Dijual Digital Procesor High End Helix Competition CDSP...Segel,.lengkap,mulus kayak baru..Germany..
Spek dan feature :
http://www.audiotec-fischer.de/lng/en/c-dsp.html
Windows interface – communication via USB 2.0
MicroSD slot to upload DSP settings without having to connect the DSP to a PC
• TwinPower – two audio DSPs with 56-bit resolution for optimal sound properties and maximum computing power
Future-oriented hardware features for virtually unlimited expansion options
Freely configurable inputs and outputs
Graphical 30-band EQ per channel with the “fine adjustment” of the individual bands in 1/24 octave steps and a quality setting between 0,5 and 15, time correction in 7-mm steps, all established filter characteristics are available and much more
Inputs: 8 x RC A, 8 x high-level, 1 x optical, 1 x control input, MicroSD and USB
Outputs: 8 x RC A and remote output
Input sensitivity adjustable
High-end AD & DA converter
Start/stop capable down to 6 volts
Dimensions: 190 x 190 x 42 mm
Compatible with the HELIX Optical & Bluetooth Interface, which will soon go on the market – this makes it possible to operate the system using a Smartphone and to configure it with a PC
1.Kondisi barang mulus ori dan segel
2.Lokasi barang di Jakarta selatan (Pakubuwono Area) Bisa test di tempat
Untuk di luar kota bisa dikirim via JNE or MEX
3.Untuk informasi Bisa call/whatsapp 0811880333 or pin bb 2AA35183
4.Terima kasih Modcom
5.Untuk posting lainnya silakan buka link ini :
http://www.modifikasi.com/member.php/130849-Ferrlim
