SX PERFORMANCE ADVANCED FUEL SYSTEM - SOLE DISTRIBUTOR
Results 1 to 10 of 15
  • Short URL:  http://modifika.si/55375
    Jln. Pluit Barat 3A No.1-3, Jakarta Utara
    1 Wk 3 Days 21 Hrs 27 Mins 1 Sec
    WE ARE PROUD TO BE A SOLE DISTRIBUTOR OF SX PERFORMANCE ADVANCED FUEL SYSTEM FOR INDONESIA MARKET.
    ENGINEERED SYSTEMS DESIGNED TO PUSH THE ENVELOPE OF YOUR ENGINE'S PERFORMANCE CAPACITY!
    MADE IN USA , TRUE AEROSPACE ENGINEERING READY FOR THE RACE TRACK AND HIGH PERFORMANCE STREET CAR.
    IF YOU HAVE QUESTIONS REGARDING SX FUEL PERFORMANCE PARTS, PLEASE ASK OR CONTACT AT:
    premierautowerkz@hotmail.com
    Phone: 021-712-55999 / 0817-000-8072
    PRODUCT LISTS ALL INSTOCK
    1. EFI & Carbureted In-Line Electric Fuel Pump
    * Supports carbureted engines up to 1300 HP and fuel injected engines up to 1000 HP at 45 PSI
    * Ultra high-flow rates exceed: 80 GPH at 12 volts and 45 PSI, AND 120 GPH at 12 volts and 10 PSI
    * Flow-thru design maintains maximum cooling, produces outstanding reliability, and provides consistent fuel delivery from idle to full throttle
    * -10 AN inlet/outlet fittings for easy installation
    * Can be mounted inside fuel cell or external
    * For use with gasoline or alcohol fuel systems
    * Passes UL standards for Coast Guard approval for use in marine applications
    * Not for use with reduced sulfur content diesel fuel
    * Requires free flowing (60 micron) fuel filter by SX Performance™
    2. EFI & Carbureted Ultra High-Flow Electric Fuel Pump
    * Supports carbureted engines up to 2000+ HP and fuel-injected engines up to 1500 HP
    * Ultra-high flow rates of 120 GPH at 12 volts and 45 PSI
    * -12 AN inlet/outlet ports
    * Compatible with gasoline and methanol
    * No separate mounting brackets required
    * All pumps available in Mil-Spec Anodize protective coating colors of red, blue, and black
    3. EFI & Carbureted Slim-Line Fuel Filter (AVAILABLE IN -10 AN OR -12 AN)
    * -10 AN OR -12 AN Inlet/Outlet Ports
    * Calibrated for all EFI and carbureted engines up to 2000 HP
    * Compact flow-thru filter design and enlarged ports will literally flow the maximum of whatever a -10 AN OR -12 AN line can handle
    * Virtually no pressure drop [less than .15 PSI pressure drop at 200 GPH]
    * Easily connects before and/or after the SX Performance™ In-Line Electric Fuel Pumps
    * Quickly and easily install and remove aerospace fuel filter element
    * Mounting bracket included
    * Available in red, blue, and black Mil-Spec Anodize
    4. EFI Adjustable Fuel Pressure Regulator
    * Has two (2) -10 AN inlet/outlet ports, one(1) -6 AN return port, and a 1/8 inch NPT gage port
    * Maintains stable fuel system pressure between 35-90 PSI for tuned flow rate flexibility up to 180 GPH (1,100 PPH)
    * Features a vacuum/boost compensating port for a supercharger, turbo, or intake manifold vacuum connection
    * Holds minimum fuel system pressure for 25 PSI for at least 20 minutes after pump shutdown
    * Compact design fits small engine compartments
    5. EFI Adjustable High Flow Fuel Pressure Regulator
    * Maintains stable fuel system pressure between 35-90 PSI for tuned flow rate flexibility exceeding 270 GPH (1,680 PPH)
    * Holds fuel system pressure for at least 20 minutes after pump shutdown
    * Has a -10 AN inlet and outlet, -8 AN return, and 1/8 inch NPT gage ports
    6. Full-Flow Check Valve
    * Aerospace-inspired and custom designed
    * Gain optimum EFI performance without sacrificing emission control
    * Innovative design eliminates engine heat soak conditions
    * Holds a minimum fuel system pressure of 25 PSI for at least 20 minutes after pump shutdown
    * Perfect with gasoline and methanol
    * Machined from 6061-T651 Aircraft-Grade Aluminum Alloy with Military Specification MIL-A-8625 Type II Anodize for extended component life6.
