Baru Power audison Lrx 4.1 new harga second
Results 1 to 5 of 5
  • Short URL:  http://modifika.si/492351
    1 Mth 2 Wks 16 Hrs 28 Mins 21 Secs
    Power Supply
    Power supply voltage: 11 ÷ 15 VDC
    Idling current: 1.8 A
    Idling current when off: 0.02 mA
    Consumption @ 14.4 VDC (Max Musical Power): 95 A
    Amplifier stage
    Distorsion - THD (1kHz @ 4Ω): 0.04%
    Bandwidth (-3dB): 4 ÷ 80 kHz
    S/N Ratio(A weighted @1 V): 100 dB
    Damping factor (1kHz @ 4Ω): 120
    Input sensitivity: 0.3 ÷ 5 VRMS
    Input impedance: 15kΩ
    Speaker-In sensitivity: 1.4 ÷ 24VRMS
    Speaker-In impedance: 5kΩ
    Load impedance: 4 ÷ 1 Ω
    Nominal output power (RMS)
    NP @ 12VDC, THD 0.3%: 125W x 2 + 135W x 2 (4 Ω)
    Output power (RMS) @14.4 VDC, THD 1%:
    4 Ch 130W x 2 (4Ω) + 140W x 2 (4Ω)
    4 Ch 230W x 2 (2Ω) + 250W x 2 (2Ω)
    4 Ch 130W x 2 (4Ω) + 250W x 2 (2Ω)
    4 Ch 130W x 2 (4Ω) + 400W x 2 (1Ω)
    4 Ch 200W x 2 (4Ω) + 350W x 2 (1Ω)
    3 Ch 130W x 2 (4Ω) + 500W x 1 (4Ω)
    3 Ch 130W x 2 (4Ω) + 800W x 1 (2Ω)
    3 Ch 230W x 2 (2Ω) + 500W x 1 (4Ω)
    3 Ch 200W x 2 (2Ω) + 700W x 1 (2Ω)
    Other functions
    Remote In: 7÷15 VDC - 1 mA
    Remote Out: 12 VDC - 50 mA
    Speaker On: Amp ON with amplified signal
    Fuse (AFS): 100 A
    Remote sub volume: Active with B ch. Lo-pass 24dB L+R
    Adjustment: +5 ÷ -5dB
    Filters
    Input Bypass/Hi-pass 50÷5kHz @ 12 dB/Oct.
    Output Bypass/Hi-pass/Lo-pass 50÷5kHz @ 12/24 (mono) dB/Oct.
    Subsonic OFF/20/30 Hz @ 24 dB/Oct.
    Active with B ch. @ 24 L+R
    -mulus abis
    -dus,buku,kartu garansi lengkap
    Hub 0811880333
    Hub 0811880333 and pin bb baru 2aa52a1c,thanks
    1.Kondisi barang Normal dan gak ada masalah
    2.Lokasi barang di Jakarta selatan (Pakubuwono Area) Bisa test di tempat
    Untuk di luar kota bisa dikirim via JNE or MEX
    3.Untuk informasi Bisa call/whatsapp 0811880333 or pin bb 2ADBDE45
    4.Terima kasih Modcom
    4 Days 12 Hrs 8 Mins 5 Secs
    boleh dibisikin gan brp duit,cmn ga bs pake sub ya kalo 4 chanel? tq
    sdh sold thanks
    dapat 1 buah lagi.......kondisi istimewa juga......
  1. WTS power audison lrx 4.5
    By EterNa in forum Power Amplifier
    Last Post: 14th July 2010, 09:51
  2. SOLD, Jual Power Audison LRx 1.1K Mulus
    By Nirwanaero in forum Power Amplifier
    Last Post: 6th July 2010, 22:42
  3. 4sale power audison lrx series....
    By rudytan in forum Power Amplifier
    Last Post: 29th October 2009, 11:27
  4. WTS : Power Audison LRX 4.300
    By budek in forum Power Amplifier
    Last Post: 7th September 2009, 13:50
