4 channel - xetec, zapco, arc audio ???
Results 1 to 10 of 38
  • Short URL:  http://modifika.si/5501
    Manado
    11 Hrs 5 Mins 28 Secs
    guys bantuin donkkkkk please
    aku butuh 4 channel utk nge-drive mid range ama tweeter
    kira2 apa ya
    xetec P4 EVO - 4x 200 Watt an 2 Ohm, 4x 120 Watt an 4 Ohm oder 2x 380 Watt an 4 Ohm, State of the Art MosFetAmp, Burr Brown OP-Amps and Foil capacitors in Signal path, Top Control, Aktive-Kit Option, Highpass (20-4000 Hz, disengageable), Lowpass (20-4000 Hz, disengageable) for all channels
    or
    ZAPCO ref. 1000.4 -
    Stereo, 4 ohms: 4 x 150
    Stereo, 2 ohms: 4 x 250
    Bridged, 4 ohms: 4x 500
    T.H.D. + Noise: 0.025% @ 4 ohms
    S/N Ratio: <95db
    Slew Rate: >32V/uS
    Damping Factor: >600 @ 4 ohms
    -SymbiLink™ Balanced Inputs
    -Dual variable electronic crossovers w/x10 switch
    -Sub-sonic filter for speaker protection
    -Bass Control Port
    -2 ohm stereo stable
    -Dual bridgeable @ 4 ohm
    -Four channel
    -High Current Bi-Polar output devices
    -Optically isolated MOSFET power supply
    -Switch for use as stereo, single L ch. or R ch. bridge
    -L+R sum mono for use as a bass amp
    -Four layer PC board with heavy 2 oz copper
    -Surface mount technology w/1% resistors,
    precision caps, and massive ground planes
    OR
    ARC AUDIO XXK 4150
    80x4 @4 ohms, 160x4 @2 ohms, & 320x2 @4 ohms bridged
    please need help guys?
    oh yeah ada yg kisaran harga dibawah ini?? thx ya
    aku sih kurang sreg ama arc nya soalnya wattnya paling rendah sih
    tapi ya siapa tau bagus?
    dipake buat midrange ama tweeter
    thx ya teman2 GBU all
    4 Hrs 10 Mins 47 Secs
    pake zapco aja steve. kalo diliat review2 nya selama ini sih, ok buat SQ
    Jakarta - Singapore
    8 Hrs 28 Mins 32 Secs
    gile steve.... upgrade habis2an... habis dapet kangtaw apa neh....
    Besok dah mesti makan2 besar deh... ^_____^
    Keep Smiling..!! Be Happy..!!
    speaker
    gw adanya ZAPCO 650.6 gimana boss ???
    bisa buat narik sub sekalian..... :smt001
    Jakarta - Singapore
    lagi sama2 online neh kita boss speaker
    Manado
    Quote Originally Posted by keparad
    udah penghabisan titik darah terakhir neh
    Manado
    speaker : sori bgt bro aku cuman perlu 4 channel
    speaker
    jangan2 abis menang bola nih......
    melbz
    untuk maen active kan. drivernya 4 ohm bukan?
    Klo utk tweeter sama midrange dgn power kecil 50-80w juga uda cukup bgt bos
    IMO, pke ARC aj
    XETEC belom pernah denger
    Zapco Ref menurut gw agak kering suaranya, ARC menang di dynamic
    MODSTER Motorsport
    - Master of Modifications -
    melbz
    btw harga arc 4150xxk bisa dpt brp bos?
    MODSTER Motorsport
GT Radial MBtech
  1. WTB; ZAPCO DC REF 4 Channel
    By fully.lebay in forum Power Amplifier
    Last Post: 25th May 2011, 23:41
  2. ZAPCO 360AG 4 Channel...
    By n03kiku in forum Diskusi Power Amplifier
    Last Post: 17th April 2011, 23:21
  3. Replies: 14
    Last Post: 17th March 2011, 14:55
  4. Replies: 5
    Last Post: 25th May 2010, 07:58
  5. Amplifire Zapco 6 Channel
    By redvox in forum Power Amplifier
    Last Post: 17th February 2010, 11:00
