Perbandingan Motor Sport 1000cc Yang Banyak Beredar di Indo
Scuto Laminating Simota Bro Togel
Results 1 to 10 of 10
  • Short URL:  http://modifika.si/459860
    2 Days 18 Hrs 6 Mins 32 Secs
    Kita compare motor sport ber-cc 1 liter yg banyak beredar di negara kita yuk...
    2013 Aprilia RSV4
    Make Model Aprilia RSV-4 Factory APRC ABS
    Year 2013
    Engine Liquid cooled, four stroke, longitudinal 65 V four , DOHC, 4 valves per cylinder
    Capacity 998,9
    Bore x Stroke 78 x 52,3 mm
    Compression Ratio 13.0:1
    Induction Air box with front dynamic air intakes. Variable length intake ducts controlled via ECU.
    4 Weber-Marelli 48-mm throttle bodies with 8 injectors and latest generation
    Ride-by-Wire engine management. Choice of three different engine maps selectable by
    the rider with bike in motion: T (Track), S (Sport), R (Road) Magneti Marelli digital
    electronic ignition system integrated in engine control system, with one spark plug per
    cylinder and "stick-coil"-type coils.
    Ignition / Starting Electronic digital ignition integrated in the fuel management system. / electric.
    Exhaust 4 into 2 into 1 layout, single oxygen sensor, lateral single silencer with engine control
    unit-controlled butterfly valve and integrated trivalent catalytic converter (Euro 3)
    Flywheel mounted 420W alternator with rare earth magnets Lubrication Wet sump. Two
    pumps (lubrication and cooling). Oil cooler.
    Clutch Cassette type.
    Max Power 180 hp 132.4 kW @ 12250 rpm
    Max Torque 115 Nm @ 10000 rpm
    Transmission / Drive 6 Speed / chain
    Gear Ratio 1st: 38/16 (2.375) 2nd: 35/18 (1.944) 3rd: 28/17 (1.647) 4th: 32/22 (1,455)
    5th: 34/26 (1,308) 6th: 33/27 (1,222)
    Traction management APRC System (Aprilia Performance Ride Control), which includes Traction Control (ATC),
    Wheelie Control (AWC), Launch Control (ALC), all of which can be configured and
    deactivated independently.
    Steering angle / Trail 24.5 / 105 mm
    Frame Twin-spar adjustable aluminium frame, with castings and pressings. Envisaged
    adjustments: headstock position and rake engine height swingarm pin height Ohlins
    adjustable steering dumper
    Front Suspension Ohlins Racing upside-down fork, 43-mm stanchions (with Tin surface treatment). Low
    profile forged aluminium radial
    Rear Suspension Twin sided aluminium swingarm; mixed low thickness and sheet casting technology.
    Ohlins Racing monoshock with piggyback with completely adjustable: spring preload,
    wheelbase and hydraulic compression and rebound damping. APS progressive linkages.
    Wheel travel: 130 mm
    Front Brakes 2x 320-mm diameter floating stainless steel disc with lightweight stainless steel rotor
    and aluminium flange with 6 pins. Brembo monobloc radial callipers with 4 34-mm
    opposite. Sintered pads. Radial pump and metal braided brake hose
    Rear Brakes Single 220-mm diameter disc; Brembo floating calliper with two 32mm isolated pistons.
    Pump with integrated tank and metal braided hose
    Front Tyre 120/70 ZR17
    Rear Tyre 200/55 ZR 17 (alternative: 190/50 ZR 17; 190/55 ZR17)
    Max. length: 2040 mm
    Max. width: 735 mm (at the handlebar)
    Max. height: 1120 mm
    Min. height from the ground: 130 mm
    Seat Height 845 mm
    Dry-Weight 184 kg
    Fuel Capacity (res) 17 litres (4-litre reserve included)
    Standing Mile 10.5 sec
    Top Speed 291.2 km/h
    2013 BMW HP 4
    Make Model BMW HP 4
    Year 2013
    Engine Liquid cooled, four stroke, transverse four cylinder, DOHC, 4 valves per cylinder
    Capacity 999
    Bore x Stroke 80 x 49,7 mm
    Intake / exhaust 33.5 mm / 27.2 mm
    Compression Ratio 13:1
    Induction Electronic fuel injection, digital motor electronics BMS-KP
    Throttle valve diameter 48 mm
    Emission control Two regulated three-way catalytic converters, EU-3
    Starting Electric
    Clutch Multiple disc antihopping clutch in oil bath,
    Max Power 143.9 KW 193 hp @ 13000 rpm
    Max Torque 112 Nm 82.6 lb-ft @ 9750 rpm
    Transmission / Drive 6 Speed / chin
    Gear Ratio I 1 :2.6471 II 1 :2.091 III 1 : 1.727 IV 1 : 1.500 V 1 : 1.360 VI 1 : 1.261
    Transmission ratio 1 :2.647
    Frame Bridge-type aluminium frame, load-bearing engine
    Front Suspension USD fork with DEC, fixed fork tube diameter 46 mm damping electronically adjustable,
    spring preload adjustable, 120mm wheel travel.
