Baru JUAL LIQUI MOLY OILS & ADDITIVES
Page 1 of 85 12345 ... LastLast
Results 1 to 10 of 848
  • Short URL:  http://modifika.si/523558
    Jkt
    3 Mths 3 Wks 5 Days 6 Hrs 7 Mins 6 Secs
    Dear All Member,
    Saya mohon izin untuk memulai thread baru yang melanjutkan jualan thread lama saya yang terpecah2 menjadi 1 disini
    Contact Number :
    0818 898 229 (SMS Only)
    0812 9072 6879 (CALL Only)
    TERIMA KIRIM LUAR KOTA
    Berikut adalah berbagai product dari LIQUI MOLY yang saya jual (available for other LIQUI MOLY product, text me for further details)
    Spoiler for LIQUI MOLY MOTOR OILS: Show
    1. LIQUI MOLY Top Tec 4100 5W-40
    Top quality, state-of-the-art low-friction motor oil for use all year round. Guarantees a motor oil that provides exceptional protection against wear and reduces oil and fuel consumption.Top Tec 4100 meets the latest requirements of BMW and Mercedes Benz for Euro IV diesel-powered vehicles equipped with a soot particulate filter.
    2. LIQUI MOLY Longtime High Tech 5W-30 *3RD BEST SELLER
    Top-quality, state-of-the-art, low-friction motor oil for use all year round. The combination of unconventional basic oils using synthetic technology, together with the latest additive technology, guarantees a motor oil that provides exceptional protection against wear and reduces oil and fuel consumption, while ensuring that the engine is immediately supplied with oil.
    3. LIQUI MOLY Leichtlauf Special AA 5W-30 *2ND BEST SELLER
    Modern premium class low-friction motor oil that was specially developed for year-round use in Japanese and American vehicles. Oil change intervals of up to 40,000 km are thus possible, depending on the manufacturer’s specifications. Optimum for modern Japanese and American gasoline and diesel engines with multi-valve technology and turbocharging with and without charge air cooling. Especially suitable where there are long intervals between oil changes and heavy duty engine requirements.
    4. LIQUI MOLY MoS2 Leichtlauf 10W-40*1ST BEST SELLER
    The MoS2 anti-friction lubricant forms a high load-bearing film of lubricant on all friction and sliding surfaces. The MoS2-lubricant film reduces the resistance to friction and allows engines to run so they conserve more energy even under extreme conditions. MoS2 Energy Conserving guarantees: significantly less fuel and oil consumption. Significant wear reduction, fewer breakdowns and emergency lubrication properties. Stable to ageing and stable viscosity. Good cold-start behaviour and high operational reliability. Prevents sludge formation. Tested on catalytic converters and turbochargers.
    5. LIQUI MOLY Leichtlauf 10 W-40
    High performance energy-conserving engine oil formulated according to the latest additive technology using the latest synthetic components.Year-round oil for modern petrol and passenger vehicle Diesel and turbocharged engines with and without intercooling. Suitable where there are long intervals between oil changes and extreme engine requirements.
    Spoiler for LIQUI MOLY ENGINE OIL ADDITIVES: Show
    1. LIQUI MOLY Ceratec
    CERA TEC is a high-tech ceramic wear protection product for all motor oils. CERA TEC reduces friction and wear due to ceramic compounds that withstand extremely high chemical and thermal loads. Prevents direct metal-to-metal contact, thus increasing the engine service life. The low-friction effect reduces fuel consumption in gasoline and diesel engines.
    Sufficient for 5 liters of motor oil. CERA TEC is added to motor oil and is self-mixing. CERA TEC provides extreme wear protection for all moving parts and friction surfaces in the engine.
    2. LIQUI MOLY MoS2 Oil Additive
    The anti-friction lubricant MoS2 forms a high load-bearing film of lubricant on all friction and sliding surfaces. This product reduces friction and guarantees energy-conserving performance for the unit. This yields the following advantages: significant savings in fuel and oil consumption, scientifically proved reduction in wear, fewer break-downs, emergency lubrication properties. Tested on catalytic converters and turbochargers.
    Added to the lubricating oils of engines, compressors, pumps and especially motor vehicle engines (gasoline and diesel). Mixable with all commercially available motor oils.
    3. LIQUI MOLY Engine Flush
    Engine Flush is a highly effective cleaning fluid for clearing the engine interior of troublesome deposits. In combination with the carrier fluid, the ideally formulated combination of detergent and dispersant additives dissolves sludge and lacquer formers quickly and reliably.
