Bekas Helix B2 Precision (3 Unit)
Results 1 to 8 of 8
  • Short URL:  http://modifika.si/491427
    3 Days 1 Hr 1 Min 7 Secs
    Cool Helix B2 Precision (2 unit)
    DIJUAL SATU PAKET!!
    B2 Precision 2 Channel (2Unit) , main SQ atau SQL ...
    Harga Special : 3jt (nego)
    Kualitas Bagus!! Masih Segel Belum Pernah di Service 100%
    Spesifikasi :
    The Helix B2 is a powerful, dynamic top-of-the-class amplifier that is controlled by its own integrated software. This integrated managing software (IMS) makes the read-out of all relevant data possible. Therefore the amplifier provides optimized working in terms of power, current and temperature. The music signal is of course analog processed to reach the best sound and dynamic results. The sophisticated active crossover allows a perfect adjustment of all connected speakers and subwoofers.
    The B2 has an integrated temperature controlled cooling fan that can be switched off if desired. The turn-on temperature as well as the maximum power of the cooling fan can be adjusted by two separate controls. The connection of an external fan is possible.
    -Cont. power rating RMS / Musik an 2 x 4Ohm at 12 Volt: 2 x 80 Watt
    -Cont. power rating RMS / Musik at 2 x 4Ohm an 13,8 Volt: 2 x 100/165 Watt
    -Cont. power rating RMS / Musik at 2 x 2Ohm at 13,8 Volt: 2 x 180/300 Watt
    -Cont. power rating RMS/Musik 1 x 4 Ohm: 1 x 360/600 Watt
    -Adjust Highpass/Lowpass/Bandpass: 15 Hz - 3kHz
    -Total harmonic distortion (TDH): < 0,014%
    -Signal to noise ratio: > 96 dB
    -Damping factor: > 450
    -Frequency range: 20 Hz -20 kHz +/- 0,5 dB
    -TIM Distortion: < 0,02%
    -Input sensitivity: 500 mV - 8 V
    -Fuse: 2 x 20 A
    -Input impedance: 10 kOhm
    -Dimensions (H/W/D) in mm: 35 x 240 x 300
    -Weight net: 3,1 kg
    -Driver with class A technology
    -Outputstage with 16 MosFet transistors
    -RMI (realmixed input) for forming an optimised mono-summation signal from the left and right channels
    -NFI (noisefree input) for distortion-free listening L
    -Intelligent active crossover
    -Mono/Bridged/ Stereo switch
    -8.0 volt input for connection to any signal source
    -ADC - Anti Distortion Choke to eliminate distortions
    -Intelligent power supply
    -Separate speaker protection circuit with current limitation for speaker short-circuiting, cable contact with car chassis, low impedance and wrong connection
    -CPS - Color Protection System
    -SMD - Surface Mounting Devices for constant assembling quality
    -Double-sided, copper plated pc-board for best power and signal transmission and protection against vibrations
    -24-karat gold-plated solid connectors
    -Temperature-optimised heatsink for highest efficiency
    -1% accurate components for perfect audiophile sound quality and maximum power
    -Smoked-grey plexi cover with both side printing
    B2Precision - Helix 2 Ch High-End Amplifier
    COD wilayah Jakarta. Luar Jakarta kirim melalui TIKI/JNE
    Info detail silahkan. . .
    PM/SMS : 081298782888-Tonny
    pin BB : 2AEFE76B
    JKT BDG MDN
    2 Mths 1 Wk 4 Days 13 Hrs 20 Mins 7 Secs
    Jual satuan gak om?
    kaga bos. duanya mau dikemanain
    JKT BDG MDN
    Mana tau om, btw saya yang kemaren sms om 081191xxxx.. saya masih nunggu nih kalau bisa satuan..wkwkwkwk..bantu up deh..
    up
    upppppupppp
    upppppppppp
    upppppppppp
    uppppppppppppppp
    upppppppppppppppp
    upppppppppppp upppppp upppppppppp
    uppp uppp uppp uppp upppp
    uppppppppppppppppp
  1. Replies: 3
    Last Post: 28th June 2013, 21:38
  2. dyn audio,helix 500q,precision,phoenik gold dll dll
    By halim_adi in forum Head Unit & Processor
    Last Post: 10th September 2010, 10:02
  3. dyn audio,helix 500q,precision,phoenik gold dll dll
    By halim_adi in forum Power Amplifier
    Last Post: 9th July 2010, 23:14
  4. Replies: 29
    Last Post: 28th February 2010, 17:54
  5. WTS : Helix B4 Precision
    By klaviermaschine in forum Speaker - SubWoofer
    Last Post: 19th January 2010, 21:20
