Bekas FS : POWER SONY XM 504 Z (JAPAN) KONDISI MULUS
  • Short URL:  http://modifika.si/528009
    SURABAYA
    1 Mth 6 Days 19 Hrs 8 Mins 19 Secs
    Permisi Modcomers
    SOLD....Tks Mr R. Tks Modcom
    SONY XM 504 Z - 4 Channel
    - Kondisi 95% mulus
    - No ex service
    - Full ori
    - Sehat dan normal 100%
    - Kualitas bagus
    - Masih asli JAPAN
    Spek :
    Class A/B Stereo Amplifier YES
    High Pass Filter, selectable (Hz) off / 80
    Low Pass Filter, selectable (Hz) off / 80
    Rated Output Power (DIN 45500)
    Max. at 4 ohm 4 x 50
    Min. at 4 ohm 2 x 50 + 1 x 120
    Max.2 ohm 4 x 60
    Max. channel configuration at 1 ohm NO
    Rated Output Power, RMS 20 - 20000 Hz
    Max. at 4 ohm (W) / THD (%) 4x 50 / 0.04%
    Min. at 4 ohm (W) / THD (%) 2x 50 + 1 x 120 / 0.1%
    Max. at 2 ohm (W) / THD (%) 4 x 60 / 0.1
    Max. at 1 ohm (W) / THD (%) NO
    Maximum Output Power (1 kHz)
    Max. at 4 ohm 4 x 100
    Min. at 4 ohm 2 x 125 + 1 x 250
    Max. at 2 ohm 4 x 125
    Frequency Response (Hz) 5 - 50,000
    Tolerance (dB) + 0 / - 3
    Signal to Noise Ratio (dB)
    Total Harmonic Distortion at 1 kHz (%) 0.005
    Harga : SOLD
    Berminat hub : 082233034400/083830479495
    Penampakan :
    No penipuan Gan
    Silahkan klik "MY PROFILE" utk lihat iklan saya yg lain dan beberap test
    Kirim bisa,cod bisa
    Datang langsung bisa
    Tks Modcom
    SURABAYA
    UP UP UP UP UP UP UP
  1. BEKAS FS : POWER MB ACOUSTICS U S A KONDISI BAGUS
    By daffaza in forum Power Amplifier
    Last Post: 25th September 2013, 07:42
  2. POWER SONY XM-5540 MADE IN JAPAN (malang)
    By paksunarto in forum Power Amplifier
    Last Post: 27th June 2013, 01:59
  3. Power Sony XM 554 ZR & Kenwood KAC 8410...
    By jabrickz in forum Diskusi Power Amplifier
    Last Post: 25th October 2007, 00:29
  4. Power Sony XM-2540S
    By rahargo in forum Diskusi Power Amplifier
    Last Post: 2nd January 2007, 13:58
  5. Cari manual Book Power Sony XM-2540S
    By rahargo in forum Diskusi Audio Lainnya
    Last Post: 18th December 2006, 07:37
