Bekas jual POWER DLS CA41
  • Short URL:  http://modifika.si/491293
    1 Wk 1 Day 20 Hrs 19 Mins 7 Secs
    jual POWER DLS CA41
    Permisi jual POWER DLS CA41
    Kondisi normal , mulussss siap pakai
    berikut penampakannya ..
    Performance Series 4-Channel Class A/B Car Amplifier
    RMS Power Rating (13.8V):
    4 ohms: 70 watts x 4 chan.
    2 ohms: 125 watts x 4 chan.
    Bridged, 4 ohms: 200 watts x 2 chan.
    Pulse Width Modulated MOSFET power supply
    LED power (green) and protect (red) indicators
    Soft Start Turn-on
    4/3/2 channel operation
    Speaker-level inputs with signal sensing for automatic turn-on
    3-Way System Protection circuitry (thermal, overload, and speaker short protection)
    Preamp RCA outputs to daisy chain multiple amps
    Heavy duty aluminum alloy heatsink sink for extreme heat dissipation
    Gold-plated RCA level inputs
    Gold-plated screw terminals
    Input sensitivity:
    Low level: 250mV-5V
    Variable high-pass filter (50-500 Hz, 150-5,000 [x10])
    Variable low-pass filter (50-500 Hz, 500-5,000 [x10])
    Fixed subsonic filter (25 Hz)
    Damping factor: >100
    Frequency response: 10-35,000 Hz
    Dimensions: 14-5/8"L x 2-15/16"W x 10-9/16"H
    4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
    minat
    pin bb : 20EDE91D
    call/sms/whatsApp : 085310141411
  1. FS : Power DLS CA41 kondisi bagus
    By David669 in forum Power Amplifier
    Last Post: 4th June 2013, 14:02
  2. Replies: 1
    Last Post: 14th March 2012, 18:48
  3. jual power DLS A5 dan bbrp barang lainnya
    By ricemodeon in forum Power Amplifier
    Last Post: 10th August 2010, 17:25
  4. Jual Power DLS
    By KingPitikz in forum Diskusi Power Amplifier
    Last Post: 3rd May 2009, 20:58
  5. Jual Power DLS !!
    By KingPitikz in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 1st May 2009, 15:21