    Spoiler for LIQUI MOLY DIESEL FUEL ADDITIVES: Show
    1. LIQUI MOLY Diesel Purge
    Diesel Purge removes deposits from injectors and the pistons/combustion chamber. Eliminates engine-running problems. No more knocking under partial load -- smoother idling and softer engine running. Cleaner injectors produce optimum engine running. Cleans the whole fuel system. Protects against corrosion. Guarantees good combustion, increased economy and operational reliability.
    2. LIQUI MOLY Common Rail Diesel Additive
    Protects the components of the fuel system (especially Common Rail Diesel) against wear, corrosion and deposits. Increases the lubricating action of Diesel fuel. Suitable for all Diesel engine vehicles with Common Rail injection systems. Add the contents of the can to the fuel when filling up. 250 ml is sufficient for up to 75 litres of fuel.
    3. LIQUI MOLY Super Diesel Additive
    Suitable for all Diesel engines in passenger and commercials vehicles, construction machinery and stationary engines. Outstandingly suitable for preserving engines, even during long periods of non-use under extreme conditions.
    Spoiler for LIQUI MOLY GASOLINE FUEL ADDITIVES: Show
    1. LIQUI MOLY Catalytic System Cleaner
    Special active solvent with a high-tech additive combination for removing typical contamination and deposits found in the intake and combustion system. The high cleaning effect ensures a clean catalytic converter and reduces the exhaust emissions. Dissolves and removes deposits and contaminants such as oil, resins, adhesive residues, etc. of the intake and combustion system. Increases the reliability of gasoline engines and the catalytic system.
    2. LIQUI MOLY Injection Cleaner
    Cleans contaminated petrol injection systems, removes carbon,deposits and deposits from fuel pipes, fuel distributors, injection,and inlet valves. Suitable for,engines with catalytic converters.
    For eliminating problems such as starting,difficulties, irregular idling, poor throttle response, performance losses, lean surging,and poor exhaust values.
    3. LIQUI MOLY Valve Clean
    Valve Clean cleans valves, injection systems, intakes, carburettors and combustion chambers and keeps them clean. Clean engines save fuel. Promotes optimum engine performance and fuel utilisation. The combustion produces a lower level of pollutants and the engine is spared. Protects against corrosion and carburettor icing.
    For all petrol engines. Suitable for standard and high-octane petrol, leaded and unleaded. 150 ml is sufficient for up to 75 litres of fuel.
    Spoiler for LIQUI MOLY SERVICE PRODUCTS: Show
    1. LIQUI MOLY Rapid Cleaner (Schnell-Reiniger)
    Makes your assembly work cleaner, easier and safer. Removes oil, grease and dirt fast without trace. The parts being treated are absolutely free of residues and fully degreased.
    Universal cleaner for the rapid cleaning and degreasing of small structural components in motor vehicles and industry. Used for brakes and clutches, transmissions and assembly and repair work.
    Demikian sekiranya produk-produk dari LIQUI MOLY yang saya jual, kindly feel free to ask for detail.
    Contact Number :
    Thanks & Best Regards,
    std aja de
    Jkt
    Liqui Moly
    Liqui Moly Common Rail Additive
    Liqui Moly Diesel Purge
    Jual Oli Shell Helix Ultra 5W-40
    Jual strutbar nissan infiniti
    Jual gantungan kunci / dompet stnk bahan suede model terkini
    Jkt
    Liqui Moly
    Jkt
    Liqui Moly
    Jkt
    Liqui Moly
    Jkt
    Liqui Moly
    Jkt
    Liqui Moly
    Jkt
    Liqui Moly
    Jkt
    Liqui Moly
    Jkt
    Liqui Moly
GT Radial Venom 300x250
  1. Liqui Moly Products - engine oil & additives
    By SIMOTA in forum Simota Racing Sports
    Last Post: 7th May 2017, 07:44
  2. Replies: 509
    Last Post: 2nd October 2015, 12:54
  3. *** JUAL : OLI LIQUI MOLY ***
    By std aja de in forum Jual Beli Mesin Lainnya
    Last Post: 19th October 2012, 00:22
  4. JUAL : LIQUI MOLY DIESEL PURGE
    Last Post: 19th October 2012, 00:21
  5. Ask: Masih ada yg jual oli liqui moly?
    By Erai in forum Diskusi Mesin
    Last Post: 23rd April 2010, 07:17
