| RACING GAUGE & TACHOMETER |
  • Short URL:  http://modifika.si/505645
    DEFI RACER GAUGE METER SIZE 60MM
    Racer Gauge the control unit in a completely independent operating unnecessary, warning, peak, dare stripped-down functions such as memory, is a meter that was developed with the aim of easily accessible Defi in hand. Because it is not a link-type, the power supply must be wired one by one. Lighting system inherited the self-emission method of BF type, it has realized the beautiful lighting and precision of Defi unique.
    It is with a self-diagnostic function of disconnection and short-circuit of wiring, wake up in the IGN ON self-emitting type meter (IGN OFF sometimes guidance appears type). Defi beautifully adopted the high-brightness LED, which was specially developed uniform illumination Opening / Ending mode adopted by flash ceremony that shines like lightning
    ALL BLACK WHEN IGN OFF
    3 COLOR OPTION - WHICH COLOR IS YOUR FAV ONE?
    Gauge Types Available:
    - Boost/Vacuum -0.8~2.0 Bar
    - Pressure (Oil & Fuel) 0~10 Bar
    - Temperature (Water & Oil) 30~150 C degree
    - Exhaust Gas Temperature/EGT 200~1100 C degree
    Color Option Available:
    - Red Amber
    - White
    - Blue
    Note: Electrical types, includes all necessary hardware, sensors/senders & mounting brackets
    A'PEXi EL II SYSTEM GAUGE METER 60MM
    Characteristics:
    - All meters can be collectively managed by the control unit.
    - By connecting fuel pressure meter and boost meter, the differences in pressure is visualized.
    - The digital network can connect up to 6 units.
    - The small, light weight design allows the unit to be mounted basically anywhere in the car.
    - Embedded with memory replay, peak hold and warning functions.
    - Data is backed up even when the battery is disconnected.
    - Installing bracket is included
    A'PEXi EL II System Gauge Meter 60mm is an Electrical Gauge Meter which works only with A'PEXi Control Unit. The following are A'PEXi Gauge that we have on-stock:
    Black Face with Silver Bezel
    - Boost Meter (2 Bar)
    - Exhaust Gas Temperature /EGT (1200 Celsius Degree)
    - Oil Temperature (150 Celsius Degree)
    - Water Temperature (130 Celsius Degree)
    - Fuel Pressure (6 Bar)
    White Face with Silver Bezel
    - Oil Pressure (10 Bar)
    PURCHASE 3 SET OF GAUGES, GET SPECIAL PRICE AND FREE CONTROL UNIT
    AUTO METER METRIC GAUGE 52MM
    SPORT-COMP
    Auto Meter Sport-Comp Gauges endure even the toughest racing environment. They have black faces, white accents, red pointers, silver or black bezels, and around-the-dial lighting (compared to Sport-Comp Gauges with through-the-dial lighting).
    Gauge Types Available :
    - Boost/Vacuum Gauge (60 cm/Hg ~ 2 Bar)
    - Boost Gauge - Diesel (0 ~ 2.5 Bar)
    - Oil Pressure Gauge (0~ 14 Bar)
    - Oil Temperature Gauge (60 ~ 140 Celsius Degree)
    - WaterTemperature Gauge (50~ 115 Celsius Degree)
    - Pyrometer/Exhaust Temp (0~ 900 Celsius Degree)
    PHANTOM
    Stark white dials, bright orange pointers, and subtle black bezels make this extensive high performance line the perfect match for any application.
    These instruments are illuminated using perimeter incandescent lighting. Red and green bulb covers are included to change backlight color. Additional bulb cover and LED replacement bulb options available separately.
    ES GAUGE
    Black satin bezels, traditional hi-perf meters with Euro-style dials, glowing red pointers and Bright Red LED through the dial lighting set this line apart.
    AUTOMETER GAUGEWORKS
    - Angle Ring 52mm (Black)
    - Gauge Panel Single Hole 52mm (Black)
    - Gauge Panel Single Dual 52mm (Black)
    - Gauge Panel Single Triple 52mm (Black)
    - Mounting Cup 52mm (Black)
    STRI X-LINE IMPERIAL GAUGE 52MM
    Stri XLine Raging Gauges are the perfect option for tuners looking for a high quality, low cost gauge for their project. Built with to the same quality standards as the Stri DSD Gauges, Stri XLine Racing Gauges are built to impress, and perform!