    7. Stainless Steel Reusable Fuel Filter Element
    * Quick-and-easy to install and remove
    * Maximum filtering protection in a compact size
    * 60-micron reusable stainless steel filter element
    * Cleans easily with ordinary carburetor cleaner
    CONTACT INFO: 021-593-62831 / 021-712-55999 / SMS ONLY KE 0817-000-8072
    PLEASE CALL ONLY ON BUSINESS HOURS
    MONDAY TO SATURDAY 10.00 AM TO 7.00 PM
    PIN BB: 28D3E0EE
    CUSTOM F1 VALVETRONIC EXHAUST AVAILABLE
    UNITRONIC INDONESIA DEALER
    PUR WHEELS -- www.purwheels.com -- INDONESIA SOLE OFFICIAL DEALER
    http://www.purwheels.com/video-portfolio/
    3 Hrs 48 Mins 35 Secs
    ini apaan ya bos..?? maklum newbie..
    huhuhuhu.. harganya pasti mahal2 ya.. nunggu kejatoan duren dolo ah..
    Quote Originally Posted by bankaixxx View Post
    Setiap parts beda2 bos. Kabarin aja. Thx
    PIN BB: 28D3E0EE
    Bos.. + pusing dng barang2 yg 1 ini.. pada susah dicerna artinya..
    Pertanyaan saya untuk mobil All New Jazz
    masing2 brp duid bos..? pemasangan di tempat bos kena brp..?
    trus nett nya ya bos..
    Saya bantu bos penjelasannya:
    1. EFI Adjustable Fuel Pressure Regulator
    Gunanya:
    a. Untuk mejaga kestabilan tekanan constant bensin diatas tekanan intake manifold
    b. Untuk mejaga kestabilan tekanan yang stabil antara fuel line dengan intake manifold
    c. Berhubungan dengan injectors mobil dan fuel pump
    d. Untuk memperbesar atau memperkecil tekanan bensin yang masuk ke engine.
    2. EFI High Adjustable Fuel Pressure Regulator
    Fungsi sama dengan yang diatas, untuk aplikasi mobil2 dengan horsepower tinggi dan injector yang besar.
    3. Full-Flow Check Valve
    Gunanya untuk menjaga tekanan bensin pada 25 psi setelah fuel pump mobil berhenti bekerja selama lebih dari 20 menit.
    4. Stainless Steel Reusable Fuel Filter Element
    Ini adalah filter untuk SX Fuel Filter. Gunanya untuk menyaring bensin yang keluar dari fuel tank sebelum masuk ke engine.
    Ini refill untuk SX Fuel Filter.
    Saya akan pm pricenya asap. Thx
    PIN BB: 28D3E0EE
    Bos.. ini PNP dng All New Jazz nggak bos..?? takutnya ndak bisa bos..
    PNP maksudnya: Plug and Play?
    Semuanya Universal pak, bisa diaplikasikan ke mobil2 apa aja.
    PIN BB: 28D3E0EE
    Penjelasan yg sangat jelas.. thx bos..
    Sama2 bos. Thx
    PIN BB: 28D3E0EE
    surabaya
    8 Hrs 29 Mins 12 Secs
    boss utk soluna pake yg mana boss?? (daily use) plz pm hrg nya ya. trims
  1. SOLE DISTRIBUTOR 3M dimana ya....?tolong info nya
    By Tuned by_AAM in forum Diskusi Mesin
    Last Post: 21st April 2010, 18:33
