genio 92.. ganti dr matic ke manual
Results 1 to 10 of 12
  • Short URL:  http://modifika.si/4933
    hastabungbung
    bantuin donk..
    perlu ganti apa aja ya?.. perlu apa aja deh sekalian trmasuk apa yg perlu dikerjain n dicek2 ?..
    biasanya total2 kira2 abis berapa ya?
    ada yg jual barang2nya dimana ya?
    thank you
    eNZed
    8 Hrs 56 Mins 27 Secs
    well.... donornya apa dulu? kalo donornya gearbox manual dari yg sama2 genio, ga bgitu major kok. laen lagi ceritanya kl mo ganti mesin, misalnya ke dohc.
    anyway, yg elo perlu:
    - manual gearbox assembly with clutch and its fork. (check whether u still can use ur 'old' driveshaft)
    - manual pedal-set
    - manual gear-selector (with gear linkages)
    - clutch master and slave cyl. (if the 'new' clutch is hydro)
    what u may need to do:
    - gear selector position assembly (lobang di lantainya auto beda posisi dgn yg manual)
    - new manual pedal-set assembly (new hole for the master cyl. push rod)
    what u may need to think:
    - ECU for manual gearboxed motor (if it has D16Y motor).
    do i missing anything??? im not 100% sure. but CMIIW
    Sebelah tetangga
    9 Hrs 37 Secs
    nah tuh ...
    emang nape bos diganti ?
    0817756556 (back !) - 021 30863062 (damn fuckin hp) -
    ikan asin ikan tongkol
    orang miskin cuma bisa misscall
    ikan lele gede di ember
    cuma orang jelek yang pake private number
    http://www.geocities.com/bantulmerana_2006/katalog1.gif
    Sebelah tetangga
    9 Hrs 37 Secs
    oh ya ecu gak kepikiran gue ya tadi .. hehehhe
    lemme guess, jedak jeduk ya di kalo pindahan transmisi ? terutama di 1 ke 2 ke 3 ?
    hastabungbung
    iyee.. bener jedakjeduk.. apa gw pernah cerita jon? hehehe... lagian dr dulu juga dah pengen ganti manual, di blppn jalannya bukit2 kasian maticnya..
    hastabungbung
    any recommended place to get those items,... and price rangenya juga sekalian kali ya..
    tengkyu.
    6 Hrs 11 Mins 41 Secs
    REV Engineering, Jl. Panjang No. 70, Teddy, 0812 1055 146.
    Genio, Original engine : Matic, Swap to B18 C, 14 s.
    Aerio_Standard
    eNZed
    diganti krn otaknya beda. biasanya cam buat auto lebih 'lunak' drpd yg manual (terutama yg dohc). bisa2 aja sih pake stock ecu, but it will be better if u top it off with manual ecu. kl mau lebih geboy lagi, ganti camshaft manual, ato malah ganti mesin sekalian. hehehehe.
    jedak jeduk wkt lg up-shift itu hentakan dr gearbox-nya. bukan dr mesin.
    sumbagteng
    wdh kerjaan susah tuh bos,...
    58 Mins 45 Secs
    waduh sayang boss, mending ganti mobil yg manual aja
    mobilku std
    Jual Tanah bantu sodara nih, dicek ayo dicek
    http://www.modifikasi.com/forum/viewtopic.php?p=691475#691475
GT Radial NGK Busi
  1. Replies: 23
    Last Post: 4th September 2012, 11:23
  2. Replies: 0
    Last Post: 1st September 2012, 02:19
  3. [ASK] Ganti Persneling Dari Manual Ke Matic
    By coal_nete in forum Diskusi Mesin
    Last Post: 1st July 2009, 19:44
  4. ganti transmisi hyundai accent dari manual ke matic
    By putu prasaba in forum Diskusi Mesin
    Last Post: 23rd April 2009, 01:57
