[selling] HKS Hipermax III - JDM Suspension
Results 1 to 10 of 52
  • Short URL:  http://modifika.si/48266
    1 Wk 3 Days 2 Hrs 57 Mins 2 Secs
    Thumbs up [selling] HKS Hipermax III - JDM Suspension
    HKS SUSPENSION HIPERMAX III Made in Japan
    HIPERMAX III
    Series Concept: Designed and tuned for street application / daily driving.
    With the Hipermax III suspension series, the driver gains increased wheel control with improved performance of all vehicle dynamics and increased driver command in all conditions. Hipermax III combines track-quality control with excellent ride and handling characteristics at real-world street speeds. HKS' all-new Hiper Linear Piston Fluid Channel System damping system creates a positive relationship between piston speed and damping force, making it possible to produce a suspension that provides track-level control and feedback with exceptional ride quality at the same time.
    In addition, the Hipermax III is shock-body adjustable (most applications) to allow vehicle height adjustment without affecting spring rate and piston stroke. With the Hipermax III’s range of adjustability, precise corner balancing can be achieved. Chrome-plated cylinder shafts provide excellent durability and newly-design rubber upper mounts reduce harshness. (For most applications, optional spherical bearing mounts are also available for enhanced steering feedback.)
    Key Features:
    • Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements. As piston speed increases, dampening rate linearly increases.
    • Strengthened rubber upper mounts – enhanced durability
    • Monotube design
    • Shock-body length adjustable (most applications)
    • 65mm diameter springs – Cold wound and manufactured in-house at HKS to ensure quality and consistency
    • Stainless lock nut & ride height adjuster – feature anti-rust & corrosion characteristics for enhanced durability.
    • 30-way adjustable dampening
    • Hard chrome-plated cylinder shaft
    • Non-electrolysis Nickel plated shock bodies provide durability in severe weather conditions.
    • Pillowball upper mounts optional on certain applications
    • Dustboots standard
    • 1 year limited warranty
    HIPERMAX III Sport
    Series Concept: Designed and Tuned For Competition / Track.
    The Hipermax III Sport series has firmer spring rates and valving to take advantage of the smoother, more consistent pavement of race tracks allowing quicker, more precise transient response and instant direction changes necessary in competition. In addition, the Hipermax III Sport incorporates HKS' all-new Hiper Linear Piston fluid-channel system, shock-body length adjustability (most applications) and ultra-thick chrome plating of the cylinder shaft for excellent durability and reduced stiction (static friction). Spherical bearings, for precise steering and feedback, are standard - but reinforced, rubber upper mounts are available for those seeking reduced vibration from less-than-smooth pavement.
    Key Features:
    • Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements.. As piston speed increases, dampening rate linearly increases.
    • Pillowball upper mounts standard
    • Monotube design
    • 65mm diameter springs - Cold wound and manufactured in-house at HKS to ensure quality and consistency
    • Lightweight Aluminum lock nut & ride height adjuster
    Hipermax III & Hipermax III Sport Basic Specifications:
    HKS SUSPENSION V-SPORT SUZUKI SWIFT
    - Only for Suzuki Swift
    - Available in 2 Variants: Street & Racing
    - 30 Way Adjustable Soft & Hard
    - Price: Starting From 9,000,000 rp.
    awaiting orders from you guys..
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    bumping up..!
    CP : Coki Siboro
    bumping up..!
    CP : Coki Siboro
    Unknown
    5 Days 4 Hrs 39 Mins 17 Secs
    wah barang mantap neh..... bantu up ya.....
    13 Mins 44 Secs
    baeng bgus nih bos..
    bntu up aja deh
    13 Mins 44 Secs
    barng bgus nih bos..
    bntu up aja deh,..
    13 Mins 44 Secs
    bntu up aja deh,..
    makasih bos..
    CP : Coki Siboro
    climbing up for tonite..
    CP : Coki Siboro
    going up lagi..
    CP : Coki Siboro
GT Radial Venom 300x250
  1. WTS : Coilover HKS HIPERMAX!!!!
    By Kakkhoi_Ze in forum Per & Shockbreaker
    Last Post: 20th January 2013, 10:44
  2. info bengkel rekondisi air suspension/ hydrolik suspension
    By indosamili in forum Diskusi Kaki-Kaki
    Last Post: 19th September 2012, 01:05
  3. Replies: 0
    Last Post: 25th January 2012, 02:23
  4. HKS Hipermax - JDM Suspension
    By coki.de auto in forum de Auto Motorsport
    Last Post: 5th September 2011, 15:16
  5. HKS HIPERMAX III SPORT Suspension for GD3 *SOLD*
    By theddhie in forum Bursa Kaki Lainnya
    Last Post: 5th December 2008, 20:18
