SPEEDZ PERFORMANCE RACING SUPPLIEST N STOCKIEST FOR PASSWORD AP ALUMUNIUM RADIATOR - Page 7
Page 7 of 7 FirstFirst ... 34567
Results 61 to 67 of 67
  • Short URL:  http://modifika.si/496036
    Represented Member
    cipondoh-tangerang
    5 Mths 3 Wks 13 Hrs 41 Secs
    SPEEDZ PERFORMANCE bring in ready stock AP RACING World RADI-CAL Caliper with new design disc brake J-Hook Floating.
    CP 8520 Radi-Cal caliper 6 pot,AP discbrake floating slotted , AP brake pad APF 404, Brake hose.
    Option use J-Hook disc brake floating
    **AP discbrake 370mm (velg minimal 18 inch)floating J-Hook harga 47 jt
    **AP discbrake 380mm (velg minimal 19 inch)floating J-Hook harga 48 jt
    **AP discbrake 390mm(velg minimal 20 inch)floating J-Hook harga 49 jt.
    **AP discbrake 410mm(velg diats 20 inch) floating J-Hook harga 50.5 jt.
    CP8530 Radi-Cal caliper 4 pot,AP discbrake floating slotted ,AP brake pad APF404, Brake hose .
    **AP discbrake 360 mm(velg minimal 18 inch) floating J-Hook harga 42 jt.
    **AP discbrake 380 mm(velg minimal 19 inch) floating J-Hook harga 44 jt.
    **AP discbrake 400 mm(velg diatas 20 inch) floating J-Hook harga 45.5 jt.
    dan utk pembelian depan belakang ada extra potongan 3 jt
    For Order Call/Whatsapp:
    081382077777 (HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    Central Distributor Parts, Racing Supplies & Modification
    Green Lake City Ruko CBD Blok L no 7
    Cipondoh-Tangerang.
    SPEED'Z PERFORMANCE by Hans SpeedZ ,Starts from 1999 with Experience and Specialized in Distribution High End Performance Engine Racing Parts & High End Brake System to Providing the Best brake system .It is for Supply With the Effort of Strong Team, Excellent Sales,Has been successfully make Pre-Sales and After-Sales Value-Added Services to our Business Partners at SpeedZ Performance,Green Lake City Ruko CBD Blok L no:7 Cipondoh-Tangerang.Mobile No/Whatsapp: 081382077777 (Hans SpeedZ)
  2. #62
    Represented Member
    cipondoh-tangerang
    081382077777-085882077777(HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    Cipondoh-Tangerang.
  3. #63
    Represented Member
    cipondoh-tangerang
    SPEED'Z PERFORMANCE ,GREEN LAKE CITY RUKO CBD BLOK L NO 7,CIPONDOH-TANGERANG contact 081382077777-082312077777(HANZ SPEEDZ)
  4. #64
    Represented Member
    cipondoh-tangerang
    SPEEDZ PERFORMANCE Authroized for supply AP RACING world leader stock in huge quantity for stockiest so make the Stock in very good price.
    we always develop for the update AP Racing stock start from 15 inch wheels to 22 inch using World-Radical
    and for Brembo Grand tourismo start from wheels 17inch to 21 inch.
    we supply for INDONESIA Exclusive market, and many installation in customer car & dealer wanted for area not in Jakarta.
    Please come and see Stock and many application before buy and all is in stock.
    AP RACING MADE IN UNITED KINGDOM
    -CP7600 caliper 4 pot ,AP disbrake 285mm floating slotted ,AP brake pad APF 404,HEL Brake hose harga 22.5 jt (black caliper) dan harga 24 jt (red caliper ) applikasi utk velg 15-16 inch.
    -CP 5200 caliper 4 pot , AP discbrake floating slotted 330mm, AP brake pad APF 404, HEL brake hose dengan harga 27 jt (black caliper) dan 29 jt (red caliper) applikasi utk velg 17 inch.
