Switzer Performance Packages for Nissan GTR R35 (600-1800Hp)
  • Short URL:  http://modifika.si/528878
    1 Wk 17 Hrs 1 Min 44 Secs
    SWITZER P600
    Switzer ECU Calibration
    Cobb AccessPort (with Trans. Control)
    Switzer SS90 Lightweight Stainless Steel 90mm Sport Exhaust
    High-Flow Drop-In Air Filters
    SWITZER P700
    Switzer ball-bearing turbocharger upgrades
    High-pressure wastegate actuators
    Switzer High-flow intake assembly with Billet MAF housing
    High-flow fuel injectors
    Switzer Fuel System Upgrades
    SWITZER P800
    Switzer MONSTER intercoolers
    Switzer high-flow test pipes (down pipes)
    Switzer fuel system upgrades
    Switzer racing thermostat and housing
    *Required for P800 but not included
    Switzer SS90 lightweight stainless steel 90mm sport exhaust
    Cobb AccessPort (w/ trans. control)
    *Upgrade options also available
    Switzer transmission cooling package
    Switzer engine cooling package
    Switzer GR6 trans. upgrade
    Switzer stage 1 engine upgrade
    SWITZER E900 (900HP)
    [SIZE=3]SWITZER E900 PACKAGE FOR R35 GTR
    Switzer Fuel Injector Kit
    Electronic Boost Controller
    Switzer Monster Intercooler Kit
    Switzer V2 Turbochargers (req's good cores)
    High-Pressure Wastegate Actuators
    COBB ACCESSPORT
    Switzer E900 Calibration for COBB AP
    Switzer MAF/Intake and Filter Assembly
    Switzer E900 Sensor Upgrade Package (includes revised MAF and MAP sensors)
    Switzer High-Flow Intakes for Switzer MAF
    Switzer V2 Off-Road Test Pipes
    Switzer Ethanol-Spec Fuel System Upgrades
    Switzer Cooling Package
    SWITZER STAGE 3 DODSON/SHEP TRANSMISSION UPGRADES:
    PPg 1st gear set
    Dodson Sportsman clutch
    Dodson FWD retainer
    Dodson Mechanical lock #1
    Dodson Mechanical lock #2
    O-ring and seal upgrade kit
    Oil pump shaft upgrade with blueprint
    6 neodymium magnets
    High temp rear differential oil seal
    Stainless re-usable internal filter
    SWITZER-BUILT STAGE 1 VR38DETT ENGINE:
    Switzer Spec MAHLE Pistons, Pins, and Rings
    Switzer Spec Carillo Connecting Rods
    Switzer Spec Camshafts
    Switzer Blueprinted Engine and Oil Pump
    SWITZER ULTIMATE FF(1000HP)
    Switzer ball-bearing turbochargers
    Switzer cast-stainless steel exhaust manifolds
    Switzer turbo oil and coolant lines
    Switzer high-flow downpipes
    Switzer high-pressure wastegates
    Switzer turbo/downpipe heat shielding and thermal wrap
    Switzer SS90 lightweight stainless steel exhaust
    Switzer engine cooling PKG
    Switzer / Sheptrans GR6 upgrade
    Switzer Transmission Cooling PKG
    Switzer stage 2 engine upgrade
    Switzer / Sheptrans stage 4 trans, upgrade
    Upgraded GTR axles
    Upgraded axle stub shaft and hubs
    Upper and lower differential braces
    Switzer 6 wheel set w/ drag radials
    Switzer brake upgrades
    Switzer suspension upgrades
    Switzer "stealth" NHRA certified roll cage
    SWITZER R1K (1100HP)
    SPI R1K Turbos
    SPI R1K Cast Stainless Manifolds
    SPI R1K Turbo Oil and Coolant Lines
    Switzer R1K Turbo/Downpipe Heat Shielding and Thermal Wrap
    SPI R1K High Pressure Wastegates
    SPI R1K Downpipes
    SPI high-flow intake assy. W/ billet MAF, Filters, and Sensors
    SPI "MONSTER" Intercoolers (incl. plumbing, couplings, and BOVs)