    Features:
    - 52mm (2-1/16”)
    - Warning – Factory Preset (Electric Only)
    - 270 Sweep – High Resolution Reading
    - Start-up Open Mode (Electric Only)
    - Dimmer – Reduce Brightness for Night Driving
    - High Brightness LED
    - Light-Weight Aluminum Casing
    Stocks Available:
    - Boost Meter (30PSI) CLEAR LENS - LED AMBER
    - Water Temperature (250F) CLEAR LENS - LED AMBER
    - Oil Temperature (300F) SMOKE LENS - LED AMBER
    - Exhaust Gas Temperature/EGT (2000F) SMOKE LENS - LED AMBER
    - Oil Pressure (100PSI) SMOKE LENS - LED AMBER
    DEFI RACER TACHOMETER 80MM WITH SHIFTLAMP
    Available in 9000 RPM & 11000 RPM
    - Red Amber
    - White
    - Blue
    Note: Electrical types, includes all necessary hardware & mounting brackets
    AUTO METER TACHOMETER
    Mountable in every conceivable position, the versatility and durability of our Pedestal Mount tachs have made them a race proven favorite for over 30 years. These tachs offer a variety of performance oriented options from shift lights to memory recall functions, coupled with a trade marked aluminum and rubber shock strap design for the best vibration protection available.
    Types Available:
    - Phantom II Series Tachometer w/ External Shift-lite 10,000 RPM Size 5in (White)
    - Sport-Comp II Series Tachometer w/ External Shift-lite 10,000 RPM Size 5in (Black)
    - Sport-Comp II Series Pedestal Mount Mini-Monster Tachometer 10,000 RPM Size 3.75in (Black)
    - Ultra-Lite II Series Pedestal Mount Mini-Monster Tachometer 10,000 RPM Size 3.75in (White)
    PIVOT RACING PRODUCTS
    GEKKO TACHOMETER with Shiftlamp
    Black Face - 80mm
    Ultra Quick Response and High Precision.
    By using a high tech microcomputer to run the high class stepping motor, the same kind as used in F1 and WRC, we are able to bring you a quick response, no hesitation needle coupled with an equally high precision digital display.
    No G-force Influence means added Stability.
    Most electronic meters are designed with cross coil movement, which are apt to produce display mistakes when G-forces cause friction upon the shaft. But, with our stepping motor design we are able bring you a highly stable and more accurate meter not under the influence of G-forces.
    REV LAMP X and Z
    Features:
    - Shift lamp lights up when the set rpm is reached.
    - Ultra bright LED is easy to see even in full daylight.
    - For night driving select auto low lighting or synchronize with parking lights.
    - High quality aluminum machined body with swivel neck.
    - Shift lamp settings can be made in units of 100 rpm.
    - Compact design needs no space.
    Rev Lamp-X
    - Type X - The High-class Aluminium Cutout Lamps
    - Controller features tachometer measuring up to 9900RPM
    - No Wiring is necessary for some Toyota and Daihatsu vehicles, simply connect to vehicle diagnostic port OBD2
    - Easy installation for other vehicles direct to the ECU
    - Features two modes: Sports Driving and ECO Driving
    - Set RPM limit for Sports Driving mode shift warning lamp
    - Separately set ECO Driving Mode RPM warning at lower RPM to encourage economical driving
    Rev Lamp-Z
    - Type Z - Sequential RPM Alert Lamp System
    - F1 style sequential Light up starting 1,000RPM before shift point
    untuk pemesanan/pembelian, kontak : 0815 1330 1978 - coki siboro
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    new stock coming in....
    CP : Coki Siboro
    up dulu ya suhu siapa tau butuh
    UPDATED...!!
    CP : Coki Siboro
Venom 300x250 GT Radial
  1. Part2 2nd........(TB 3SGTE,gauge meter EVO,etc....)NO MENIPU....
    By RETROtuning in forum Jual Beli Mesin Lainnya
    Last Post: 27th September 2010, 17:36
  2. WTS CARBON HOOD GD3 + DEFI RACE GAUGE
    By SIMOTA in forum Bursa Eksterior Lainnya
    Last Post: 25th October 2009, 23:03
  3. WTA:pivot gauges meter
    By bethefastest89v in forum Diskusi Mesin
    Last Post: 2nd July 2009, 22:43
  4. WTA/WTB:pivot gauges meter
    By bethefastest89v in forum Gauges
    Last Post: 28th June 2009, 20:16
  5. WTB PIVOT RACING MONITOR METER--PICT
    By civic96 in forum Jual Beli Mesin Lainnya
    Last Post: 9th June 2009, 16:39
