[selling] Coilover Kit KSPORT
Page 1 of 18 12345 ... LastLast
Results 1 to 10 of 176
  • Short URL:  http://modifika.si/46924
    K SPORT COILOVER KIT
    Website:
    www.ksportusa.com
    www.ksport.co.uk
    ---> Harga coilover kit xxx
    Tentang Coilover Kit KSPORT:
    - 1 set 4 buah shock breaker depan & belakang + 4 buah per depan dan belakang
    - bisa adjust/setting tinggi & rendah (manual dengan kunci khusus)
    - bisa adjust/setting keras & empuk sebanyak 36 klik settingan (manual dengan alat khusus)
    - perlengkapan dalam 1 set termasuk 2 buah kunci untuk setting tinggi rendah dan 4 buah kunci untuk setting keras empuk)
    - materialnya terbuat dari bahan berkualitas alumunium 6061 dengan tingkat kekuatan alumunium T6
    - untuk beberapa tipe kendaraan akan dilengkapi dengan pillow ball uppermount untuk penyetelan sudut kemiringan/chamber roda
    Sedikit Lebih Jauh Tentang KSPORT:
    Ksports Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. Made from high quality 6061 Aluminum with T6 for increased hardness.
    Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
    Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
    The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavitations are a lot less common in a Monotube design, which results in a better ride.
    The Ksport control Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
    1. 36 levels of adjustable dampening
    2. Made from high quality 6061 aluminum with T6 for increased hardness
    3. Compression/Rebound adjustable
    4. Adjustable spring perch for height adjustment
    5. Adjustable body allowing maximum suspension travel
    6. Pillowball top mount with adjustable camber (not available for some models)
    7. Monotube high pressure design reduces oil leakage
    8. Electroplated body for protection from corrosion and rust
    9. One year limited warranty
    waiting orders from you guys..
    waiting for that green light
    2 Days 9 Hrs 52 Mins 28 Secs
    bwt lancer CB5 brp yah?
    J-town
    3 Days 13 Hrs 12 Mins 37 Secs
    Boss, bs buat mobil apa aja nih?
    altezza_zita@yahoo.com/satyrwebstore@yahoo.com
    5 Days 10 Hrs 36 Secs
    iya. ada list aplikasinya ga ?
    www.satyrwebstore.web.id - automotive online store since 2006
    Osram, Forch, DS, Wealthy, K&N, Michelin, Denso, NGK, NWB, Castrol, Mobil, Shell, Aral, Total, etc
    jakarta barat
    4 Days 13 Hrs 45 Mins 43 Secs
    Untuk jazz ad g???
    jakarta barat
    Untuk gd3 ad g???
    Quote Originally Posted by B146RA View Post
    maunya mobil apa bos? biar di cek ada apa enggak..
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    Quote Originally Posted by B 36 U View Post
    Untuk gd3 ad g???
    buat jazz ada bos..
    CP : Coki Siboro
    Quote Originally Posted by satyr2 View Post
    ini coilover yg plug n play, jadi bos tinggal kasih tau saya mau untuk mobil apa, nanti saya pesenin yg sesuai dengan mobil bos..
    CP : Coki Siboro
    Quote Originally Posted by soundpump View Post
    segituan deh bos.. hehehe
    CP : Coki Siboro
GT Radial MBtech
  1. --selling-- KSPORT COILOVER KIT
    By coki.de auto in forum Per & Shockbreaker
    Last Post: 15th August 2015, 01:50
  2. [selling] KSPORT Big Brake Kit
    By coki.de auto in forum Bursa Kaki Lainnya
    Last Post: 6th December 2014, 06:39
  3. FS::: Ksport Kontrol Pro Coilover V2.2 Golf GTI Mk5
    By roadstaz in forum VolksWagen
    Last Post: 5th December 2011, 10:36
  4. --.WTS.-- KSPORT Coilover Kit Honda New Jazz GE8
    Last Post: 31st May 2009, 01:09
