AUTOMETER ORIGINAL MADE IN USA
Results 1 to 10 of 79
  • Short URL:  http://modifika.si/442099
    cipondoh-tangerang
    5 Mths 3 Wks 13 Hrs 41 Secs
    SPEEDZ PERFORMANCE IS AUTHORIZED DEALER FOR SUPPLY AUTOMETER PRODUCT MADE IN USA
    SPEED'Z PERFORMANCE AUTHORIZED DEALER MEMBERIKAN PENAWARAN AUTOMETER ORIGINAL (BUKAN REPLICA)
    -4899 CARBON FIBER HARGA 3JT
    -6299 COBALT HARGA 2.650 JT
    -5899 PHANTOM HARGA 2.8 JT
    -7599 PHANTOM 2 HARGA 2.5 JT
    -3904 SPORT COMP MONSTER HARGA 2.7 JT
    -3699 SPORT COMP 2 HARGA 2.5 JT
    -3911 SPORT COMP HARGA 2.8 JT
    -6834 PRO COMP HARGA 4.2JT
    -4999 ULTRA LITE 2 HARGA 2.5 JT
    SPEED'Z PERFORMANCE AUTHORIZED DEALER FOR AUTOMETER MADE IN USA
    JUST COMING STOCK IN BELOW
    SPORT COMP 2 INCH
    -3327 OIL PRESS 0-100 PSI
    -3316 FUEL LEVEL
    -3391 VOLT METER
    -3348 OIL TEMP
    -3337 WATER TEMP
    -3303 BOOST METER
    SPORT COMP 2-5/8 INCH
    -3522 OIL PRESS
    -3516 FUEL LEVEL
    -3592 VOLT METER
    -3401-J BOOST METER
    PHANTOM 2 INCH
    -5727 OIL PRESS
    -5716 FUEL LEVEL
    -5791 VOLT METER
    -5748-M OIL TEMP
    -5737-M WATER TEMP
    -5703-M BOOST METER
    PRO COMP 2-5/8 INCH
    -5427 OIL PRESS
    -5417 FUEL LEVEL
    -5492 VOLT METER
    -5447 OIL TEMP
    -5437 WATER TEMP
    ULTRA-LITE 2 INCH
    -4327 OIL PRESS
    -4316 FUEL LEVEL
    -4391 VOLT METER
    -4348 OIL TEMP
    -4337-M WATER TEMP
    -4303-M BOOST METER
    ULTRA-LITE 2 5/8 INCH
    -4427 OIL PRESS
    -4416 FUEL LEVEL
    -4491 VOLT METER
    -4457 TRANS TEMP
    -4437 WATER TEMP
    -4403 BOOST METER
    -3543-M OIL TEMP
    OPTION
    -3262 FUEL LEVEL SENDER
    AUTOMETER 3699
    AUOTOMETER 3904
    cipondoh-tangerang
    dapetkan autometer original hanya di speedz performance ........
    cipondoh-tangerang
    SPEED'Z PERFORMANCE RACING SUPPLIER Is The Main Distributor For AEM, DC SPORT, MSD IGNITION, AP RACING, BREMBO, TM WORKS, FIDANZA, BISIMOTO, GUDE CAMS, AEROMOTIVE, XRP, WALBRO, CP PISTON, ARP,ISKY, FORGED RACING, BRIAN CROWER, COMETIC, EDELBROCK, SUPERTECH, MEGAN RACING, AUTOMETER, WEBER CARBURATION, FLUIDAMPER, PERMA-COOL, ATI DAMPER, MICKEY THOMPSON DRAG TYRE, WELD DRAG WHEELS, DEFI, APEX-i, TOMEI, SARD , M7 JAPAN, BLITZ, TEIN, EXEDY, HALTECH, TURBOSMART, CUSCO, POWER ENTERPRISE, APP, GREEDY, PROJECT MU, PIVOT, SPOON, MUGEN, K&N, BILLION, NGK, BRIDE, TAKATA, N-BRAKE, ATS&CARBONETIC, And Others Stuff. You Can Visit Our Workshop At MUARA KARANG RAYA NO:11 . Phone:021-66602331-66602332/MOBILE: 081382077777-02199199777(HANS) Or You Can Email Us (speedzperformance@yahoo.com) For Consultation Or Just For Information About Our Products.
