(need advice) power 4 ch under 1,5 jt
Results 1 to 10 of 15
  • Short URL:  http://modifika.si/41675
    11 Mins 37 Secs
    Buat angkat spek sbb :
    Speaker split :
    - 160mm (6-1/2") 2-Way Component System
    - 25mm (1") My-Ti tweeter
    - Outboard Crossover System
    - Sensitivity : 92dB ? Impedance : 2ohms
    - Power Handling, RMS : 70W
    - Power Handling, Peak : 210W
    Subwoofer :
    - 250mm (10") Dual - Voice Coil Subwoofer
    - Vented Polepiece
    - Dual 4-ohm Voice Coil
    - Sensitivity : 91dB ? Frequency Response : 25Hz - 400Hz
    - Impedance : 4ohms/8ohms
    - Power Handling, RMS : 250W
    - Power Handling, Peak : 1000W
    Kira2 klo spec power ini cukup ga ya?
    Power 4 Channels merk Sony XM554 ZR harga 1,2 jt
    - MOSFET Power Supply
    - Maximum Output Power:
    - 4 Ch x 110W at 4 Ohm,
    - 2 Ch x 150W + 1 Ch x 300W at 4 Ohm,
    - 4 Ch x 150W at 2 ohm
    - Rated Output Power: 4 Ch x 55W at 4 Ohm (0.04% THD),
    - 2 Ch x 65 W + 1 Ch x 130W at 4 Ohm (0.1% THD),
    - 4 Ch x 65W at 2 Ohm (0.1% THD)
    - High Pass Filter: 80Hz,-12dB/oct
    - Low Pass Filter: 80Hz,-18dB/oct
    - Frequency Response: 5Hz-50kHz
    - Signal-to-Noise Ratio: 100dB
    And, klo ada saran laen, tolong dong masukannya,
    Trus klo bisa disertai harga n toko nya dimana..
    Thanks before
    Surabaya - Ambon
    1 Mth 3 Days 21 Hrs 14 Mins 37 Secs
    cari a600 bekas aja bos..
    West Jakarta
    13 Mins 52 Secs
    hdt a600 2nd.. dapet barang murah tp berkualitas..
    www.FirstKoi.com
    mgkn arc kar 400.2 baru sekitar sgt budget u atau lebih dikit tp kl mau cari 2nd aj brang x ad dan dpt lbh murah
    Pemula yg baru belajar, jadi perlu byk bimbingan dari para senior dan terutama pakar2nya.
    52 Secs
    integra nt7600... barunya pas budget segitu, sekennya dibawah sejuta.
    CIRACAS
    9 Hrs 6 Mins 12 Secs
    emang ada apa dengan power sony itu ?
    udah ada yg pernah coba ?
    inside my 406
    1 Wk 4 Hrs 15 Mins 8 Secs
    kalo budget nya segitu...tambahin dikit dapet baru bro
    gw ada tuh HDT A600 baru he3...baru gw buka aja kardus nya..lengkap sama manual+kartu jaminan..he3
    11 Mins 37 Secs
    Quote Originally Posted by bigGy View Post
    HDT A600 merk apa bro?
    Beli nya dimana ? Klo dibanding ARC KAR 400.4 gimana ?
    Tq
    liat aja plat nomor nya
    9 Hrs 9 Mins 10 Secs
    KRONE 4.100X...n 2 chnlnya..mauuu?
    2500d monoblok/spkr SP-160.model DTC-5
    http://www.postimage.org/aVknNYr.jpg
    46 Mins 30 Secs
    subwoofernya musti cari power yg bisa dibridge di 2 ohm tuh (kelas a/b) ato gak pake monoblok.... kalo mau pake kelas a/b ribet tuh, kalo emang budget gak bisa naik, mendingan cari power buat sub dulu, speaker langsung dr hu, ato beli 2 channel buat speaker yg bagus, power buat sub belakangan....
MBtech Venom 300x250
  1. power apa ya?? need advice...
    By pios1018 in forum Diskusi Power Amplifier
    Last Post: 12th March 2009, 18:50
  2. advice power & sub kisaran 2jt-2jt300rb :)
    By jimnymerah in forum Diskusi Power Amplifier
    Last Post: 17th October 2008, 16:30
  3. Need Advice power mono yg seken
    By gokilbangets in forum Diskusi Power Amplifier
    Last Post: 25th September 2008, 14:24
  4. Need advice for power to drive dynaudio 240
    By dastinggo in forum Diskusi Power Amplifier
    Last Post: 10th March 2008, 01:22
  5. Advice Please.....
    By ags in forum Diskusi Power Amplifier
    Last Post: 30th May 2007, 22:40
