,grand,bisa mellow namun dynamicnya juga bagus serta powerfull..
    Spek :
    For sale A Limited Edition Crafted by Lux Corporation , Luxman CM 2100 dual mono 2x100 @ 4 ohm ( very under rated ). one of the most natural sounding car amplifier on planet !!!
    Luxman CM-2100
    2 x 100W @ 4 ohms (0.005% THD)
    Weight: 21.6 lb (9.8 kg)
    Specification
    # Continual effective ability: 100Wx2ch (4 ohms) 400Wx1ch (4 ohms and MONO) / 1600Wx1ch (1 ohms and MONO, instant maximum)
    # Input sensitivity impedance: NORMAL (LOW) 0.5V/20K ohms (HIGH) 2.0V/3.1K ohms DIRECT0.5V/25K ohms
    # signal-noise ratio (rated output): Above 110dB (IHF-A revision and input short circuit and DIRECT)
    # All the harmonic distortion factors: 0.005% or less (4 ohms, 1kHz and DIRECT) 0.008 or less (4 ohms, 20 - 20.0000Hz DIRECT)
    # Frequency characteristic: 20 - 20,000Hz (+0, −0.2dB and DIRECT) / 5 - 100,000Hz (+0, 0.2dB and DIRECT)
    # Damping factor: 100 or more (4 ohms, 1kHz and DIRECT)
    # Battery voltage: DC12V
    # Electric power consumption: 33.6W (2.8A, signal-less) / 354W (29.5A, 4 ohms and rated output)
    # Size: W480 x D302 x H76 mm
    1.Barang masih Original,mulus dan no service
    2.Mohon maaf saya tidak menjual barang Palsu dan barang KW juga tidak menjual barang yang rusak
    3.Lokasi barang di Jakarta selatan (Pakubuwono Area) Bisa test di tempat
    Untuk di luar kota bisa dikirim via JNE or MEX
    4.Untuk informasi Bisa call/whatsapp 0811880333 or pin bb 2AA35183
    5.Untuk posting lainnya silakan buka link ini :
    http://www.modifikasi.com/member.php/130849-Ferrlim
    6.Terima kasih Modcom
    maaf gak bisa upload foto,untuk foto by bbm atau whatsapp saja...thanks
    Hub 0811880333 and pin bb baru 2aa52a1c,thanks
    Happy sunday
    Sundul...........
    Power high end
    sundul...........
    Power high end,........
    Sundul.............
    Power ampli
    Luxman CM-2100
    Sinfoni Amplitude 120.4x (4x135Watt-Handmade Itali)
    Genesis five channel (5 channel-UK)
    Genesis Class A P300x (6 channel-UK)
    Orion Xtreme XTR 100 (USA)
    Zapco Competition Z600C2-SL
    Zapco Monoblock Ref 500.1 Class AB
    Power amper class A PA 60
    Audison Lrx1.1K (monoblok)
    RF DSM100 (2biji)
    Soundstream D200ii
    Steg qmos 120.2
    Steg Qmos Monoblok 240.1
    Steg K2.01 (2x105Watt)
    Power HarmanKardon TC300
    Crossfire monoblok cfa390M
    Crussfire BMF 125.2
    Orion HCCA 2100
    Orion 280GX Military spek (2x80Watt) USA
    Hifonics Vulcan 100watt
    Rockford Forgate 75
    Rockford Forgate 150
    Alpine 3540 Japan (2x40Watt)
    Alpine Juba 3501
    Alpine MRV-T500
    Rockford Forgate 75hd (2 x 37,5watt) USA
    Crossfire BMF 125.2 (2x125 Watt) USA
    PhoenixGold M50
    Precision Power 2150M (2x150Watt)
    presision power(ppi2360)
    Ram Signat 6ch pure class A
    Speaker dan sub woofer :
    Venture 2 way V92+V26
    Venture tweter V26
    Midbass Skaning Flexi Unit 6H
    Midbass DLS Ultimate Iridium
    Midbass dLs Nobellium
    midbass dynaudio MW160+tw+pasif
    Cresendo 2 way opus 5
    Midrange Audhible phisik 3"
    Mcintosh mss650 lengkap
    Mcintosh mss630 lengkap
    JL audio 6” coax
    Hertz coaxial 6" hcx165
    Sub woofer :
    Sub skanning Flexi unit FU 10c
    Sub High end Hertz Mille ML2500
    Sub RF 8" RFS-1408
    Pioneer TS-W12PRS
    Kicker Freeair F12c
    Kicker Freeair F8a
    JL audio 12w6 Gold series
    JL Audio 10W3v1
    Dynaudio 24w75xl
    Phass 10” Japan
    Head Unit,Procesor dan accesoris :
    Alpine PXA+Rux 800 New
    Helix C-DSP
    Phoenix gold ax406A
    EQ Audiocontrol EQL
    Crossover Audiocontrol 24XS
    Hi to Low Audiocontrol LC7
    Audiocontrol 3xs
    Audiocontrol DXS (Digital Crossover)
    Pioneer CD-UB100 (New) (USB conector)
    Proc Alpine PXA 700 (Korea)
    Alpine CDA 9855
    Alpine CDA-7949E
    Addzest drx-9255xl
    Alpine 5980
    Nakamichi MB-650
    Pioneer AVH-P7850dvd
    Pioneer Dex-P1
    Caps Lightning Audio USA 1F
    Caps Helix 500.000 uf Germany
    capasitor EFX 1 F
    Batcap 300
    Crossover Pasif 2way & 3way Custom by Ko EX
    1.Kondisi barang segel dan normal
    6.Terima kasih
  1. BEKAS WTS POWER HI END LUXMAN CM 2100- 2CHANNEL
    By ric_signature in forum Power Amplifier
    Last Post: 8th May 2014, 05:03
  2. Wts Power Hi end LUXMAN CM 2100
    Last Post: 21st October 2010, 22:50
  3. Replies: 14
    Last Post: 1st October 2010, 08:01
  4. FS : Hi End Luxman CM 2100 ( SOLD )
    By jeam in forum Power Amplifier
    Last Post: 13th March 2010, 19:00
  5. WTS : POWER HIGH END TRU TECH T03.4.150 .......soldddddd
    By guciboy in forum Power Amplifier
    Last Post: 22nd July 2009, 18:00