    cipondoh-tangerang
    cipondoh-tangerang
    just coming new stock for AP RACING:
    CP 7600 street 4pot
    -caliper +selang rem+brake pad
    -caliper +selang rem+brake pad +adaptor dengan discbrake ap racing 280mm atau 295mm
    CP 5200 street 4pot
    -caliper+selang rem+brake pad +adaptor dengan discbrake ap racing 330mm
    CP 5040 race 4pot
    CP 9040 street 6 pot
    -caliper+selang rem+brake pad +adaptor dengan discbrake ap racing 355mm
    CP 5060 race 6 pot
    -caliper+selang rem+brake pad +adaptor dengan discbrake ap racing 355mm dan discbrake ap racing 362mm
    *brake pad is original ap racing (apf404) dan selang rem godridge
    *for price call,sms or whatsapp
    cipondoh-tangerang
    CP 7600 street 4pot
    CP 5200 street 4pot
    CP 5040 race 4pot
    CP 5060 race 6 pot
    cipondoh-tangerang
    cipondoh-tangerang
    SPORT COMP 2 INCH
    -3316 FUEL LEVEL
    -3391 VOLT METER
    -3348 OIL TEMP
    -3337 WATER TEMP
    -3303 BOOST METER
    -3522 OIL PRESS
    -3516 FUEL LEVEL
    -3592 VOLT METER
    -3401-J BOOST METER
    PHANTOM 2 INCH
    -5727 OIL PRESS
    -5716 FUEL LEVEL
    -5791 VOLT METER
    -5748-M OIL TEMP
    -5737-M WATER TEMP
    -5703-M BOOST METER
    PRO COMP 2-5/8 INCH
    -5427 OIL PRESS
    -5417 FUEL LEVEL
    -5492 VOLT METER
    -5447 OIL TEMP
    -5437 WATER TEMP
    ULTRA-LITE 2 INCH
    -4327 OIL PRESS
    -4316 FUEL LEVEL
    -4391 VOLT METER
    -4348 OIL TEMP
    -4337-M WATER TEMP
    -4303-M BOOST METER
    -4427 OIL PRESS
    -4416 FUEL LEVEL
    -4491 VOLT METER
    -4457 TRANS TEMP
    -4437 WATER TEMP
    -4403 BOOST METER
    -3543-M OIL TEMP
    OPTION
    cipondoh-tangerang
    SPEED'Z PERFORMANCE IS AUTHORIZED DEALER EXCLUSIVE IN INDONESIA,SINGAPORE AND MALAYSIA FOR SUPPLY MSD PART NUMBER IN BELOW JUST COMING THE STOCK:
    *MSD 34635 LONG BRASS CLIP FOR
    *MSD 31179 SUPERCONDUCTOR,6CYL MULTI ANGLE SOCKET HEII
    *MSD 8516 PRO BILLET DISTRIBUTOR 6 CYL AMC JEEP 232.258 4.0 LITER
    *MSD 8222 HIGH VIBRATION BLASTER COIL
    *MSD 34059 SUPER CONDUCTOR WIRE RED 300 BULK
    *MSD 34525 90 DEGREE DIDTRIBUTOR BOOTYS ,GRAY SILICONE,100 EACH
    *MSD 34565 STRAIGHT.GRAY.SILICONE ,100 EACH
    *MSD 84049 COIL WIRE .BLASTER COIL/SOCKET CAP
    *MSD 34615 90 DEGREE SPARK PLUGTERMINAL S.100EACH
    *MSD 34605 MULTI ANGLE SPSRTKS TERMINAL 100 EAH
    POPULAR STOCK MSD IN BELOW:
    *MSD 6425 6AL DIGITAL WITH REV CONTROL
    *MSD 6421 6AL-2 WITH 2 STEP LIMITER
    *MSD 7AL-3 PRO DRAG RACE IGNITION
    *MSD 6304 DISC CPC SIGNAL CONVERTER 4 CHANEL
    *MSD 6305 SC COIL DRIVE IGNITION FOR SC DISTRIBUTOR
    *MSD 8235 COIL BLASTER FOR 6305 OR CDI IGNITION
