Bekas ABYSS HAMMER CT2000 MONOBLOCK
Results 1 to 10 of 16
  • Short URL:  http://modifika.si/529469
    1 Mth 1 Wk 2 Days 22 Hrs 11 Secs
    CP : 081319920070
    Lokasi : Kelapa Gading
    Kondisi : Mulus, normal, mantap..
    Harga : 9 jt
    ABYSS HAMMER CT2000
    Similar to Tru Technology H-1
    COMMERCIAL GRADE SQ AMPLIFIER/SPL POWER SUPPLY DESIGN
    - Very High Voltage/High Current Class AB Mono Block Bass Amplifiers
    - Absolute Sound Quality Performance with Tremendous Controlled SPL Output
    - C & C Machined Heatsink with Hand Grinded Heatsink Fin Edges
    - Constant Rated RMS Power Output until Thermal Shutdown
    - High Voltage / Current Unregulated Bi-Polar Power Supply
    - +/- 90 Volt Rail Voltage
    - (10) ON® TO-3 (250 Volt) Metal Case Output Devices (20 for SH-1)
    - (12) I.R.® HEXFET® (60 Amp Rated) Power Inverters for Efficiency (24 for SH-1)
    - (2) Hand Wound Power Transformers (4 for SH-1)
    - (4) High Speed Rectifier Diodes (8 for SH-1)
    - (2) 100Volt 6800mf Capacitors (4 for SH-1)
    - (2) Pairs Complimentary Transistors for Input Stage
    - (2) 3 inch Variable speed Intake/Exhaust Fans (4 for SH-1)
    - 69.1% Efficiency @ 4 W (Full Power)
    - WIMA® Polyproplyne & Mylar Capacitors
    - Balanced Line input capability
    - Symmetrically mounted heat generating parts
    - PROPRIETARY RF Grounding Techniques used for
    Improved Reliability and HF noise rejection
    - Power section uses Discrete Circuitry throughout Audio Path
    - Linkable Amplifiers (H-1)
    - 18dB Low Pass X-over (40Hz ~ 300Hz)
    - 24dB Subsonic filter (10Hz ~ 100Hz)
    - Remote Bass control knob (Optional)
    - 4 Gauge Power/Ground Input (2 Sets for SH-1)
    - 8 Gauge Speaker Wire Output (1 Set for Both Models)
    - Hand Built in California, U.S.A.
    SPECIFICATIONS:
    Channels: 1 CH
    Frequency Response: 10Hz ~ 300KHz ±1dB
    Rated Power: 14.4 Volts DC
    T.H.D.: < 0.1%
    4 Ohm RMS: 600W x 1
    2 Ohm RMS: 1,000W x 1
    1 Ohm RMS: 1,500W x 1
    S/N Ratio: > 100dB
    Input Sensitivity: 0.16mV ~ 4 Volts
    Damping Factor: > 700
    Efficiency: 69.10%
    Fuse Requirement: 120 Amp
    Power Supply: 11 ~ 17.9 Volts DC
    Low Pass @ 18dB / oct: 40Hz ~ 300Hz
    Sub-Sonic @ 24dB: 10Hz ~ 100Hz
    Remote Bass Knob: Yes
    Bass Boost: No
    Dimensions: (L x W x H): 15" x 8 13/16" x 3 19/16"
    Weight: 14 lbs. / 6.4 Kg
    Thx Modcom
    1 Mth 2 Wks 4 Days 9 Mins 12 Secs
    Widiw abis brg hien aja gk kepake ama suhu shinigami , ampunnnnnnnnnnn
    Clarion HXD2se/Helix DSP Pro/Zapco Z.150LE+Abyss CT2000/Dynaudio esotar2+Idmax 10"/DIY rca+Ndeso rca,Tesla quad,HH,Wbt, Mundorf,Acrolink,Furutech,Batcap
    Click here to hear my active 2way setup
    Quote Originally Posted by skyven View Post
  1. BEKAS [FS] ABYSS HAMMER CT2000 HIGH END MONOBLOCK
    By b2okane in forum Power Amplifier
    Last Post: 9th October 2013, 20:49
  2. High End ABYSS POWER 1.5K / HAMMER kondisi muluus ex display
    By MR.GASOLINE in forum Power Amplifier
    Last Post: 23rd July 2013, 15:16
  3. WTB MONOBLOCK TRU HAMMER H 1
    By metalindosteel in forum Power Amplifier
    Last Post: 24th February 2013, 07:10
  4. ABYSS 1.5K Monoblock
    By edwin_sasmito in forum Power Amplifier
    Last Post: 8th November 2011, 07:21
  5. FS: Abyss CT2000
    By godfather in forum Power Amplifier
    Last Post: 23rd October 2011, 14:16
