four throttle
Page 1 of 5 12345 LastLast
Results 1 to 10 of 45
Thread: four throttle
  • Short URL:  http://modifika.si/4294
    Banned
    SF-JKT
    21 Hrs 56 Mins 28 Secs
    four throttle
    anybody can explain?
    apa kelebihan dan kekurangannya?
    apa bisa membuat lonjakan tenaga jauh lebih besar?
    thx..
    1 Day 16 Hrs 41 Mins 24 Secs
    rasanya sih efeknya sama kaya masang 4 barrel di mesin karbu..
    CMIIW...
    eNZed
    8 Hrs 56 Mins 27 Secs
    hmm... kelebihannya, throttle response jauh lebih baik, krn throttle flap-nya ada di setiap intake manifold (bandingkan dgn model yg biasa, 1 throttle utk 4 intake).
    kekurangannya, its a real pain in the ass to tune it properly. but if u have decent mods and an accurate tuning, results are mind blowing. however, for the trouble u face and the advantage u may get, its just not that practical to do.
    info lebih lanjut, tanya bahamuth... dia pake ITB di 4age-nya...
    Bahamuth
    sperti kaya sugar.
    respon naek. cuman gak kerasa tenaga jauh lebih besar.
    biasa pasang ginian mesti sertai maen IHE, cam. ecu.
    ecu juga mending stand alone ecu, jgn piggy back.
    Banned
    SF-JKT
    whats wrong using piggyback sir? what if piggybacks enough already? but would be so much worth it if assuming the tuning and result is way off the hook?
    and what about the fuel consumption? would it also be very much a 'thirsty one machine' like those using 4barrels?
    jakarta timur
    9 Hrs 9 Mins 19 Secs
    mmmh... piggyback tuh ada kelemahanya...... kalo lu pake stand alone mapnya ada banyak n ada fasilitas2 lain seperti als,dll ribet jelasinya.......
    Banned
    SF-JKT
    tapi mungkin ga pake piggyback? lil bit short in fund nih..
    ping2
    kalo short of fund, coba aja cari stand alon power fc. enak, kagak ribet(plug n play) trus harga gak mahal bos, dan tuh stand alone favorit banget di amrik. Gampang setting nya tinggal lewat hand controller aja, kalo soal response naek sih iya, tapi jangan sampe kepanasan deh bos, mending di kasih box trus di arahin ke daerah yang lebih adem deh. biar aman juga buat mesin nya. kalo tenaga mungkin bisa sampe 20 whp tapi bos yang penting reliable apa gak. karena power delivery nya laen banget bos, untuk 0-100 kenceng banget, kalo gak salah aku pernah liat nih civic pakek seri b bisa masuk 11-12 second buat 0-400m. kalo di kota enak banget, nyalip nya gampang cuman kalo macet parah juga, parah karena throttle response naek tajam jadi sering tersendat2 dah kalo jalan pelan.
    Bahamuth
    Quote Originally Posted by odi
    aku pake bahasa indo aja biar yg laen lebih enak yah
    pake piggy back contoh safc2 (ini yg sekarang aku pake).
    mesin bakal jalan tapi gak bakal jalan bener2 sebagus kalo pake stand alone. ECU yg asli (walaupun + piggyback) gak bakal bisa jalanin ITB dgn bener, karena gak di design buat ITB. ITB jalan dgn low vacuum, sedangkan yg normal 1 throttle ke intake manifold jalan high vacuum terus TPSnya beda, kecuali di custom lagi.. dan bbrp problem laen lagi. fuel consumption emang jauh lebih 'thirsty' dibanding dulu.
    Bahamuth
    yah kalo mau asal mesinnya 'jalan' iya, piggyback bisa jalan.. tapi saran aku, kumpulin uang buat stand alone. kalo blom kekumpul, tetep ama stock dulu.
  1. For Sale : 4-throttle ex. 4A-GE (individual throttle body)
    By slalomer2804 in forum Jual Beli Mesin Lainnya
    Last Post: 1st October 2012, 23:15
  2. 4-throttle std 4AG 20V
    By gtracing in forum Jual Beli Mesin Lainnya
    Last Post: 2nd August 2009, 22:22
  3. WTB 4 throttle AGE
    By vauxhel in forum Jual Beli Mesin Lainnya
    Last Post: 31st July 2009, 21:26
  4. Replies: 0
    Last Post: 26th June 2008, 23:13
  5. throttle body
    By GTMan in forum Diskusi Mesin
    Last Post: 11th November 2005, 06:23
