TURBO TIMER |A'PEXi|HKS|GReddy|ARK|
  • Short URL:  http://modifika.si/433831
    TURBO TIMER
    A turbo timer is a device designed to keep an automotive engine running for a pre-specified period in order to automatically execute the cool-down period required to prevent premature turbo wear and failure.
    After a period of driving when a turbocharger has been working hard, it is important to let the engine run at idle speed for a period, allowing the compressor assembly to cool from the lower gas temperatures in both the exhaust and intake tracts. At the same time the lubricating oil from the engine is able to circulate properly so the turbine won't burn the lubricating oil that would otherwise be trapped within the charger with the turbine rotating at high speed.
    With regard to modern automotive turbochargers, the need for a turbo timer can be eliminated by simply ensuring the car does not produce any 'boost' (during driving) for several minutes prior to the ignition being shut off.
    A'PEXi AUTO TIMER PEN STYLE (BLACK FACE/RED LED)
    The Apex Auto Timer allows the vehicle to idle for a preset amount of time after the ignition key has been removed. In turbocharged vehicles this prevents hot oil in the engine from coking up in the lines. Hard driving can raise engine oil temperatures to dangerously high levels. Proper cool down is essential for a healthy turbo and engine.
    The Auto Timer stands as a technological marvel. The pen shaped, compact size makes the Auto Timer one of the smallest turbo timers on the market. This allows a clean and stylish installation virtually anywhere inside the car. The unique multi angle joystick button allows easy navigation through the many feature menus.
    Upgraded in every way from the previous model, the new Auto Timer can automatically determine the necessary amount of idle time. A Manual Mode allows the user to preset desired idling times from 0 sec.~10 minutes in 16 increments. By inputting O2 sensor voltage, the Timer can also display theoretical air fuel ratio. Since the Auto Timer uses the factory O2 sensor which is primarily designed for emissions, the readings may not be as accurate as facing air fuel ratio monitors, however Timer readings are very close. The Timer can also display critical data such as O2 sensor voltage and Battery Voltage.
    HKS TYPE-0 SLIM DESIGN TURBO TIMER (BLACK FACE/RED LED)
    The HKS Turbo Timer - Type 0 assist in cooling down the turbocharger to prevent oil coking in the center bearing cartridge assembly. Oil "coking" occurs when a turbocharger is not properly cooled down and the oil that normally lubricates the center cartridge heats up and forms solidified oil deposits.
    A turbo timer allows an engine to idle for a preset amount of time after the ignition key has been turned to the off position and removed. By allowing a turbocharged engine to idle, oil continues to pass through the turbo until it has cooled down to the point where oil "coking" will not occur. Re-designed for 2008, the all new Turbo Timer Type-0 feature a new, slim low profile design with a separate LCD display and control unit following the same design concepts as the current HKS EVC and A/F Knock Amp.
    The Turbo Timer Type-0 features a red LCD backlit display for easy visibility, 2 timer modes, and a battery voltage meter with a peak value indication and warning function.
    GREDDY FULL AUTO TIMER
    Designed to prolong the life of your turbocharger, while adding connivance. GReddy Full Auto Turbo Timers allow a vehicle to idle the engine for a timed period, with the ignition key removed.
    This conveniently allows the engine oil and turbo center cartridge to cool down properly and prolong turbo and oil life. This can be done by two standard programmable count down presets (P-1, P-2), or the GReddy Full Auto Timer can use itís two auto timer modes (A-L, A-H). The modes estimate the driving RPM according to the vehicle's alternator signal and then recommend a count down time.
    ARK DESIGN REV SHIFT TIMER (BLACK FACE/RED LED)
    The REV Shift Timer was developed specifically to combat improper engine oil cooling and over-revving. The RST is a full functioning turbo timer with an integrated shift light, plus additional monitoring functions. All these features are built into the same compact size unit as ARK Design's Advanced Boost Controller (ABC) so the REV Shift Timer and ABC perfectly complement each other in any vehicle's interior.
    Features:
    - RPM
    - Shift Light
    - Turbo Timer
    - Air Fuel Ratio (AFR)
    - Battery Voltage
    Slim and compact display/control unit (W105 x D20 x H18 mm) provides an easy installation and placement inside any vehicle
    Timer Function
    Auto Mode calculates (by driving style) how long a turbocharged vehicle's engine should run after the ignition has been shut off. Manual mode allows the driver to set the desired idle time manually.
    Rev-Shift Function
    The engine's speed (RPM) can be captured through either the alternator pulse or directly from the ECU. The shift light can be set to turn on and off at any RPM. For indicator purposes, the LED will flash in bright white when the user preset shift point is reached.
    A/F Ratio Display
    A/F ratio can be displayed numerically on the LED display and in color ranges by the LED indicator. A/F ratio is calculated from the factory O2 sensor. Because most OEM O2 sensors are designed for emissions, the RST readings may vary compared to a wide-band A/F meter.
    * A/F ratio readings will only work with Zirconia type O2 sensors.
    Battery Voltage Display
    Battery voltage can be displayed on the LED display, along with battery change status.
    Contact:
    Coki Siboro
    de Auto Motorsport
    Mobile 0815 1330 1978
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    turbo timer for your turbocharge engine..
    CP : Coki Siboro
    mantab suhu
GT Radial Venom 300x250
  1. Replies: 369
    Last Post: 22nd July 2014, 06:07
  2. Replies: 785
    Last Post: 30th April 2013, 06:07
  3. TURBO Timer HKS, RAZO, FET
    By Francy in forum Jual Beli Mesin Lainnya
    Last Post: 18th February 2009, 13:42
  4. ===HKS TURBO TIMER TYPE-0===
    By zoom-bodyworks in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 26th March 2008, 20:47
  5. FS : HKS TURBO TIMER TYPE 1!!!! BOOKED!!!
    By mugendc2 in forum Jual Beli Mesin Lainnya
    Last Post: 3rd March 2008, 03:53
