Bekas Jual Robot Femisapien - WowWee, Keren dan Unik
Results 1 to 10 of 10
  • Short URL:  http://modifika.si/528623
    1 Day 17 Hrs 38 Mins 54 Secs
    Jual Robot Femisapien - WowWee, Keren dan Unik. Bisa nyanyi, dansa, dan berinteraksi.
    Highlights:
    RS Femisapien has 3 main function modes, each corresponding to a different head position. Tilt her head in the desired direction and her function mode will change!
    In Attentive Mode, RS Femisapien interacts directly with you. She will slow pose, be your back-up singer, introduce herself, dance with you, and even blow kisses.
    In Learning Mode, teach RS Femisapien a sequence of movements that she can perform for you, up to 80 steps long! RS Femisapien is also pre-programmed with a number of precise functions and sounds that can be used as part of her program routine, including striking poses, holding and presenting thin objects such as business cards and blowing kisses!
    Responsive Mode is RS Femisapien's main walking mode; she can interact with your sounds or perform comedy routines. She will also detect objects at neck level, and stop when something is in her path. And, she can even respond to your hand gestures as you wave in front of her!
    RS Femisapien features responsive 4-way joystick hands. Each hand can be moved forward, backward, inward or outward to initiate various actions. Depending on Femisapien's head tilt, each hand position combination differs.
    Acts as your own personal back-up singer with her "Shoop" feature. Sing aloud or play music, and when in range (within 3 feet /1 m) of any sound source, she will move her hips and arms to the music and sing a back-up tune.
    Keterangan lebih lanjut bisa lihat di:
    http://www.wowwee.com/en/products/to...ics/femisapien
    Silahkan lihat foto-foto dibawah ini. Harga: 1,5 juta.
    Jika minat, silahkan hubungi telepon/sms di: 085776179618.
    COD di Emporimum Mall Pluit. Sepatu cuma sepasang. Siapa cepat dia dapat. Ga pake tipu2. Thanks.
    Silahkan yang ingin koleksi
    Robot bisa interaksi
    Silahkan sma
    Robo femisapien
    Silahkan sms yang minat
    Femme robo sapien for sale
    Silahkan sms
    Yang ingin koleksi
