HKS Hipermax - JDM Suspension
Results 1 to 10 of 65
  • Short URL:  http://modifika.si/42043
    1 Wk 3 Days 2 Hrs 57 Mins 1 Sec
    HKS SUSPENSION HIPERMAX III Made in Japan
    HIPERMAX III
    Series Concept: Designed and tuned for street application / daily driving.
    With the Hipermax III suspension series, the driver gains increased wheel control with improved performance of all vehicle dynamics and increased driver command in all conditions. Hipermax III combines track-quality control with excellent ride and handling characteristics at real-world street speeds. HKS' all-new Hiper Linear Piston Fluid Channel System damping system creates a positive relationship between piston speed and damping force, making it possible to produce a suspension that provides track-level control and feedback with exceptional ride quality at the same time.
    In addition, the Hipermax III is shock-body adjustable (most applications) to allow vehicle height adjustment without affecting spring rate and piston stroke. With the Hipermax III’s range of adjustability, precise corner balancing can be achieved. Chrome-plated cylinder shafts provide excellent durability and newly-design rubber upper mounts reduce harshness. (For most applications, optional spherical bearing mounts are also available for enhanced steering feedback.)
    Key Features:
    • Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements. As piston speed increases, dampening rate linearly increases.
    • Strengthened rubber upper mounts – enhanced durability
    • Monotube design
    • Shock-body length adjustable (most applications)
    • 65mm diameter springs – Cold wound and manufactured in-house at HKS to ensure quality and consistency
    • Stainless lock nut & ride height adjuster – feature anti-rust & corrosion characteristics for enhanced durability.
    • 30-way adjustable dampening
    • Hard chrome-plated cylinder shaft
    • Non-electrolysis Nickel plated shock bodies provide durability in severe weather conditions.
    • Pillowball upper mounts optional on certain applications
    • Dustboots standard
    • 1 year limited warranty
    HIPERMAX III Sport
    Series Concept: Designed and Tuned For Competition / Track.
    The Hipermax III Sport series has firmer spring rates and valving to take advantage of the smoother, more consistent pavement of race tracks allowing quicker, more precise transient response and instant direction changes necessary in competition. In addition, the Hipermax III Sport incorporates HKS' all-new Hiper Linear Piston fluid-channel system, shock-body length adjustability (most applications) and ultra-thick chrome plating of the cylinder shaft for excellent durability and reduced stiction (static friction). Spherical bearings, for precise steering and feedback, are standard - but reinforced, rubber upper mounts are available for those seeking reduced vibration from less-than-smooth pavement.
    Key Features:
    • Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements.. As piston speed increases, dampening rate linearly increases.
    • Pillowball upper mounts standard
    • Monotube design
    • 65mm diameter springs - Cold wound and manufactured in-house at HKS to ensure quality and consistency
    • Lightweight Aluminum lock nut & ride height adjuster
    Hipermax III & Hipermax III Sport Basic Specifications:
    awaiting orders from you guys..
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    Sea Shore!
    1 Hr 20 Mins 43 Secs
    Thumbs up
    makin gila aja coilover tuh!!
    Quote Originally Posted by gaztrusz View Post
    mungkin minat bos?
    CP : Coki Siboro
    1 Min 25 Secs
    Gileeee utk ajrut2an aje mau lebih dari 10jt... Kalo ajrut2an-nya bukan dimobil 10jt bisa mpe pengkor2 tuh yaaa??? huehehehehhe
    sudirman,jakarta
    1 Hr 49 Mins 26 Secs
    untuk swift berapaan??
    Bali-Kediri
    1 Day 5 Hrs 15 Mins 6 Secs
    buat starled ada ga ya....
    kuat buat rally ga ya...
    NATURAL engine performance
    Telp : 081-80555-5321
    pin : by request sms aja
    Denpasar-Bali
    Quote Originally Posted by NATURAL View Post
    sori kalo buat starlet harus special order bos, tp takutnya harganya jadi agak tinggi.. yg bisa dipake rally ada kok speknya suspensi hks, tp bisa sampe diatas 17jt tuh.
    CP : Coki Siboro
    Quote Originally Posted by benny66 View Post
    cek pm bos.. thx
    CP : Coki Siboro
    Unknown
    5 Days 4 Hrs 39 Mins 17 Secs
    bos.... untuk jazz ama swift yg tipe mana n brp harganya?pm ya thx
    Quote Originally Posted by RraditzZ View Post
    untuk jazz tipe hks hipermax s-compact yang bisa adjust tinggi-rendah dan 30klik keras-empuk.
    untuk swift juga ada tipe hks hipermax s-compact dan yang paling baru 2 varian hks v-series suspension.
    hks v-sport ada 2 varian: v-series yang street & v-series yang sport.
    harga masing2 cek pm bos. thx
    CP : Coki Siboro
GT Radial NGK Busi
  1. WTS : Coilover HKS HIPERMAX!!!!
    By Kakkhoi_Ze in forum Per & Shockbreaker
    Last Post: 20th January 2013, 10:44
  2. info bengkel rekondisi air suspension/ hydrolik suspension
    By indosamili in forum Diskusi Kaki-Kaki
    Last Post: 19th September 2012, 01:05
  3. Replies: 0
    Last Post: 25th January 2012, 02:23
  4. [selling] HKS Hipermax III - JDM Suspension
    By coki.de auto in forum Bursa Kaki Lainnya
    Last Post: 10th April 2009, 22:25
  5. HKS HIPERMAX III SPORT Suspension for GD3 *SOLD*
    By theddhie in forum Bursa Kaki Lainnya
    Last Post: 5th December 2008, 20:18
