[selling] KSPORT Big Brake Kit
Page 1 of 19 12345 ... LastLast
Results 1 to 10 of 182
  • Short URL:  http://modifika.si/46926
    1 Wk 2 Days 19 Hrs 34 Mins 22 Secs
    K SPORT BIG BRAKE KIT
    WEBSITE:
    http://www.ksportusa.com
    http://www.ksport.co.uk
    Harga Big Brake Kit mulai dari 9,500,000 rp.
    KEY FEATURES:
    1. Aluminum Piston Calipers
    2. D.O.T. Compliant Stainless Steel Brake Lines
    3. Machined Aluminum Hats
    4. Carbon Steel Brackets
    5. Large Ventilated Discs
    6. High Quality K SPORT Brake Pads
    FRONT Big Brake Kit Availability:
    6 Pot Piston Calipers With 286mm Disc Rotor Diameter (Minimum Velg R15in)
    6 Pot Piston Calipers With 304mm Disc Rotor Diameter (Minimum Velg R16in)
    6 Pot Piston Calipers With 330mm Disc Rotor Diameter (Minimum Velg R17in)
    8 Pot Piston Calipers With 330mm Disc Rotor Diameter (minimum Velg R17in)
    8 Pot Piston Calipers With 358mm Disc Rotor Diameter (minimum Velg R18in)
    12 Pot Piston Calipers With 380mm Disc Rotor Diameter (minimum Velg R19in)
    12 Pot Piston Calipers With 400mm Disc Rotor Diameter (minimum Velg R20in)
    Big Brake Kit Package:
    - Caliper Piston 4 Pot to 12 Pot
    - Disc Rotor Diameter 286mm to 400mm (Min. Velg 15in to 20in)
    - PCD Rotor Compatible with OEM Rotor
    - Bracket Caliper
    - Brake Line
    - Brake Pads
    NOTE:
    1. Masing-masing item dalam 1 kit sepasang untuk depan
    2. Plug & Play instalation
    3. Tidak perlu ubahan apapun pada Brake Kit ataupun pada kendaraan
    REAR Big Brake Kit Availability:
    4 Pot Piston Calipers With 286mm Disc Rotor Diameter (Minimum Velg R15in)
    4 Pot Piston Calipers With 304mm Disc Rotor Diameter (Minimum Velg R16in)
    6 Pot Piston Calipers With 358mm Disc Rotor Diameter (minimum Velg R18in)
    8 Pot Piston Calipers With 380mm Disc Rotor Diameter (minimum Velg R19in)
    8 Pot Piston Calipers With 400mm Disc Rotor Diameter (minimum Velg R20in)
    - Caliper Piston 4 Pot to 8 Pot
    - Bracket Caliper
    - Brake Line
    - Brake Pads
    NOTE:
    1. Masing-masing item dalam 1 kit sepasang untuk belakang
    DESKRIPSI
    Ksport big brake kits provide the ultimate in stopping power for your vehicle. Integrating new brake technology into the design of the kits allows for a kit that highly reduces brake fade and continually cools and refreshes the brake pads surface under braking. These brake systems are designed for easy installation with minimal tools required (in most applications).
    Our extreme lightweight caliper comes in differential bore configuration. It is machined from aircraft quality billet, weighs just over 5lbs. each, and has machined in protection grooves for the bridge tubes. Aluminum pistons, high temperature seals, and stainless steel brake pad wear plates are also standard on each caliper design. The opposed piston caliper design greatly improves pad wear and caliper rigidity over the OEM design. The stainless steel brake lines stop expansion under pressure.
    Most applications utilize the 2-piece floating disc assembly, which reduces weight both rotating and unsprung. The floating disc also stops thermal stresses of extreme heat from warping the disc or cupping the braking surface. The unique slot design on the rotor greatly reduces braking noise and expels gas and pad debris faster than conventional slot designs. Every rotor is always heat treated and balanced before shipment for the best possible performance.
    awaiting orders from you guys..
  2. Hokinusa
    http://www.facebook.com/RARERIMS
    1 Mth 5 Days 6 Hrs 52 Mins 55 Secs
    Upz for you boss!
    Quote Originally Posted by bigone6788 View Post
    Upz for you boss!
    makasih bos..
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    2 Mths 2 Wks 6 Hrs 13 Mins 34 Secs
    pcd 4x108 buat peugeot ada bos?
    Djogja Town
    wah harganya miring jg yah...
    tp dah terlanjur beli WP Pro 6pot 360mm baru aja kmarin ini >,<
    didalam mobilQu tercinta..
    3 Days 7 Hrs 44 Mins 50 Secs
    Om,kalo brake line nya sama booster remnya aja bisa ga?!?
    Tu kalo beli a set sama pasang?!?tapi discnya yg kecil aja ada om?!?
    buat famie ane nie..
    Quote Originally Posted by play View Post
    peugeot tipe apa bos? tahunnya juga sekalian dan kalo ada chassis & engine code biar gak salah..
    CP : Coki Siboro
    Quote Originally Posted by 7thSign View Post
    gpp bos.. mungkin kalo nanti perlu brake kit lagi buat mobil bos yg lain atau mobil teman bisa kabarin.. hehehe
    CP : Coki Siboro
    Quote Originally Posted by paculbo View Post
    gak bisa pisah2 bos belinya.. ini brake kit gak sama booster rem juga..
    1 set brake kit itu isinya (untuk roda kiri&kanan)
    - disc rotor
    - califer rem
    - brake line
    - bracket
    - brake pad
    kalo ukurannya udah didesain dari sana nya..
    FYI: harga baru barang aja, belum termasuk instalasi. thx
    CP : Coki Siboro
    Djogja Town
    boss...
    gw rotornya paling kecil 330 yah ?
    gw sebenernya butuh 1 lagi...paling ngga 6 pot gitu tapi yg rotornya kecilan...
    yg bisa masuk velg r16 kira2 apa yah ?
    buat mitsubishi pajero...rem bawaannya kurang pakem...
    thanks...
  1. --selling-- KSPORT COILOVER KIT
    By coki.de auto in forum Per & Shockbreaker
    Last Post: 15th August 2015, 01:50
  2. .:de Auto Motorsport:. KSPORT Big Brake Kit - Honda New Jazz GE8
    Last Post: 7th May 2013, 14:06
  3. [selling] Coilover Kit KSPORT
    By coki.de auto in forum Bursa Kaki Lainnya
    Last Post: 3rd December 2012, 17:36
  4. --.WTS.-- KSPORT Coilover Kit Honda New Jazz GE8
    Last Post: 31st May 2009, 01:09
  5. [modcom sponsor] selling: Performance Disc Rotor & Brake Pads
    Last Post: 2nd May 2009, 10:05
