permisi, saya mau Jual power kicker kx400.1
kondisi, normal
siap pakai
berikut gambarnya..!
200 watts RMS x 1 at 4 ohms
400 watts RMS x 1 at 2 ohms
Signal to Noise Ratio: 95dB
Input Voltage: 13.8V
variable 50-200 Hz low-pass crossover, 12 dB per octave
25 Hz subsonic filter, 12 dB per octave
efficient Class D amp design
0-18 dB KickBass bass boost at 40 Hz
amp can be strapped to another KX400.1 to power one 4-ohm subwoofer (800 watts total power)
dash-mountable remote bass level control
speaker- and preamp-level inputs
preamp outputs
frequency response 20-200 Hz
4-way protection circuits
requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
12-13/16"W x 2-5/8"H x 10-1/4"D (including removable shroud); 10-1/16"W x 2-5/16"H x 9-9/16"D (without shroud)
Authorized Internet Dealer
1-year Manufacturer's warranty
Power Specifications - Full Range Channels
RMS Power @ 4 ohms
200 watts x 1 channels
RMS Power @ 2 ohms
400 watts x 1 channels
RMS Power @ 1 ohm
Not Stable
Bridged RMS Power
Not Bridgeable
Peak Power Output
800 watts
Amplifier Specifications
Number of Channels
1 - Mono
Total RMS Power Output
400 watts
Minimum Impedance Unbridged
2 ohms
Minimum Impedance Bridged
Not Bridgeable
THD at Rated RMS Power
1.5%
Speaker Level Inputs
Yes
Preamp Outputs
1 pair
Built-in Crossover
Low-pass (LP)
High-pass (HP)
High-Pass Crossover Frequency
50 - 200 Hz
Low-Pass Crossover Frequency
50 - 200 Hz
Signal-to-Noise Ratio
95 dB
Bass Boost
0 - 18 dB
Fan Cooled
No
Fuse Rating
40A
minat
pin bb : 20EDE91D
call,sms,whatsapp: 085310141411
