[ASK] biar rolla'74 kenceng tanpa swap engine
Results 1 to 10 of 27
  • Short URL:  http://modifika.si/54965
    BDG
    gimana yah caranya rolla veteran biar kenceng tanpa swap engine?! ada yang bisa kasih ide?!
  2. Hokinusa
    BJAmodified Bandung
    6 Days 18 Hrs 39 Mins 17 Secs
    N/A ato forceinduction?
    3 Mths 1 Wk 10 Hrs 26 Mins 9 Secs
    corola type mesinnya apa c?
    klo ga mo swap engine..
    *P&P
    *pengapian
    *Header
    *camsaft
    *4barrel
    *balance kruk as,flywheel
    DLL
    turbo lah... pasti kenceng. Eh, tapi masih karburator ya?
    chaos city, jakarta
    2 Days 17 Hrs 42 Mins 54 Secs
    Quote Originally Posted by Dr.engine View Post
    *P&P
    *pengapian
    *Header
    *camsaft
    *4barrel
    DLL
    setuju banget ma nyang ni bos. nambahin aja, ganti gearboxnya pake t-50, makin mantap bos.............
    dungban
    10 Hrs 18 Mins 13 Secs
    Quote Originally Posted by r3zzz4 View Post
    betulz...gw dulu pernah ngebangun corvet tp yg 78. nambahin oversize jd 100. rante keteng ganti yang dobel ama gir2 nya biar gak cepet meral. per klep nya di dobel lagi. ato ganti trd sekalian. kopling ganti trd.
    sama pompa bensin membran ganti sama yg elektrik. waktu itu g pake mitsuba. plus ganti fan radiator ma yg elektrik juga biar adem.
    around elevator C
    10 Hrs 22 Mins 56 Secs
    Quote Originally Posted by ideydaclown View Post
    selain itu semua kalau bisa kap mesin dan bagasi diganti fiber....
    pasti tambah kenceng...
    BDG
    Quote Originally Posted by RETROtuning View Post
    pgn nya mah sih n/a..
    BDG
    *P&P
    *pengapian
    *Header
    *camsaft
    *4barrel
    DLL
    type mesin nya 3k..
    SMG
    5 Hrs 56 Mins 54 Secs
    type mesin nya 3k..
    port polished,
    naekin kompresi
    light weught pulley..
    balanced cranks shaft...
    header set
    koil, kabel busi, busi,
    4 barrel lah...
    pasti ngacirr
  1. WTA Fortuner AT biar kenceng....
    By Al_vin in forum Diskusi Mesin
    Last Post: 13th March 2010, 06:44
  2. Jazz biar kenceng [need Help]
    By matrix_son in forum Diskusi Mesin
    Last Post: 14th February 2010, 11:19
  3. WTA:SWIFT BIAR LARI KENCENG......
    By P'tank in forum Jual Beli Mesin Lainnya
    Last Post: 24th March 2008, 18:38
  4. Twincamp 1.6 biar kenceng gmn ?
    By Ibal in forum Diskusi Mesin
    Last Post: 21st May 2007, 12:13
  5. Visto biar kenceng larinya...
    By vistojakarta in forum Diskusi Mesin
    Last Post: 14th October 2005, 19:10