    Rear Suspension Aluminum double-sided swing arm with DDC central spring strut, compression and
    rebound stage electronically adjustable, spring preload hydraulicaily adjustable 130 mm
    wheel travel.
    Front Brakes 2x 320mm discs radial monoblock4-piston fixed caliper
    Rear Brakes Single 220mm disc 1 piston floating caliper
    ABS BMW Motorrad Race ABS (partially integral, disengageable)
    Wheel castor 3.9 in / 98.5 mm
    Wheels Forged wheels Front 3.50x17 Rear 6.00 x 17
    Rear Tyre 200/55 ZR17
    Seat Height 820 mm / 33.3 in
    Wheelbase 56 0 in / 1422 7 mm
    Dimensions L / W 80.9 in / 2,056 mm 32.5 in / 826 mm
    Dry-Weight 169 kg / 373 lb
    Fuel Capacity 17.5 Litres
    2013 Ducati 1199 Panigale
    Make Model Ducati 1199 Panigale
    Year 2013
    Engine Liquid cooled, four stroke, 90Ltwin cylinder, DOHC, desmodromic 4 valve per cylinder.
    Capacity 1199
    Bore x Stroke 112 x 60.8 mm
    Compression Ratio 12.5;1
    Induction Mitsubishi EFI, Full ride-by-wire elliptical throttle bodies
    Exhaust 2-1-2 system with catalytic converter and 2 lambda probes. Twin stainless steel
    mufflers with alumimum outer sleeves
    Ignition / Starting - / electric
    Clutch Clutch Slipper and self-servo wet multiplate clutch with hydraulic control
    Max Power 195hp 143kw @ 10,750rpm
    Max Torque 98.1lb-ft 132Nm @ 9000rpm
    Frame Monocoque aluminum
    Front Suspension Marzocchi 50mm pressurized and fully adjustable usd fork with hard anodized aluminum
    lightweight slider
    Rear Suspension Fully adjustable Sachs unit. Adjustable linkage: Progressive/flat. Aluminum single-sided
    swingarm.
    Front Brakes 2 x 330mm semi-floating discs, radially mounted Brembo Monobloc M50 4-piston callipers
    ABS optional +2.5kg (+5.5lb)
    Rear Brakes Single 245mm disc 2 piston caliper
    Front Tyre 120/70 ZR17 Pirelli Diablo Supercorsa SP
    Rear Tyre 200/55 ZR14 Pirelli Diablo Supercorsa SP
    Seat Height 824 mm / 32.4 in
    Dry-Weight 164kg / 361.5lb
    Fuel Capacity 17 Litres / 4.5 gal
    Standing Mile 10.8 sec / 141.41 mp/h
    Standing Mile 27.0 sec / 176.07 mp/h
    Top Speed 178.4 mp/h
    2013 Honda CBR 1000RR Fireblade
    Make Model Honda CBR 1000RR Fireblade
    Year 2013
    Engine Liquid cooled, four stroke, transverse four cylinder, DOHC, 4 valve per cylinder.
    Capacity 998
    Bore x Stroke 76 x 55.1 mm
    Compression Ratio 12.3 : 1
    Induction PGM-DSFI electronic fuel injection 46mm Throttle Bore
    Ignition / Starting Computer-controlled digital transistorised with electronic advance / electric
    Clutch Wet, multiplate with diaphragm spring
    Max Power 175.6hp 131.0 kW @ 12000 rpm
    Max Torque 112.0 Nm @ 8500 rpm
    Rake / Trail (Caster Angle): 23.3 / 96.2mm (3.8 inches)
    Gear Ratio 1st 2.286 (32/14) / 2nd 1.778 (32/18) / 3rd 1.500 (33/22) / 4th 1.333 (32/24) /
    5th 1.214 (34/28) / 6th1.138 (33/29)
    Frame Diamond; aluminium composite twin-spar
    Front Suspension 43mm inverted Big Piston Fork with spring preload, rebound and compression damping
    adjustability
    Rear Suspension Unit Pro-Link Balance-Free Rear Shock with spring preload, rebound and compression
    damping adjustability
    Front Brakes 2x 320mm discs 4 piston calipers, Combined ABS and sintered metal pads
    Rear Brakes Single 220mm disc, Combined ABS and sintered metal pads
    Front Tyre 120/70ZR-17
    Rear Tyre 190/50ZR-17
    Seat Height 820 mm / 32.3 in
    Wet Weight 210 kg
    Fuel Capacity 17.7 Litres (including 4-litre LCD-indicated reserve) / 4.7 gal
    2013 Kawasaki ZX-10R Fireblade
    Make Model Kawasaki Z-X10R Ninja
    Year 2013
    Engine Liquid cooled, four stroke, transverse four cylinder, DOHC, 4 valves per cylinder.