    *MSD 8864 DIST ADPTR CAB HONDA/ACURA OBD 2 TO OBD 1
    *MSD 8488 DISTRIBUTOR 96-01 HONDA 1.6/1.8L B DOHC VTEC
    *MSD 8910 TACH ADAPTOR
    *MSD 8910EIS TACH ADAPTOR
    *MSD 8920 TACH ADAPTOR
    *MSD 62112 MSD DIS-2 PLUS
    *MSD 62113 MSD DIS -2 PLUS HIGH OUTPUT
    *MSD 62152 MSD DIS-4 PLUS
    *MSD 62152 MSD DIS-4 PLUS HIGH OUTPUT
    *MSD 6520 DIGITAL 6-PLUS IGN.CONTROL MICROPROCESSOR
    *MSD 6302 DIS DUAL COIL IGNITOR 2 CHANEL
    *MSD 8207 MSD SS BLASTER COIL
    *MSD 8202 MSD COIL BLASTER 2 HIGH PERFORMANCE
    *MSD 5528 MSD COIL PACK STREET FIRE FORD 6 TOWER DIS 94-00
    *MSD 8241 MSD COIL FORD DIS COIL PACK 4 TOWER
    *MSD 8251 MSD HVC COIL WITH MSD 7 SERIES
    *MSD 8252 MSD HVC COIL WITH MSD 6 SERIES
    *MSD 8253 MSD HVC2 COIL WITH MSD 6 SERIES
    *MSD 84049 COIL WIRE BLASTER COIL/SOCKET CAP
    *MSD 8735 LAUNCH CONTROL MODULE SELECTOR
    *MSD 82903 MSD DISTRIBUTOR CAP AND ROTOR FOR HONDA D-SERIES ENGINE
    *MSD 82923 MSD DISITRIBUTOR CAP AND ROTOR FOR HONDA B-SERIES ENGINE
    *MSD 82933 MSD DISTRIBUTOR CAP AND ROTOR FOR HONDA B18C
    *MSD 82913 MSD DISTRIBUTOR CAP AND ROTOR FOR HONDA F-H SERIES ENGINE
    *MSD 8672 SELECTOR SWITCH 6.0-8.2K
    *MSD 8673 SELECTOR SWITCH 7.6-9.8K
    *MSD 8674 SELECTOR SWITCH 9.0-11.2K
    *MSD 8732 2 STEP LAUNCH CONTROL FOR 6425 IGNITION
    *MSD 8737 MODULE SELECTOR ,THREE STEP
    *MSD 8912 TACH ADAPTER DIS-2 N DIS-4 IGNITIONS
    *MSD 32319 WIRE SET FOR HONDA CIVIC 1.6 LITER
    *MSD 32359 WIRE SET FOR HONDA CIVIC 1.6 LITER VTEC
    *MSD 32369 WIRE SET FOR HONDA ACCORD 2.2 LITER
    *MSD 8239 COIL,MITSUBISHI,DODGE 96-ON
    *MSD 8883 HARNESS DIS-2 TO DODGE/MITSUBISHI COIL PACK
    *MSD 8843 PRO-CLAMP WIRE SEPARATORS
    *MSD 8841 PLUG WIRE SPACER KIT 16/SET
    *MSD 8842 PLUG WIRE SPACER KIT 16/SET WIRE SLEEVES
    *MSD 8812 SWITCH UNIVERSAL PUSH BUTTON ALT ACTION
    *MSD 34615 90 DEG SPARK PLUG TERMINALS
    *MSD 34515 90 DEG SPARK PLUG BOOT GRAY SILICONE
    *MSD 3510 CRIMP JAWS DEUTSCH CONNEECTOR
    *MSD 350051 PRO CRIMP TOOL RATCHET ACTION
    *MSD 4217 IGN 1CYL PROGRAMMABLE BATT POWERED
    *MSD 42181 YAMAHA YZ250 PROGRAMMABLE IGNITION
    *MSD 8232 COIL SINGLE TOWER CPC IGNITION
    *MSD 8204 COIL BLASTER MC MOTORCYCLE LARGE CASE
    *ASY30160 HARNESS DODGE/MITSUBISHI COIL PACK ASSY
    cipondoh-tangerang
  1. WTS Kabel Busi Blue Fire Original made in USA
    By Farizi in forum Engine & Parts
    Last Post: 18th December 2012, 13:34
  2. Replies: 4
    Last Post: 20th November 2011, 06:51
  3. HRE 547 ring 17 ( 7,5rata) ORIGINAL made in USA
    By halimsatria in forum Ragam Ukuran
    Last Post: 23rd July 2010, 23:06
