power nakamichi
Results 1 to 10 of 18
Thread: power nakamichi
  • Short URL:  http://modifika.si/5510
    Manado
    11 Hrs 10 Mins 15 Secs
    power nakamichi
    guys ada yg pengalaman pake power nakamichi di bawah ini?
    modelnya elegan abis ya
    Nakamichi PA-2004
    Power Output (4 ohms) 100 W x 4
    Power Output (2 ohms) 200 W x 4
    Power Output (1 ohm) N/A
    Bridged Power Output (8 ohms) 200 W x 2
    Bridged Power Output (4 ohms) 400 W x 2
    Power Bandwidth 5 Hz - 30 Hz
    Frequency Response
    (1 W / 4 ohms) 5 Hz - 100 Hz
    Total Harmonic Distortion
    (at rated power, 4 ohms) Less than 0.05%
    atau mungkin yg ini?
    PA-4100
    High Current MOSFET Devices
    Gold-Plated Power and Speakers Connectors
    Aluminum Printed Circuit Board (PCB) for All Transistors -
    Stereo & Bridges Mode Application
    • Continuous Phase Control (0 – 180 deg)
    • Terminal Layout At Bottom Of Amplifier
    • 4 Way Protection : Output Short, DC Offset, Thermal & Battery > 18 V
    • Dual LED Indicators (Power & Protect)
    • Double Power Output When Using A 2 ohms Speaker
    Power Output RMS @ 4 ohms 100 W x 4
    Power Output RMS @ 2 ohms 200 W x 4
    Bridged Output RMS @ 4 ohms 350 W x 2
    Frequency Response 20 Hz – 20,000 Hz
    Crossover (Butterworth) HP 15 – 400 Hz
    LP 40 – 400 Hz
    Bass EQ @ 45 Hz 0 – 12 dB
    S/N Ratio >90 dB
    Total Harmonic Distortion <0.05%
    yimmy
    Wah Modelnya Cantik Ui
    4 Hrs 10 Mins 47 Secs
    kerennn
    Di rumah tercinta...
    21 Mins 16 Secs
    viktor mungkin tau
    CEC class A, CA Azur 640 C
    DV-655, DVD-HD870
    B&W, Tannoy
    jak city
    gw masih ada yg made in usa seri PA 2002
    100 X 2 @ 4 ohm
    200 X 2 @ 2 ohm
    Jakarta - Singapore
    8 Hrs 28 Mins 32 Secs
    emank yg manguni posting itu dah buatan mana???
    Keep Smiling..!! Be Happy..!!
    heaven
    udah pernah liat power cubig dual mono??
    modelnya mirip2 gt dech.. silver-item gt,,
    (mirip yg PA-4100)
    Jakarta 14240
    1 Hr 25 Mins 59 Secs
    kalo gua sich mending ambil yang PA 2100. duitnya sama, dapet powernya 2 biji
    Nakamichi sebelum diupgrade dasar suaranya soalnya udah baik. Gua udah denger setelah diupgrade full, kontrolnya bisa lebih ke bawah. Atasnya jauh lebih transparan. Ini power suaranya analog banget....
    Upgrade di supply untuk 6 IC nya ditambahin extra capacitor, trus Resistor utk output, kalo mau full, ICnya ada 2 yang bisa diupgrade.
    Call gua untuk pembuktian test denger
    Jakarta - Singapore
    upgrade ampli FULL itu apa ajah si yg diupgrade???
    Kita ambil contoh power Nakamichi ini....
    jak city
    gambar diatas made in usa
    yg di bawah made in malaysia
    bener kata Victor, n tambahan dikit flat banget suaranya
  1. [WTS] : Power Nakamichi PA-304
    By calla2011 in forum Power Amplifier
    Last Post: 6th August 2012, 16:37
  2. WTS : Power Nakamichi (Buy 1 get 2) & Power u dimension
    By cipto_ng in forum Power Amplifier
    Last Post: 30th April 2012, 08:05
  3. WTB POWER NAKAMICHI
    By giovanni in forum Power Amplifier
    Last Post: 8th May 2011, 08:33
  4. Power Nakamichi
    By AK-47 in forum Diskusi Power Amplifier
    Last Post: 4th July 2007, 00:55
  5. POWER NAKAMICHI PA 304
    By NL in forum Diskusi Power Amplifier
    Last Post: 2nd July 2006, 01:09
