Bekas DIJUAL pOWER gENESIS FOUR CHANNEL MULUS DAN ORI..........
  • Short URL:  http://modifika.si/527751
    1 Mth 2 Wks 16 Hrs 23 Mins 39 Secs
    Dijual power Genesis four Channel...kondisi mulus dan full original,no service.......
    Details:
    Our reference Four Channel features twin power supplies for extra energy reserves, ensuring excellent fidelity at any volume level. Independent and fully flexible filtering allows the Four Channel to suit any system.
    Specification:
    4 x 75W / 2 x 75W + 1 x 250W at 4 ohms
    Technologies:
    •Thermal bias tracking - Eliminates distortion
    •Custom capable design - Create your own unique amplifier
    •DC Sub level control - Eliminates noise pickup
    •Dual power supplies - For outstanding imaging and soundstage
    •Smart Switching - Automatically routes the signal
    •Simultaneous crossovers - For complete system flexibility
    Features:
    •Power Source [Volts] - 10.8 ~ 14.4
    •Number of Channels - 4
    •Rated Power @ 14.4v [4 Ohm] - 4 x 50
    •Watts RMS @ 0.1% - Rated [2 Ohm] - 4 x 100
    •All Channels Driven - Rated [Bridge 4 Ohm] - 2 x 200
    •Typical Power @ 14.4v [4 Ohm] - 4 x 95
    •Watts RMS @ 0.1% - Typical [2 Ohm] - 4 x 85
    •All Channels Driven - Typical [Bridge 4 Ohm] - 2 x 290
    •Maximum Current Draw - 75 Amps
    •Signal to Noise Ratio 'A' Wtd [4 Ohm] - > 110dB
    •THD + Noise @ Rated Output - 0.1%
    •Input Sensitivity [Volts RMS] - 0.3 ~ 5
    •Frequency Response - 20 Hz ~ 20 KHz
    •Dimensions H x W x D [mm]* - 62 x 360 x 210
    •Weight [Kg] - 4.7
    1.Kondisi barang mulus
    2.Lokasi barang di Jakarta selatan (Pakubuwono Area) Bisa test di tempat
    Untuk di luar kota bisa dikirim via JNE or MEX
    3.Untuk informasi Bisa call/whatsapp 0811880333 or pin bb 2AA35183
    4.Terima kasih Modcom
    5.Untuk posting lainnya silakan buka link ini :
    http://www.modifikasi.com/member.php/130849-Ferrlim
    Hub 0811880333 and pin bb baru 2aa52a1c,thanks
    Up.......................
  1. BEKAS Dijual Sub Woofer High End Genesis Audiophile 10"mulus dan ori........
    By Ferrlim in forum Speaker - SubWoofer
    Last Post: 30th April 2014, 16:28
  2. BEKAS POWER GENESIS FIVE CHANNEL MULUS DAN MURAH
    By daffaza in forum Power Amplifier
    Last Post: 13th April 2014, 04:07
  3. wts power rockford 300 mosfet mulus dan ori
    By erwanto.sby in forum Power Amplifier
    Last Post: 28th February 2013, 08:43
  4. genesis four channel mulus
    By carloramses in forum Power Amplifier
    Last Post: 14th December 2011, 07:56
  5. Replies: 4
    Last Post: 10th July 2009, 15:47