    SPI R1K High-Flow Fuel Injector Kit
    SPI R1K Fuel System Upgrades (Lines, Pumps, Fittings, Regulator)
    SPI R1K Boost Control Solenoid
    SPI R1K Cooling System PKG (+ Coolant drain & fill)
    SPI R1K Stage 4 Transmission Build W/ ProMax Clutch
    SPI Transmission Cooling PKG
    SPI R1K Stage 1 VR38DETT Engine Build
    Switzer R1K Calibration for Cobb AccessPort
    Switzer Tuned Transmission Control Unit and Diagnostic Cable
    Syvecs SGTR ECU
    Switzers stage 2 VR38DETT Engine Build
    Upgraded GTR axles
    SWITZER R1KX(1500HP)
    SPI R1K-X Turbos
    SPI R1K-X Cast Stainless Manifolds
    SPI R1K-X Turbo Oil and Coolant Lines
    Switzer R1K-X Turbo/Downpipe Heat Shielding and Thermal Wrap
    SPI R1K-X High Pressure Wastegates
    SPI R1K-X Downpipes
    Switzer Intake Manifold w/ 3rd Injection Rail System
    SPI R1K-X High-Flow Fuel Injector Kit
    SPI R1K-X Fuel System Upgrades (Lines, Pumps, Fittings, Regulator)
    SPI R1K-X Boost Control Solenoid
    SPI R1K-X Cooling System PKG (+ Coolant drain & fill)
    SPI R1K-X Stage 4 Transmission Build W/ ProMax Clutch
    SPI R1K-X Stage 2 VR38DETT Engine Build
    Syvecs S8 ECU
    Switzer R1K-X Calibration for Syvecs
    Upgraded GTR axles
    SWITZER GOLIATH (1800HP)
    SPI Goliath Turbos
    SPI Goliath Cast Stainless Manifolds
    SPI Goliath Turbo Oil and Coolant Lines
    SPI Goliath Turbo/Downpipe Heat Shielding and Thermal Wrap
    SPI Goliath High Pressure Wastegates
    SPI Goliath Downpipes
    SPI Goliath High-Flow Fuel Injector Kit
    SPI Goliath Fuel System Upgrades
    SPI Goliath Boost Control Solenoid
    SPI Goliath Cooling System PKG (+ Coolant drain & fill)
    SPI Goliath Stage 4 Transmission Build W/ ProMax Clutch
    SPI Goliath Stage 2 VR38DETT Engine Build
    Syvecs S8 ECU Syvecs Sensor Pack for Flex Fuel and other datalogging
    Switzer Goliath Calibration for Syvecs - Flex Fuel
    Dyno Tuning and Testing
    Street Tuning and Testing
    93 Octane Pump Fuel for Break-in and Tuning
    E85 Fuel for Dyno Tuning and Testing
    Engine oil changes
    Switzer Signature Series Drag 6 Pack (wheels & tires)
    Upgraded GTR axles
    Switzer NanoCarbon front brake pads
    H&R 09-up Nissan GT-R Typ R35 Sport Spring
    ABSOLUTE AUTO
    Ruko Elang Laut Boulevard Blok C No.8-9
    Pantai Indah Kapuk , Jakarta Utara 14770
    No Telp : 021-9777 0358 / 081-184-999-3
    PIN BB : 277F99C7
    Aftermarket & Parts Division : 0817-085-6007 / 0811-888-0371 / PIN BB : 28BBB085
    E-Mail : enquiry.absoluteauto@gmail.com
    Website : www.absolute-auto.net
    Facebook : https://www.facebook.com/pages/Absolute-Auto-Jakarta
    1 Wk 2 Hrs 44 Mins 13 Secs
    nge built nya mbl nya di shipping ke us / bule nya dtg ksini bro..?
    bulenya k sni bro
    ABSOLUTE AUTO
    PIN BB : 277F99C7
  1. For sell: Ori GTR R35 velg
    By gyovee in forum Ragam Ukuran
    Last Post: 11th June 2015, 10:34
  2. ATPM Nissan Jual GTR-R35 di Indonesia Akhir Tahun
    By 200CN in forum Berita Otomotif Mobil
    Last Post: 16th July 2014, 08:13
  3. >> Performance Package For GE8 Matic (Daily Driven) <<
    By gbers in forum Jasa (Tunning, Service Engine, etc)
    Last Post: 23rd April 2013, 10:11
  4. WTS RADIATOR ALMUNIUM FOR JAZZ GE & GTR R35
    By ROSELLA in forum Jual Beli Mesin Lainnya
    Last Post: 8th August 2011, 13:29
