WTA :> power xtant
Results 1 to 9 of 9
  • Short URL:  http://modifika.si/41599
    www.FirstKoi.com
    Question WTA :> power xtant
    boz dan bro smua ad yg tau ga spek dan perkiraan power xtant?? dan ni produk buatan mana yah??
    wa ud cari d internet kebanyakan pd bahasa inggris dan berhubung inggris wa krg yah makanya tanya2 d sini aj deh
    tipenya kl ga slh Xtant a400.4 deh
    thanksss yg ud kasi infonya
    Pemula yg baru belajar, jadi perlu byk bimbingan dari para senior dan terutama pakar2nya.
    www.FirstKoi.com
    ayo yg tau bantu bntr dunk
    www.FirstKoi.com
    up, ayo d bantu d bantu bagi yg tau
    1 Hr 11 Mins 51 Secs
    xtant ntu keluaran amrik
    era taon 90-an tu merk mantaf bgt
    skr g jg make xtant jg
    tp yg seri 4.4 nya !!!
    pokok nya brg mantaffff nih
    www.FirstKoi.com
    Quote Originally Posted by keladan View Post
    emang skrg uda krg mantap atau gmn ni bro produknya??
    iya wa punya juga ad yg 4 chanel class A tp ga jls tipe pastinya paan
    Indonesia
    Quote Originally Posted by xsis View Post
    sambil buka kamus aja...itung2 sambil belajar, hehehe...
    itu kl gk salah 4 x 100watt yah, buwatan amprick
    nyoo_hks@yahoo.co.id
    salam bro xsis... di jamin kagak salah pilih dah.. powernya halus, bertenaga.
    djogja
    Xtant A4004 Specifications
    Frequency Response: 20 Hz to 20 kHz +/ 1 dB
    Number of Channels: 4
    Watts per Channel @ 4Ω: 4 x 50
    Watts per Channel @ 2Ω: 4 x 100
    Bridged Mono @ 4Ω: 2 x 200
    Recommended Load: ≥2Ω Stereo / ≥4Ω Bridged
    Distortion (THD): ≤ .2%
    Measured: 20 Hz to 20 kHz at rated power, all channels driven 4Ω
    Signal to Noise Ratio: ≥ 100 dB
    Measured: A-weighted in 20 kHz noise bandwidth @ 1 volt sensitivity
    Damping Factor: ≥ 200 @ 100 Hz with 4Ω load
    Input Sensitivity: 100 mV to 8.5 V RMS Unbalanced
    200 mV to 17 V RMS Balanced
    Input to Line Output Gain: 0 dB
    On-Board Crossover: Front: 12dB HP, 40-120 Hz
    Rear: 12dB HP or 24dB Mono LP, 40-120 Hz
    Balanced Line: On Board
    Power Supply: Fully Regulated, PWM
    Operational Voltage: 10 to 16 Volts
    Fusing Requirement: 60 Amp
    Size (L xW x H): 15-13/16 x 9-1/4 x 1-7/8
    402mm x 235mm x 47mm
    A.R.C.: 0-15dB Level Adjustment
    Bass Boost: 0-12dB @ 45 Hz
    Warranty: Limited 4 Year Parts and Labor
    Quote Originally Posted by daff View Post
    kalau mw upgrade cross over nya bisa ke PROFINDO Gading kirana 021-94062486
  1. WTS Power Amplifier XTANT X604 (used)
    By pentung390 in forum Power Amplifier
    Last Post: 9th June 2012, 23:37
  2. WTS: Xtant Hexagonal Type-X 12" + Monoblock Xtant 2x100 2 Channel
    By netekdenkow in forum Speaker - SubWoofer
    Last Post: 8th November 2010, 16:21
  3. WTS : Power XTANT 3 channel
    By benkz_89 in forum Power Amplifier
    Last Post: 8th August 2010, 04:13
  4. WTA : Power bwt angkat Xtant X1044
    By anjing_gila in forum Diskusi Power Amplifier
    Last Post: 3rd September 2008, 23:34
  5. tny power xtant donk.....
    By keladan in forum Diskusi Power Amplifier
    Last Post: 21st October 2006, 10:08