    Capacity 998
    Bore x Stroke 76 x 55 mm
    Induction DFI with four 47mm Keihin throttle bodies with oval sub-throttles, two injectors per
    cylinder
    Ignition / Starting TCBI with digital advance and Sport-Kawasaki Traction Control (S-KTRC) / electric
    Max Power 185 -200 estimated
    Max Torque 114.3 Nm @ 1150 rpm
    Rake / Trail 25.0 degrees / 109.9mm
    Front Suspension 43mm Big Piston Fork (BPF), rebound, compression and spring preload adjustability 4.7in
    wheel travel
    Rear Suspension Horizontal Back-link. High/low-speed compression, rebound and preload adjustable. 4.9in
    wheel travel
    Front Brakes 2x 310 mm petal discs, radial-mount 4-piston calliper
    Rear Brakes Single Single 220mm petal disc
    Rear Tyre 190/55 ZR17
    Seat Height 812 mm / 32 in
    Weight 198 kg
    Consumption average 16.4 km/lit
    Standing Mile 10.4 sec
    Top Speed 296.6 km/h / 184.3 mp/h
    2013 MV Agusta F4 RR
    Make Model MV Agusta F4RR
    Year 2013
    Engine Liquid cooled, four stroke, transverse four cylinder. DOHC, 4 radial valves per cylinder
    Capacity 998
    Compression Ratio 13.4:1
    Engine management Integrated ignition - injection system MVICS (Motor & Vehicle Integrated Control
    System) with eight injectors Engine control unit Eldor EM2.0, throttle body full drive by
    wire Mikuni, pencil-coil with ion-sensing technology, control of detonation and misfire.
    Torque control with four maps, Traction Control with eight levels of intervention with
    lean angle sensor, EAS
    Electronically Assisted Shift - TSS Torque Shift System employing variable length intake runners
    Electrical Equipment Voltage 12 V
    Alternator 350 W at 5000 r.p.m.
    Battery 12 V - 8.6 Ah
    Starting electric
    Max Power 143.5 kW 195 hp @ 13400 rpm
    Max Torque 110.8 Nm 11.3 kgm @ 9600 rpm
    Clutch Wet, multi-disc with back torque limiting device
    Transmission / Drive Cassette styl 6 Speed / chain
    Primary drive 48/82
    Gear Ratio 1st: Speed 14/37 2nd : Speed 16/33 3rd Speed 18/31 4th Speed 20/30 5th Speed
    22/29 6th Speed 21/25
    Final drive ratio 15/41
    Rake / Trail 100,4 mm / 3.93 in.
    Frame Type CrMo Steel tubular trellis Rear swing arm pivot plates material Aluminium alloy
    Front Suspension 43mm hlins EC Nix hydraulic "UPSIDE DOWN" front forks with TiN superficial treatment.
    Completely adjustable electronically controlled compression and rebound damping with
    manual, spring preload 120 mm 4.72 in wheel travel.
    Rear Suspension Progressive, single shock absorber hlins TTX. Fully adjustable hydraulic electronically
    controlled compression and rebound damping with manual, spring preload Single sided
    swing arm material Aluminium alloy 120 mm 4.72 in. wheel travel
    Front Brakes 2x Double floating 320mm discs with steel braking disc and aluminium flange, Front brake
    caliper Brembo radial-type, single-piece with 4 pistons 34 mm ( 1.34 in.)
    Rear Brakes Single 210mm disc Nissin with 4 pistons - 25.4 mm ( 1.00 in.)
    Wheels Front Material/size Aluminium alloy 3,50 in x 17 in
    Wheels Rear Material/size Aluminium alloy 6,00 in x 17 in
    Dimensions length 2115 mm / 83.30 in Overall width 750 mm / 29.51 in Saddle height 830 mm /
    32.68 in
    Wheelbase 1430 mm / 56.27 in
    Seat Height 830 mm / 32.68 in
    Dry-Weight 190 Kg / 418.9 lb
    Fuel Capacity 17 Litres / 4.49. gal.
