WTS: Used Apexi RSM + Original Bracket
Results 1 to 10 of 19
  • Short URL:  http://modifika.si/41949
    2 Hrs 41 Mins 53 Secs
    Mau dijual nih Apexi RSM Sayah,
    Udah lama dicopotin nga dipake, dulunya pasang di mobil newcity.
    Barang lengkap dus, buku kartu garansi PLUS ada bracket original apexi nya.
    Kondisi masih maknyuss..... kinyis kinyiss...
    Barang ada dikantor di Sudirman,Midplaza.
    Mau dijual 1.4jt sajah nego dikit2 bole la
    Kalau minat, lgs call ajah di 0818661806 atau ym:my_bad_habbit
    Tq all
    Spoiler :
    Like the original, the new Rev / Speed Meter GP is a complete multi function measuring device designed to measure and monitor data such as vehicle speed, engine RPM and elapsed times. The new screen utilizes the easy to read VFD (Vacuum Flourescent Display) with built in light sensor used in many of APEXis line up. The new unit also delivers a host of new functions.
    Standard features include: Engine RPM, Vehicle Speed, Travel Distance and Battery Voltage (all which can be displayed in real-time graph mode, or analogue mode; 1-4 channels at a time). Peak Hold, Replay (60secs), Speed Limiter Cut, 0-100m/200m/400m time with Trap Speed. 0-100km/h/200km/h/300km/h times, Mid Range Acceleration (user can preset any range of speed to measure), Stop Watch functions, Best Time Memory, RPM Warning, Speed Warning, RPM & Speed Outputs (for external devices requiring an RPM or Speed signal). Tyre Size Correction (for timing accuracy), and Vehicle weight input.
    One of the most exciting new features is the option to utilise a revolutionary APEXi G-Sensor (Sold separately). The G-sensor allows the unit to measure G-forces in a 4 way front/rear/left/right directions. This data can be plotted in a graph display to map acceleration characteristics and lateral Gs on a race track, or used in an array of new features including : Highly accurate 100m/200m/400m times with trap speed and wheelspin correction, produce an extremely accurate power measurements. Usually, when measuring 0-400m times through the speed senso signal alone, the meter will end measurement too early (shorter distance due to wheel spin). Using the G-Sensor modifies the speed sensor signal, compensating for wheel spin, and producing impeccably accurate acceleration times.
    Potonya bisa dilihat disini
    http://upload.kapanlagi.com/h/20080603100713_03062008_4844b56148248.jpg
    http://upload.kapanlagi.com/h/20080603100713_03062008001_4844b5614f770.jpg
    http://upload.kapanlagi.com/h/20080603100713_03062008002_4844b561545b1.jpg
    http://upload.kapanlagi.com/h/20080603100713_03062008003_4844b561593f9.jpg
    1 Wk 6 Days 8 Hrs 44 Mins 45 Secs
    Boss ini kumplit ya?termasuk g sensornya?
    ad
    1 Mth 1 Wk 1 Day 14 Hrs 31 Mins 3 Secs
    harga net berapa boz?? thanks
    8 Hrs 52 Mins 58 Secs
    bwat estilo bisa gag????
    bedanya ama SAFC 2??????
    tlg infonya
    deadman.incorporated : Nggak bos saya nda punya G Sensornya cuma unit buku kabel + bracket original
    hen_88 : Om Hen harga sudah bagus loh om.. bole tanya toko deh hehehe. kondisi masih kinyis2 loh...
    MARGOREJO AUTO SPEED : buat estillo ? wahh pasti bisa lah om bedanya dgn SAFC tu kalau SAFC itu setahu saya fungsinya mirip seperti piggyback yg kerjanya ngebodoh2in ECU supaya larinya kenceng
    Nah tapi kalau RSM itu fungsinya HANYA mendisplay data2 dari speed dan engine rpm, dikombinasikan dgn bobot kendaraan dapat deh bisa lihat HP mobil, 0-400m performance, 0-200m, 0-100kmh dll dsb
    yah kira2 kayak main game ps3 tanpa harus takut ngacak2 ECUnya. gitu loh om.
    tambahin link full reviewnya please check this link
    http://www.importtuner.com/tech/0203it_apex_rsm/index.html
    btw thanks untuk yg udah nawar tapi masih blm masuk ni harganya.
    cup cup waw waw
    Upppss....
    Hayo2 barang langka nih
    buat latihan drag liat waktu 0-400 nya
    Komplek Ruko Gading Kirana Utara Blok G 10 No. 37 Kelapa Gading Permai 021.4587.6330
    49 Mins 33 Secs
    pm harga net nya ya bro ... atau sms gua jg boleh .. 021.9302.9676
    AUTOFEVER
    Kompleks Ruko Gading Kirana Utara Blok G10 No. 37
    Kelapa Gading Permai - Jakarta Utara
    Phone: 021.4587.6330 - autofever.finalstage@yahoo.com
    jakarta utara
    2 Wks 1 Day 23 Hrs 47 Mins 5 Secs
    nich buat vtec y bos...?
    ngatur vtec gak...?
    sorry new bee..
    autofover : PM Sent , thanks
    kambingcongek : boss ini cuma display only, sama sekali nggak ngerubah apa apa jadi bisa dipasang semua mobil mau vtec atau vvti atau polos juga nda masalah, selama ada signal RPM dan KMH nya
    Ups lagi thanks yg uda mampirr yaaa
    cup cup waw waw dehh
    netnya brp bos ? kabel2 komplit kan ?
  1. RECARO SPG Original, plus Bracket
    By okki in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 18th January 2012, 02:32
  2. Replies: 128
    Last Post: 17th October 2011, 10:32
  3. WTS : Apexi RSM blue face + bracket ori Apexi
    By L_2636 in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 8th June 2009, 14:43
  4. WTS : Apexi RSM blue face + bracket ori Apexi
    By L_2636 in forum Jual Beli Mesin Lainnya
    Last Post: 8th June 2009, 07:32
  5. WTB: APEXI RSM (Black Face & Stand Bracket @ Jkt)
    By Rihanna in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 27th December 2008, 01:37
