EXTERNAL WASTEGATE || TiAL ~ TurboSmart ~ Precision ~ GodSpeed
  • Short URL:  http://modifika.si/427955
    EXTERNAL WASTEGATE
    Wastegates are an essential part of any turbocharged powerplant. Controlling boost not only ensures that you are maintaining the correct pressures for the fuel you are running, but it also prevents overboost situations where the turbocharger is forced to spin faster than it would like. In these instances, you actually can loose horsepower, as the air is being super-heated by the compressor.
    |:| TiAL SPORTS |:|
    TiAL answered our cries for the "perfect" Twinscroll wastegate by releasing the brand new MV-S & MV-R. Designed to be the highest flowing/smallest size external wastegate available, this new ultra compact wastegate stands only 3.7" in height (vs the old units at 4.85") and is ideal for Dual-Wastegate applications (twinscroll). Other features include 3 bottom pressure ports for easy install and fitting access and a top mount pressure port that can be rotated 6 different ways. No more bolts or gaskets and like all high end TiAL wastegates are leaded fuel safe. we also altered the way the diaphragm sits so it is virtually impossible to pinch.
    MV-S 38mm V-Band (Red)
    MV-R 44mm V-Band (Blue)
    |:| TURBOSMART |:|
    Ultra Gate 38mm 7 PSI (Blue)
    The new Ultra-Gate38 is a 38mm external wastegate for street and racing applications. Designed with minimum size and maximum flow in mind, the new Ultra-Gate38 is smaller and lighter than the previous model and features Turbosmartís unique locking collar design for quicker spring changes and a one piece, stainless steel valve.
    Comp Gate 40mm 14 PSI (Blue)
    Turbosmartís brand new 40mm external wastegate was designed to fit into tight engine bays while still offering superior flow and heat handling capabilities. The revolutionary new actuator housing is 25% smaller than our current range and allows for easy spring changes and gives the ability to index the cap orientation in 12 different positions.
    |:| PRECISION 39mm (Black) |:|
    Precision 39mm Wastegate including 3 different stiffness springs, both V-Band Flanges, Clamps, and all installation hardware. This wastegate will mount to existing Tial F38 2 bolt style flanges, but features a larger valve opening to flow more air. It is a bolt=on upgrade for Tial F38 users.
    |:| GODSPEED |:|
    RS-Series Gen-2 Wastegate 38mm 5 PSI (Black)
    - comes with 5psi wastegate spring
    - dual port
    - accurate boost pressure
    - ultra durable diaphragm
    - comes with all the hardware (bolts, gasket etc)
    RS-Series Wastegate 44mm V-Band (Black)
    - comes with 10.5 psi wastegate springs (adjustable)
    - dual port
    RS-Series Wastegate 50mm V-Band (Black)
    - comes with 7 psi & 12 psi wastegate springs (up to19 psi max)
    - dual port
    Semua wastegate diatas ORIGINAL dengan kondisi barang 100% baru
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    EP Garage jogja 2AC9346F
    4 Wks 1 Day 3 Hrs 37 Mins 24 Secs
    38 nya brp duit boss??
    Starlet Enthusiast Community
    EP91 insideEP Garage - jogjakarta w/a 087838399000
    Quote Originally Posted by starlet_EP91 View Post
    maksudnya yg tial atau turbosmart bos?
    CP : Coki Siboro
    update parts..
    CP : Coki Siboro
  1. RR // External Wastegate (TiAL MV-S & TurboSmart)
    By RacingRepublic in forum Turbo & Parts
    Last Post: 29th September 2015, 10:39
  2. Replies: 12
    Last Post: 12th October 2013, 19:07
  3. RR // TiAL MV 38mm & TURBOSMART External Wastegate
    By RacingRepublic in forum Jual Beli Mesin Lainnya
    Last Post: 3rd April 2013, 15:20
  4. Replies: 1
    Last Post: 15th February 2013, 02:09
  5. WTS Tial External Wastegate dan apexi turbo timer
    By Bad_Boy in forum Jual Beli Mesin Lainnya
    Last Post: 12th March 2010, 15:21
