MODESTA real glass coating
Results 1 to 10 of 28
  • Short URL:  http://modifika.si/462458
    Exclamation MODESTA real glass coating
    Spoiler for Introduction MODESTA: Show
    Modesta BC-05 was originally developed in the manufacturing industry to be applied in molds in order to release products easily from the mold. BC-05 is a glass coating which uses a three-dimensional siloxane frame as the base, and forms a clear membrane which is excellent in durability. Both wet and dry application is possible and demonstrate powerful water repelling qualities. The strong anti-fouling property almost rejects even a parmanent marker.
    Spoiler for MODESTA Character: Show
    Anti-fouling property - As the dirt and grime does not adhere, it is easily removed by rinsing with water (both oil and water based fouling).
    Very High water repelling efficiency - Not present in conventional waxes.
    Scratch resistance- It excels in abrasion-proof nature and wear resistance. Physical membrane protects paint work from minor car wash scratches.
    Heat resistance - Hardened Modesta BC-05 doesn’t burn and will not soften when exposed to high temperatures, this prevents dirt and grime from embedding into the coating.
    Gloss - Modesta BC-05 produces a beautiful glass-like shine with extreme clarity.
    Weather resistance - The paint work is protected from environmental factors such as ultraviolet rays and acid rain.
    Chemical resistant - Deterioration of the paint by the corrosive substances is prevented.
    Adhesiveness - Modesta BC-05 forms a strong bond to the paintwork at the room temperature, this ensures long-term durability.
    No environmental pollution - As it is a thin film of inorganic coating, there is almost no environmental pollution.
    Spoiler for FAQ: Show
    How long does it last?
    Modesta’s coated surface is glass of an inorganic substance, so technically it has no secular distortion. It does not come off unless cut by abrasives. We are conducting follow up research with our customers and the oldest vehicles have past 10 years since the application and have minor scratches, but they are easily cleaned and the gloss is restored by a car wash.
    How long is the warranty for?
    Most of Modesta dealers issue 3 year written warranty against cracking, bubbling and delaminating of the coating on the car body with normal use and maintenance. This means that should the applied coating peels, dealers will clean or repair the damaged section and re-apply the treatment provided all conditions in the warranty have been observed.
    Does the car never get any scratches again after applying the Modesta?
    Glass Coating is about three times harder than paint so it makes the car body surface tougher, however it will have scratches as time goes on because of the paint underneath the Modesta is very soft.
    Does the Modesta crack or delaminate?
    The thickness of applied Modesta on the car body surface has very high adhesiveness, so the coating doesn’t crack or delaminate.
    Do bird droppings, water stain and other dirt stick to the car after Modesta has been applied?
    It will, but most of them are easy to clean. It is recommended to wash the car to clean some nasty dirt as soon as it appears in order to keep the car in a good condition.
    How is the gloss compared to conventional paint protection?
    Modesta gives a perfect wet look on the car. It sharpens the colour just like fresh clear paint. Conventional paint protections don’t have such a solid gloss like Ark Barrier. It doesn’t darken or partly loses the gloss.
    Can you re-apply the Modesta after a smash repair and repaint?
    Yes, we can. We can re-apply it to all the body or the panel.
    How much maintenance does it require?
    Only wash by water or with a dish washing detergent basically. Coal tar(pitch) and iron powder can stick. Please contact us for its maintenance.
    Spoiler for Coating: Show
    Before coating :
    After coating :
    Clean N' Tidy
    Auto wash & paint protection
    ph : 08159332995
    Thumbs up
    As it may, they’re a lot of competitive coating on the market. Modesta Coatings are made by professionals for professionals. In the growing industry of vehicle protection, Modesta stands apart from the rest in a large way. Modesta technology is the most sophisticated coating on the market, aimed for professional use only.
    These coatings are layer-able to produce a thicker top coat if used correctly. Offering effective durability to extreme temperatures (UV protect-ant) and an insane gloss. Modesta coatings help to protect the paint from all kinds of damage including, wash-induced damages (scratches) oxidation, tree sap, watermarks, salts, acids and even permanent ink. It’s strong water-repellent properties promote the self-cleaning effects.
    Maintenance should always be performed by a professional with required skill and equipment. Modesta M1shot and Shampoos are highly recommended for protecting the coating.
    Clean N' Tidy
    ph : 08159332995
    Clean N' Tidy
    ph : 08159332995
    Clean N' Tidy
    ph : 08159332995
    Clean N' Tidy
    ph : 08159332995
    Clean N' Tidy
    ph : 08159332995
    Clean N' Tidy
    ph : 08159332995
    Clean N' Tidy
    ph : 08159332995
    Clean N' Tidy
    ph : 08159332995
Venom 300x250 MBtech
  1. CAR GLASS PROTECTION, COATING SERVICE by RN-Tech
    By warcupid in forum Jasa Perawatan Mobil
    Last Post: 12th July 2013, 00:31
  2. For Sale: 22PLE Glass Coating VX1 Pro 50ml
    By detailermart in forum Produk Perawatan Mobil
    Last Post: 6th April 2013, 17:55
  3. Replies: 17
    Last Post: 15th October 2012, 10:06
  4. [WTA] Glass Coating
    By febriandp in forum Diskusi Perawatan Mobil (Exterior & Interior)
    Last Post: 12th October 2012, 10:49
  5. Replies: 4
    Last Post: 30th December 2011, 17:20
