Engine Spec detail B5 DOHC (Timor)
Results 1 to 10 of 10
  • Short URL:  http://modifika.si/4802
    Coen
    type : Gasoline, 4-stroke
    Cycl : Inline 4.
    Combustion Chamber : Pentroof
    Dispalcement :1,498cc (91.4 CU.in)
    BoreXstroke : 78.0 X 78.4 (3.07 X 3.09 )
    Compresion Ratio : 9.3
    Valve timing
    IN : open BTDC = 5*
    Close ABDC = 40*
    EX : open BBDC = 50*
    close ATDC = 5*
    ignition Timing : 8* +_ 1*
    Firing order 1-3-4-2
    Engine Performance => Pentroof COmbustion Chamber
    Noise & vibration Reduction => Main Bearing Support Plate ( MBSP)
    => Timing Belt ( YU shape )
    => Hidraulic Lash Adjuster (HLA)
    Weight & size reduction => Compact Cycl block w/ oil Spray.
    Engine
    Power = 105 HP @ 5500 rpm / 110PS@5500rpm
    Torque = 145 Nm @ 4400 rpm
    VVT-i or VTEC = No
    COen
    3 Days 20 Hrs 23 Mins 31 Secs
    wah apalan nih bos coen.. hehehe
    kl mesin timor B5 mau yg sohc ato dohc
    ane punya manualnya dari KIA Sephianya..
    Pradhia Motor
    Kemayoran Jakarta Pusat
    Coen
    ane jg punya.. bejibun...
    nanya body parts nih....? sampe Chassis bisa di usahakan koq..
    Coen
    iye bos.. timor temen ane tabrakan..
    kap, fender ma bemper ancur..
    tp da sih yg nawarin timor body + mesin bekas kanibalan poll
    minta 6jt..
    Pradhia Motor
    Coen
    SOHC atau DO? kayaknya parah tuch....
    fender kiri & kanan ?
    coen
    satyr
    thread timor dah banyak BANGET. tolong disatuin donk. PUSING liatnya
    hehehe.. iya disatuin ja dech..
    @coen lumayan parah..
    Pradhia Motor
    Coen
    Quote Originally Posted by satyr
    Gw setuju sama loe.. hehehehehhe :smt003 :smt005
    " All about Timor/Sephia "
    coen
    satyr
    nah betul begitu
    Coen
    tinggal om Moderatornya aja... Topic All about sephia khan udah ada.. hehehehehe
Venom 300x250 GT Radial
  1. WTS:Timor DOHC 1999 dan Timor SOHC 1996 Istimewa
    By jadulz in forum Merk Lainnya
    Last Post: 2nd February 2012, 15:52
  2. Replies: 2
    Last Post: 24th October 2009, 10:59
  3. WTB: ISC Timor DOHC
    By harrymaura in forum Jual Beli Mesin Lainnya
    Last Post: 5th November 2008, 22:20
  4. WTS Timor DOHC '98-99
    By riq896 in forum Merk Lainnya
    Last Post: 14th July 2008, 21:09
  5. engine detail
    By syncmaster in forum Diskusi Mesin
    Last Post: 8th February 2006, 18:59
