tips : filling up ur vehicles
Results 1 to 10 of 10
  • Short URL:  http://modifika.si/41059
    driver's seat
    11 Mins 6 Secs
    Harus dibuktikan neh, terus share disini
    This is a Message received from a friend:
    I don't know what you guys are paying for petrol... but here in Durban, we are
    also paying higher, up to 47.35 per litre. But my line of work is in petroleum
    for about 31 years now, so here are some tricks to get more of your money's
    worth for every litre.
    Here at the Marian Hill Pipeline, where I work in Durban, we deliver about 4
    million litres in a 24-hour period thru the pipeline.
    One day is diesel; the next day is jet fuel, and petrol, LRP and Unleaded. We
    have 34-storage tanks here with a total capacity of 16,800,000 litres.
    ONLY BUY OR FILL UP YOUR CAR OR BIKKIE IN THE EARLY MORNING WHEN THE GROUND
    TEMPERATURE IS STILL COLD. Remember that all service stations have their storage
    tanks buried below ground. The colder the ground, the denser the fuel, when it
    gets warmer petrol expands, so buying in the afternoon or in the evening....
    your litre is not exactly a litre.
    In the petroleum business, the specific gravity and the temperature of the
    petrol, diesel and jet fuel, ethanol and other petroleum products play an
    important role. A 1degree rise in temperature is a big deal for this business.
    But the service stations do not have temperature compensation at the pumps.
    WHEN YOU'RE FILLING UP, DO NOT SQUEEZE THE TRIGGER OF THE NOZZLE TO A FAST MODE.
    If you look, you will see that the trigger has three (3) stages: low, middle,
    and high. In slow mode, you should be pumping on low speed, thereby minimizing
    the vapours that are created, while you are pumping. All hoses at the pump have
    a vapour return. If you are pumping on the fast rate, some of the liquid that
    goes to your tank becomes vapour. Those vapours are being sucked up and back
    into the underground storage tank so you're getting less worth for your money.
    ONE OF THE MOST IMPORTANT TIPS IS TO FILL UP WHEN YOUR TANK IS HALF FULL. The
    reason for this is, the more fuel you have in your tank, the less air occupying
    its empty space. Petrol evaporates faster than you can imagine. Petroleum
    storage tanks have an internal floating roof. This roof serves as zero clearance
    between the petrol and the atmosphere, so it minimizes the evaporation.
    Unlike service stations, here where I work, every truck that we load is
    temperature compensated, so that every litre is actually the exact amount.
    ANOTHER REMINDER, IF THERE IS A FUEL TRUCK PUMPING INTO THE STORAGE TANKS, WHEN
    YOU STOP TO BUY, DO NOT FILL UP - most likely the petrol/diesel is being stirred
    up as the fuel is being delivered, and you might pick up some of the dirt that
    normally settles on the bottom.
    Hope, this will help you get the maximum value for your money.
  2. Jayapoker
    Singapore
    2 Wks 23 Hrs 29 Mins 1 Sec
    Nanti dicoba ah... beda nya banyak ga yah?
    P01RS / FA3FR / ABYSS NOBELLA PROJECT X / FA3 SUB /SR TESLA SERIES
    SQ ENTHUSIAST
    http://www.modifikasi.com/showthread...R-FUN-By-SQ_UP
    ~ɯɐɾ ɔıɟɟɐɹʇ ɟo ʎʇıɔ~
    1 Wk 3 Days 22 Hrs 20 Mins 11 Secs
    patut dicoba,,txs for the info bro:smt023
    ta'lempar ijo2:smt023
    Ja-Pan. Jakarta Panas
    2 Wks 4 Days 16 Hrs 26 Mins 51 Secs
    thanks!nice info!
    -=Gantungan kunci logo mobil, semua merk ada=- Click Here!!
    1 Mth 2 Wks 1 Day 9 Hrs 6 Mins 56 Secs
    Tips yg ok bgt disaat BBM terus naik ini heheh... Thanks
    Jakarta-Bandung pp Via Cipularang
    44 Mins 19 Secs
    Nice info, Thx
    Jakarte Timur
    7 Hrs 53 Mins 14 Secs
    bener koq ini..
    gw selalu isi bensin diatas jam 10 dsaat udara uda dingin..
    beda banget dibandingin pas ngisi bensin dsiang bolong,,
    berasa beda liat meterannya padahal isi di level bensin yang sama, tapi isinya banyakan pas gw isi di malem hari.. misalnya kalo gw ngisi dr strip terakhir, di siang hari jaman premium msh 4500 kmaren100rb strip bensin naek sampe 3/4, tapi kalo dmalam hari bisa lebih naek lg smp 7/8.. Lumayan kan..
    ngisi dmalem hari jg enak koq, ga macet, ga ngantri..irit dah..
    Jakarta Bogor Bandung
    1 Day 20 Hrs 59 Mins 13 Secs
    nice info...
    jakarta yg penuh polusi
    3 Wks 11 Hrs 16 Mins 15 Secs
    wah mesti pagi2 isi bensinnya....
    STICKYTOMS.COM
    2 Mths 5 Days 22 Hrs 43 Mins 28 Secs
    hmm...dipikir2 berarti teknologi penyimpanan bensin masih jelek yah..
Venom 300x250 MBtech
  1. SUV Perang Termahal Dan Tergahar Dari Conquest Vehicles Inc
    Last Post: 28th December 2012, 22:05
  2. TIPS : DO and DON'T
    By coki.de auto in forum de Auto Motorsport
    Last Post: 6th December 2011, 22:49
  3. RESTRICTED TIPS!!!!
    By firecross2999 in forum HID Provision
    Last Post: 22nd September 2010, 15:20
  4. TIPS MAKAN DI ALL U CAN EAT
    By neo_power in forum Automotive
    Last Post: 23rd June 2008, 12:07
