Engine
Type:
V12, 60, MPI
Displacement:
6,498 cm (396.5 cu.in.)
Bore and stroke:
95 mm x 76,4 mm
Valve gear:
Variable valve timing electronically controlled
Compression ratio:
11.8 ( 0.2) : 1
Maximum power:
700 HP (515 kW) @ 8,250 RPM
Maximum torque:
690 Nm (507 lbft) @ 5,500 RPM
Emission class:
EURO 5 LEV 2
Emission control system:
Catalytic converters with lambda sensors
Cooling system:
Water and oil cooling system in the rear with variable air inlets
Engine management system:
Lamborghini Iniezione Elettronica (LIE) with Ion current analysis
Lubrification system:
Dry sump
Chassis and body
Frame:
Carbon fiber monocoque with Aluminium front and rear frames
Body:
Carbon fiber engine bonnet, movable spoiler and side air inlets; Aluminium front bonnet, front fenders and doors; SMC rear fender and rocker cover
Mirrors:
External mirrors heated, electrically adjustable and foldable
Rear spoiler:
Movable - 3 positions depending on speed and drive select mode
Suspension
Suspension:
Front and rear horizontal mono-tube damper with push-rod system
Tyres and wheels
ESP:
ESP/ ABS with different ESP charecteristics managed by drive select mode
Steering:
Steering Gear with 3 different servortonic charcteristics managed by drive select mode
Front tires:
Pirelli 255/35 ZR19
Rear tires:
Pirelli 335/30 ZR20
Front wheels:
19 x 9J
Rear wheels:
20 x 12J
Curb-to-curb turning circle:
12.5 m (41.0 ft)
Airbags
Airbags:
Front dual stage driver airbag and front adaptive passenger airbag; seats with side head-thorax airbags; passenger and driver knee airbags
Brakes
Brakes:
Dual hydraulic circuit brake system with vacuum brake booster; front and rear CCB, 6-cylinder brake callipers, 4-cylinder brake callipers 400x 38 mm 380 x 38 mm
Drivetrain
Type of transmission:
4WD with Haldex generation IV
Gearbox:
7 speed ISR, shifting characteristic depending on drive select mode
Clutch:
Dry double plate clutch, 235 mm
Standard:
AMT
Performance
Top speed:
350 km/h (217 mph)
Acceleration 0-100 km/h (0-62 mph):
2.9 s
For the Price :
OFF THE ROAD : 8,3M
ON THE ROAD : 9,2M + Quicksilver Exhaust
Ready Orange Colour
For more info please call / Massage
(jarang buka jadi jgn di PM ya)
081908859063
288C91AB
