Permisi Modcomers
Mau numpang jualan Profender 40mm bgasbore shock untuk aplikasi 4x4
Super Twin tube designed with a big piston and a big shaft that provides excellent performance suited for heavy duty use. The perfect specification allows the driver to enjoyed a more comfortable and improved ride.
Low pressure Nitrogen Gas prevent cavity of oil inside the shock when it gets hot. So shocks will consistently work until you arrive at the destination. The inside of the piston is made of Teflon that allows it to slide smoothly and last long. Super polished shaft is excellent in working properly. The shock absorber valve is made of materials from Sandvik Company, Sweden. They can accurately control the needed damping force. It is sealed properly to protect oil leaks and can perform very weel even in dusty and dirty conditions.
enak buat harian, dan buat adventure ringan
Aplikasi
Plug and play: Dmax, Navarra, Hilux, Innova, pajero sport, fortuner, triton, ranger, everest.
Kendaran lain bisa dgn modifikasi ringan pada absorber itu sendiri atau pada kendaran; hardtop, taruna dll
bisa COD (jagakarsa)
bisa kirim2 juga
mau temuan buat ngrobrol juga boleh di jagakarsa buat nanya2 aplikasi dll
sms 08888332362