    2013 Suzuki GSX-R 1000
    Make Model Suzuki GSX-R 1000
    Year 2013
    Engine Liquid cooled, four stroke, transverse four cylinder, DOHC, 4 valves per cylinder, TSCC
    Capacity 998.6
    Bore x Stroke 74.5 x 57.3 mm
    Compression Ratio 12.9:1
    Induction Fuel Injection
    Ignition / starting Electronic ignition Transistorized / electric
    Clutch Hydraulically-actuated multiplate wet clutch.
    Max Power -
    Max Torque -
    Transmission / drive 6 Speed / chain
    Gear Ratio 1st - 2.562 / 2nd - 2.052 /.3rd - 1.714 / 4th - 1.500 / 5th - 1.360 / 6th - 1.269
    Front Suspension Inverted telescopic, coil spring, oil damped
    Rear Suspension Link type, coil spring, oil damped
    Front Brakes 2x Brembo, Disc
    Rear Brakes Single disc
    Rear Tyre 190/50 ZR17
    Wheelbase 1405mm / 55.3 in.
    Seat Height 810 mm / 31.9 in.
    Weight 203 kg / 448 lb
    Fuel Capacity 17.5 Litres / 4.6 US gal
    2013 Yamaha YZF-R1
    Make Model Yamaha YZF 1000 R1
    Year 2013
    Capacity 998
    Bore x Stroke 78 X 52.2 mm
    Compression Ratio 12.8:1
    Ignition / Starting TCI / electric
    Clutch Cable-operated multiplate wet slipper clutch.
    Max Power 133.9 kW 182 hp @ 12500 rpm
    Max Torque 115.5 Nm 11.8 kg-m @ 10000 rpm
    Gear Ratio 1st 38/15 (2.533) 2nd 33/16 (2.063) 3rd 37/21 (1.762) 4th 35/23 (1.522)
    5th 30/22 (1.364) 6th 33/26 (1.269)
    Frame Deltabox V aluminium
    Front Suspension 43mm inverted telescopic fork w/adjustable preload, compression damping, rebound
    damping; 120.mm wheel travel
    Rear Suspension Single shock w/piggyback reservoir; adjustable for hi-/lo-speed compression damping,
    rebound damping, spring preload, 120mm wheel travel.
    Front Brakes 2x 310mm discs 6 piston calipers
    Rear Brakes Single 220mm disc 1 piston caliper
    Seat Height 835 mm / 32.8 in
    Wet-Weight 206 kg / 454 lb
    Fuel Capacity 18 Litres / 4.8 gal
    Naaaahhh... bos-bos sekalian mau beli yg mana hayoooo????
  2. Solar Gard
    1 Hr 52 Mins 1 Sec
    Kalo menurut ane rsv 4 paling yangsud dijakarta.. Body kecil segede ninja lah.. Tapi tarikan paling maut, kedua panigale karena alesan yang sama.. Terus ane suka moge italy karna mesin gak pasaran inline 4 yang suaranya cempreng gitu2 aja.. Itu pendapat ane si..
    3 Days 3 Hrs 57 Mins 9 Secs
    Kawasaki kereen
    StudioKaos.net - shine your image of what you wear
    Plat B & Plat H
    1 Mth 1 Wk 2 Days 3 Hrs 55 Mins 6 Secs
    Nice Inpho
    Keep Calm n Safety Driving
    bandung
    1 Hr 48 Mins 11 Secs
    ane demen banget sama R1
    20 Hrs 9 Secs
    Pi;ih ane 2 nro.. Honda, Kawasaki atau ducati.. Yang sudah ada branded namanya
    Ajibarang
    1 Mth 1 Wk 13 Hrs 16 Mins 12 Secs
    nice share...
    pemula
    3 Days 2 Hrs 3 Mins 3 Secs
    Suzuki GSX1000RR... tinggal plug in knalpot yoshimura.... suaranya bikin horny....
    2 Days 3 Hrs 58 Mins 4 Secs
    Honda CBR manttap tu
Datsun 300x250 MBtech
  1. Replies: 35
    Last Post: 25th August 2015, 16:34
  2. Foto Seksi Jupe Yang Beredar Di Situs Porno
    By Livie959 in forum ShowBiz
    Last Post: 10th December 2014, 13:28
  3. Jual Diecast / Miniatur mobil. Berbagai merk mobil yang beredar di Indonesia dan luar
    By 4A-GE in forum Diecast, RC, etc (Gunakan http://jualbeli.modifikasi.com)
    Last Post: 16th April 2014, 14:55
  4. Kawasaki Test Pasar Motor Sport Retro Estrella di Indonesia
    By DISCOVERYturbo in forum Berita Otomotif Motor
    Last Post: 5th September 2013, 14:51
  5. 5 Motor Sport Honda Yang Populer
    By B_Series in forum Berita Otomotif Motor
    Last Post: 8th November 2012, 00:14