    -CP 5040 race caliper 4 pot pro5000+, AP discbrake floating slotted 330mm, AP brake pad APF 402, HEL brake hose harga 34 jt. (applikasi utk velg 17 inch).
    -CP 9040 caliper 6 pot , AP disbrake 355mm floating slotted , AP brake pad APF 404, HEL brake hose harga 34 jt (black caliper) dan 35 jt( red caliper) applikasi utk velg 18inch
    *dengan discbrake floating slotted 362mm harga 37 jt.(applikasi utk velg 19 inch).
    -CP 5060 race caliper 6 pot pro5000+, AP disbrake 355mm floating slotted , AP brake pad APF 402, HEL brake hose harga 42 jt. (applikasi utk velg 18inch)
    *dengan discbrake floating slotted 362mm harga 44 jt.(applikasi utk velg 19 inch).
    NEW and ready stock AP RACING World RADI-CAL Caliper new design futuristic and with new model Floating J-Hook design .
    -CP 8520 caliper 6 pot,AP floating J-hook , AP brake pad APF 404, Brake hose.
    **AP discbrake floating J-hook 370mm (velg minimal 18 inch) harga 45 jt
    **AP discbrake floating J-hook floating 380mm (velg minimal 19 inch)harga 47 jt
    **AP discbrake floating J-hook 390mm(velg minimal 20 inch) harga 49 jt.
    **AP discbrake floating J-hook 410mm (velg minimal 21-22inch)harga 52 jt.
    CP8530 caliper 4 pot,AP discbrake floating slotted ,AP brake pad APF404, Brake hose .
    **AP discbrake Floating J-hook 360 mm(velg minimal 19 inch)harga 42 jt.
    **AP discbrake floating J-hook 380 mm(velg minimal 20 inch) harga 43,5 jt.
    BREMBO Made in ITALY
    Brembo GT 4 pot,brembo brake pad, alumunium brake hose with center bell plug & play alumunium and adaptor.
    *Dengan discbrake floating drilled 330mm harga 34 Jt. (velg minimal 17 inch)
    *Dengan floating drilled discbrake 345mm harga 36 Jt.
    *Dengan floating drilled discbrake 355mm harga 37 Jt.(velg minimal 18 inch)
    *Dengan floating drilled discbrake 380mm harga 39 Jt.(velg minimal 19 inch).
    -BREMBO GT 6 pot,brembo brake pad GT,Brake hose with center bell plug n play alumunium dan adaptor.
    **Dengan discbrake floating drilled 355mm(buat velg minimal 18 inch) harga 46 Jt.
    **Dengan Discbarake Floating Drillet 380mm(Buat Velg Minimal 19 INCH ) Harga 48 Jt.
    **Dengan Discbrake Floating Drilled 405Mm(Buat Velg Minimal 20 Inch) Harga 50 Jt.
    New and just coming in stock
    -BREMBO GT 8 pot.brembo brake pad .duralium center bell and adaptor plug and play of specific car
    **Dengan Discbarake Floating Drillet 380 MM(Buat Velg Minimal 20 inch ) Harga 50 Jt.
    **Dengan Discbrake Floating Drilled 405Mm(Buat Velg Minimal 21-22 Inch) Harga 52 Jt.
    dapetkan potongan setiap pembelianbig brake kit depan + belakang dapetkan potongan harga 3 jt (extra pemotongan for customer).
    081382077777-082312077777 (HANZ SPEEDZ)
    SPEEDZ PERFORMANCE
    Cipondoh-Tangerang 11750
  5. #65
    Represented Member
    cipondoh-tangerang
    PEED'Z PERFORMANCE by STZ ,It has over 17 years’ experience and specialized in distribution high end performance engine racing parts, bring high end brake system to providing the best brake system to consumers.It is for supply With the effort of SPEED’Z strong team, excellent sales , SPEED:Z has been successfully make pre-sales and after-sales value-added services to our business partners.for call/whatsapp 081382077777-082312077777(Hans SPEED'Z PERFORMANCE)
  6. #66
    Represented Member
    cipondoh-tangerang
    Update price BBK oktober
    -CP7600 caliper 4 pot ,AP disbrake floating slotted ,AP brake pad APF 404,HEL Brake hose,Cnter hub +adaptor.
