HARGA RP 1050000
GARANSI DARI SAYA (1TH) TERMASUK PART
BELUM TERMASUK ONGKOS KIRIM
KONDISI BARANG ORIGINAL
MADE IN USA
SPESIFIKASI:
RMS Output:
4ohms Stereo: 50 W per channel
2ohms Stereo: 100 W per channel
1ohm Stereo: 200 W per channel
4ohms Mono: 200 W
2ohms Stereo: 400 W
Total Harmonic Distortion (THD): 0.02%
Frequency Response (+/- 1dB): 15-40kHz
Signal to Noise Ratio: 102dB A weighted
Slew Rate: 15V/us
Damping Factor @ 100Hz 4ohm load: >500
Damping Factor @ 100Hz 2ohm load: >250
Stereo Separation: 72dB
Input Sensitivity: 100mv - 2V
Input Impedance: 10k Ohms
Supply Voltage: 10.5-16V
Fuse Rating: 30 Amp
Shipping Weight: 12 Pounds
Dimensions: 14" L x 8.5" W x 2.3" H
GARANSI DARI SAYA 1 TH TERMASUK PART
KETERANGAN MENGENAI GARANSI PERSONAL
1.APABILA BARANG YG DIBELI RUSAK DALAM MASA GARANSI SELURUH BIAYA KERUSAKAN
TANGGUNGAN SAYA,KALAU BISA DATANG LANGSUNG KE TOKO SAAT ITU JUGA LANGSUNG SAYA BENAHI.
KALAU KERUSAKAN PARAH MAXIMAL 3 HARI SELESAI
2.APABILA DILUAR KOTA,ONGKOS KIRIM BOLAK BALEK DITANGGUNG PEMBELI
3.APABILA BARANG YG RUSAK TIDAK BISA DIPERBAIKI,SAYA TUKAR DENGAN BARANG YG SAMA APABILA BARANG YG SAMA TIDAK ADA .BISA DITUKAR DENGAN BARANG YG NILAINYA SAMA.
4.GARANSI PERSONAL BATAL APABILA DALAM MASA GARANSI TERJADI KERUSAKAN .DAN BARANG DISERVISKAN KE ORANG LAIN.
KALAU DATANG LANGSUNG KE TOKO PASANG GRATIS
HUB :085-234-900-099
:081-333-106-646
HANYA HUBUNGI NO TELPON INI ,SELAIN NO TELP INI BERATI PENIPU
Rek BNI : 3112201609
a/n : SUNARTO
Rek BRI : 0344-01-000074-56-0
a/n : SUNARTO
Rek BCA : 4390295915
a/n : DJANAH KARWIYAH
Rek MANDIRI : 144-00-9080706-3
An/ :SUNARTO
TOKO: PRO AUDIO:jl RAYA SAWOJAJAR NO:13 MALANG JAWATIMUR
DARI PEREMPATAN SULFAT PALING TIMUR BELOK KANAN JARAK 200M
DEPAN APOTEK SAWOJAJAR MAS
RUMAH : JL KRESNO: 14 & 39 RT10/RW 01 /KEL POLEHAN /KEC BLIMBING / KODYA MALANG /JAWA TIMUR
email:paksunarto_proaudio@yahoo.com
DAN INI SEKEDAR BUKTI no RESI BARANG YG SUDAH TERKIRIM (bisa dicek di JNE TRACE & TRACKING)
1.RESI - 1958717460008 KE.SURABAYA
2.RESI – 1958705780002 KE.PALANGKARAYA
3.RESI - 1926174940005 KE.KOTABARU.PULAU LAUT
4.RESI – 1926077140007 KE.PT MADHANI.BALIKPAPAN
5.RESI – 1958723540008 KE.KELAPA LIMA. KUPANG
6.RESI – 1958705770003 KE.BEKASI
7.RESI – 2026885520004 KE.SEMARANG UTARA .SEMARANG
8.RESI – 1992429060002 KE.SAMARINDA
9.RESI – 1935705260000 KE.BANGSALSARI.JEMBER
10.RESI – 1903137570004 KE.DENPASAR
11.RESI – 2011720370005 KE.KEDATON,BANDARLAMPUNG
12.RESI – 2026816890008 KE.MAKASAR
13.RESI – 2026816880009 KE.CILAKU,CIANJUR
14.RESI – 2011658440009 KE.BANGUNTAPAN,BANTUL
15.RESI – 2007014110006 KE.SAMPIT
16. RESI – 1992243870009 KE BANJARMASIN TIMUR
17.RESI – 1916293660007 KE TANJUNG PINANG (KANTOR BAPEDA .KAB.BINTAN)
18.RESI – MXGAA00030726212 KE.TANJUNG BALAI KARIMUN
19.RESI – MXGAA00026096012 KE. JAMBI
20. RESI – MXGAA00166633612 KE.MATARAM
22.RESI – MXGAA00215306312 KE. BONTANG
23.RESI - MXGAA00275145112 KE .PROBOLINGGO
24.RESI –MXGAA00278941012 KE. SLEMAN KAB SLEMAN
25.RESI – MXGAA00279741512. KE. CIKARANG. KAB.BEKASI
26.RESI – MXGAA00290195212.KE.DENPASAR.BALI
27.RESI – MXGAA00300884012.KE.JAKARTA BARAT
28.RESI – MXGAA00377802112. KE.YOGYAKARTA
29.RESI – MXGAA00024934212.KE.MEDAN PETISAN,MEDAN
30.RESI – MXGAA00430863413 . KE.MAKASAR
KALAU BUKTI NO RESI INI MASIH KURANG ,BISA MINTA NO RESI YG LAIN LEWAT SMS.
