Bekas Sparepart Mesin BMW M60 530i E34 / 730i E38 - 3000cc 8 cylinder
Results 1 to 10 of 14
  • Short URL:  http://modifika.si/564168
    Depan Kompie, Asbak dan Rokok
    1 Mth 1 Wk 2 Days 16 Hrs 40 Mins 5 Secs
    Mesin BMW M60 3000cc 8 cylinder + Modul2 dan lain2
    - BMW 530i E34 M60
    - BMW 730i E38 M60
    Bisa Beli Pretelan Part Mesin, GearBox Matic, Sensor/electrical Component, Modul2 dll :
    - Cylinder Head
    - Cover Cylinder Head
    - Cover Cylinder/intake Plastic
    - Intake Manifold
    - Throttle Housing Assy
    - Camshaft inlet / outlet
    - Hidrolic Valve Lifter paket per 16 pcs
    - Valve exhaust / intake
    - Ignition Coil
    - Injector Valve
    - Crankshaft Piston - Connection Rod
    - Starter Motor
    - Alternator
    - MAF Sensor / Air Flow
    - Idle Up / ICV
    - Engine Wiring Harness
    - Sensor2
    - Air Pump Vacuum Control / Valve
    - Emission Control - Air Pump
    - Power Steering Pump
    - Vibration Dumper
    - Radiator Matic
    - Cooling System water hoses
    - Viscous Fan Coupling + Fan Blade
    - ECU / DME
    - GearBox Matic
    - Modul Matic
    - Compressor AC
    - Kondenser AC
    - Aux Fan
    - ABS Hydrolic Unit
    - dll....dll...dll
    Harga : call
    Hub.
    Telp / SMS / Whatsapp
    0882 100 80100
    0813 818 22210
    Pin BB : by request
    Lokasi Depok
    Tersedia Juga Sparepart / Aksesoris BMW tipe lainnya
    Penampakan :
    sparepart & Accessories BMW lainnya:
    http://www.modifikasi.com/search.php...vBForum_Thread
    Visit our website at
    http://www.sparepart-bmw.com
  1. BEKAS jual mesin BMW M60 V8
    By nunu182 in forum Engine & Parts
    Last Post: 20th March 2015, 09:06
  2. Sunroof BMW 520i/530i E34
    By batbat in forum Bodykits & Body Parts
    Last Post: 28th January 2014, 11:25
  3. Jual Mesin BMW M60 3000cc V8 +Girbox manual Komplit
    By s515i in forum Engine & Parts
    Last Post: 10th June 2013, 20:32
  4. WTS sparepart mesin BMW M52B28 ex singapore
    By bedjo1970 in forum Jual Beli Mesin Lainnya
    Last Post: 3rd July 2012, 10:16
  5. WTB Block Mesin BMW 530i M60 V8 th 94
    By mija in forum Jual Beli Mesin Lainnya
    Last Post: 7th August 2009, 18:41