    *dengan discbrake 285mm(min velg 15 inch) harga 24 jt
    *dengan discbrake 295mm(min velg 16 inch) harga 25.5 jt
    -CP 5200 caliper 4 pot , AP discbrake floating slotted, AP brake pad APF 404, HEL brake hose ,Center hub +adaptor.
    *dengan discbrake 330mm(min 17 inch) harga 29 jt.
    -CP9200 caliper 4 pot (new model caliper), AP discbrake floating slotted, AP brake pad APF 404, HEL brake hose ,Center hub +adaptor.
    *dengan discbrake 330mm(min 17 inch) harga 30 jt.
    -CP 5040 race caliper 4 pot pro5000+, AP discbrake floating slotted, AP brake pad APF 402, HEL brake hose ,Center hub +adaptor.
    *dengan discbrake 330mm(min17 inch) harga 36 jt.
    -CP 9040 caliper 6 pot , AP disbrake floating slotted , AP brake pad APF 404, HEL brake hose ,Center hub +adaptor.
    *dengan discbrake 355mm(min velg 18 inch) harga 36jt.
    *dengan discbrake 362mm(min velg 18-19 inch) harga 38 jt.
    -CP 5060 race caliper 6 pot pro5000+, AP disbrake floating slotted , AP brake pad APF 402, HEL brake ,Center hub+adptor.
    *dengan discbrake 355mm (velg min 18 inch) harga 43jt.
    *dengan discbrake 362mm (velg min 18-19 inch)harga 45 jt.
    ** AP discbrake floating Curved Groove 370mm (velg minimal 18 inch) harga 47 jt
    **AP discbrake floating J-hook 370mm (velg minimal 18 inch) harga 47 jt
    **AP discbrake floating J-hook floating 380mm (velg minimal 19 inch)harga 48 jt
    *Dengan discbrake floating drilled 330mm harga 36 Jt. (velg minimal 17 inch)
    *Dengan floating drilled discbrake 345mm harga 38 Jt.
    *Dengan floating drilled discbrake 380mm harga 42 Jt.(velg minimal 19 inch).
    **Dengan discbrake floating drilled 355mm(buat velg minimal 18 inch) harga 48 Jt.
    **Dengan Discbarake Floating Drillet 380mm(Buat Velg Minimal 19 INCH ) Harga 50 Jt.
    **Dengan Discbrake Floating Drilled 405Mm(Buat Velg Minimal 20 Inch) Harga 52 Jt.
    SPEEDZ PERFORMANCE
  7. #67
    Represented Member
    cipondoh-tangerang
    SPEEDZ PERFORMANCE
    www.speedzperformance.com
MBtech Venom 300x250
  1. Replies: 1
    Last Post: 14th April 2015, 10:46
  2. Replies: 1
    Last Post: 23rd February 2014, 07:04
  3. BARU SPEEDZ PERFORMANCE RACING SUPPLIEST N STOCKIEST FOR TURBO
    By [speed'Z] in forum Turbo & Parts
    Last Post: 17th December 2013, 14:38
  4. BARU SPEEDZ PERFORMANCE RACING SUPPLIEST N STOCKIEST FOR BIG BRAKE KIT BREMBO
    By [speed'Z] in forum Bursa Kaki Lainnya
    Last Post: 16th December 2013, 13:02
  5. SPEEDZ PERFORMANCE RACING SUPPLIEST N STOCKIEST FOR PERFORMANCE PARTS
    By [speed'Z] in forum Jasa (Tunning, Service Engine, etc)
    Last Post: 16th December 2013, 12:58
