Bekas WTS: 2 AMPLI GENESIS DUAL MONO CLASS A LTD ED. No. 91 & 114 (ONLY 250 IN THE WORLD!)
Results 1 to 10 of 23
  • Short URL:  http://modifika.si/484347
    Joglosemar (Jogja Solo Semarang)
    4 Days 10 Hrs 54 Mins 44 Secs
    Jual Power Langka Hanya ada 250 pcs di dunia,
    GENESIS DUAL MONO CLASS A LIMITED EDITION No. 91 dan 114
    Spek badboy buat SQ ini bisa cek di google,
    Komplit box kayu dan sertifikat dari AudioPlus.
    Mulus, Normal bisa dilihat di foto2, cuma pernah dipakai lomba tidak sampai 1 bulan habis itu masuk lemari lagi, belum pernah service.
    Harga Paket 2 biji 23jt
    Contact: Call/SMS/WA 081-2271-2121 / 0838-6599-5552
    Jogja, Solo, Semarang bisa langsung saya COD, selain itu bisa dikirim via JNE/TIKI/Kesepakatan
    foto-foto asli:
    Thanks.
    Spesifikasi Lengkap:
    Long considered the ultimate configuration for superb audio performance, true class A amplification has been passed over by the automotive world due to cost and current consumption. Cleverly integrating Class A and Class G technology, Genesis has managed to produce a ground breaking product which operates in true class A mode up to 20 Watts per channel at 4 Ohms then seamlessly switches to class G for high power requirements – up to 150 Watts per channel. As a result, idling current is kept below 15 Amps.
    Dual power supplies and a dual mono architecture ensure excellent staging. Separate gain controls for each channel as well as variable low pass and high pass filters allow maximum application flexibility. The filters can be switched out for “straight line” use.
    Two internal fans maintain optimum temperature levels and are supplemented by a temperature dependent cooling fan output, allowing system designers to add cooling to suit specific mounting conditions.
    Genesis will hand produce just 250 individually numbered units in its factory in Essex, England.
    Burr-Brown and Analog Devices preamps and filter IC's are used. Sanken output transistors for exceptionally warm, detailed and musical sound quality. Also fitted with a temperature dependent fan output providing flexibility in cooling options, and two inbuilt fans control the case temperature at an optimum level.
    A limited production of 250 amplifiers will be made world wide, all individually numbered.
    Brief Specifications:
    Rated Power: 4ohm 2 x 20 WRMS
    Class A mode: 2ohm 2 x 10 W RMS
    Typical Power: 4ohm 2 x 26 WRMS
    Class A Mode: 2ohm 2 x 13 W RMS
    Typical Power: 4ohm 2 x 150 WRMS
    Class G Mode: 2 ohm 2 x 250 W RMS
    S/N : > 115dB A Wtd Ref full output
    Input : 0.3 - 4.0 Volts RMS
    Crossovers: High pass <20 Hz - 200Hz Fully variable
    Low-pass, 50 Hz - 200Hz Fully variable
    Filter slope: 12dB / octave ( 2nd order butterworth )
    Fuse: 4 x 20 Amps
    Size: 450 x 210 x 62
    Origin: Designed and hand-built in the Genesis factory in Essex, England.
    selamat siang, up dulu.........
    selamat malam, up dulu.........
    1 Mth 4 Wks 10 Hrs 39 Mins 5 Secs
    Ampli bagus nih bantu up aja
    thanks bro hokie....
    Up dulu.....................
    selamat pagi, up dulu........................
    up sore.................
    up...............................
Mega Glodok Kemayoran MBtech
  1. Replies: 13
    Last Post: 14th November 2013, 21:28
  2. Replies: 10
    Last Post: 27th May 2013, 23:31
  3. [wts]power genesis dual mono 2ch, like new!
    By B523 in forum Power Amplifier
    Last Post: 23rd June 2010, 09:31
  4. SALE: Genesis Dual Mono Class A (DMA) SOLD
    By ace911 in forum Power Amplifier
    Last Post: 1st September 2009, 13:00
  5. GENESIS DUAL MONO class A
    By dexza in forum Diskusi Power Amplifier
    Last Post: 11th April 2007, 00:09
