Silikon Motorsport
Sun Air
Tritala CK & DRD Otostereo
Results 1 to 15 of 23
    Colonel
    2 Wks 13 Hrs 12 Mins 6 Secs
    Smile Ultra RARE ONLY 100 PCS ! NOS "Rockford Fosgate POWER 1000 Mosfet TERMINATOR EDITION"
    Ultra RARE ONLY around 100pcs in the WORLD !
    New Old Stock "2pcs of Rockford Fosgate POWER 1000 Mosfet TERMINATOR EDITION"
    The Rockford Fosgate Power 1000 Mosfet "Terminator Edition" (from now on we'll refer to as the 1000C) was a step forward in design from the original Power 1000 Mosfet, which was introduced around 1987. The internals were identical except for the LED meter and removal of the "caboose". The 1000C's chrome appearance and $2650 US MSRP meant this amp was not for your average 16 year old getting a new stereo....it was for serious competitors and those who got had the means to buy such an expensive amplifier. Many Rockford dealers had one or more of these amps in their demo vehicles and most of us could only dream of owning such an amp.
    The 1000C is a four-channel, class A/B amplifier with no internal crossovers. See detailed specs below:
    Power Ratings 2 Channels (Bridged): 500 watts x 2 channels from 20-20,000Hz with less than 0.1% THD
    Power Ratings 4 Channels: 4 Ohms: 150 watts x 4 channels from 20-20,000Hz with less than 0.05% THD; 2 Ohms: 250 watts x 4 channels from 20-20,000Hz with less than 0.1% THD
    Frequency Response: 20-100,000Hz +0.5dB, -3.0dB
    Damping Factor: At circuit board: Over 200 (referred to 4 ohms); At speaker fuse: Over 50 (referred to 4 ohms)
    Signal to Noise Ratio: Over 80dB Unweighted
    Instantaneous Peak Output Current: Over 100 Amperers
    Protection: The Power 1000 is protected by analog computer output protection circuitry and a 100A fuse. A thermal sensor shuts down the amplifier in case of overheating
    Dimensions: 22.75" L x 7.4" W x 3.75" H
    Weight: 21lbs
    MSRP: $2650 US (1991)
    Here is an informational email I received directly from Rockford Fosgate when I inquired about the 1000c Terminator Edition amp:
    “The T1000’s went from the black painted and silkscreened ones with the caboose (that covered the 6ga B+ & Gnd terminal block), then to the black painted and silkscreened ones that no longer had the caboose and just had the one B+ and two GND cables hanging out of it. Then it migrated into a chrome fan shroud. That’s about the time that Wayne Harris came on board with designing the LED output meter for the T1000’s. Then probably in ’92-’93* is when the Terminator Edition hit the market with the special screening and LED display. It was a very limited run….I think maybe only 100pcs or so. I think Wayne had 10 of them for himself.
    http://www.oldschoolstereo.com/2012/...ate-power.html
    GASOLINE AUDIO STATION
    Mega Glodok Kemayoran Lantai 6 Blok F1 no.6
    Jakarta Pusat
    telp : 082123883999
    PIN : 29CC3DCF
    email : gasoline.audiostation@gmail.com
    Gasoline Audio Station link :
    http://www.modifikasi.com/forumdispl...on-Represented
    Colonel
    naik ya bro....!!
    Jakarta Pusat
    telp : 082123883999
    PIN : 29CC3DCF
    First Sergeant
    PASURUAN JATIM HOT LINE (08121656565) new pin bb 281A222B
    2 Days 21 Hrs 25 Mins 31 Secs
    bisa panas dingin liat ni power
    Colonel
    heheheeee,ko har bisa aja,apalagi liat pa43000 nya ko har nie? bisa meriang akut nie ko har,hehehe..........
    Jakarta Pusat
    telp : 082123883999
    PIN : 29CC3DCF
    Colonel
    mari boss...
    Jakarta Pusat
    telp : 082123883999
    PIN : 29CC3DCF
    Colonel
    malem boss
    Jakarta Pusat
    telp : 082123883999
    PIN : 29CC3DCF
    Colonel
    sundul dulu ah
    Jakarta Pusat
    telp : 082123883999
    PIN : 29CC3DCF
    Colonel
    malem-malem tak sundul dulu
    Jakarta Pusat
    telp : 082123883999
    PIN : 29CC3DCF
    Colonel
    naik ya bro
    Jakarta Pusat
    telp : 082123883999
    PIN : 29CC3DCF
    Sergeant First Class
    1 Wk 2 Days 9 Hrs 25 Mins 28 Secs
    PM harganya boleh ga?
  12. #11
    Colonel
    pm sent bro,thanks.....
    Jakarta Pusat
    telp : 082123883999
    PIN : 29CC3DCF
  13. #12
    Colonel
    sundul dulu
    Jakarta Pusat
    telp : 082123883999
    PIN : 29CC3DCF
  14. #13
    Colonel
    sundul dulu deh
    Jakarta Pusat
    telp : 082123883999
    PIN : 29CC3DCF
  15. #14
    Colonel
    pagi
    sunduuul dulu
    pagi
    sunduuul dulu
    Jakarta Pusat
    telp : 082123883999
    PIN : 29CC3DCF
  16. #15
    Colonel
    naik yuk
    Jakarta Pusat
    telp : 082123883999
    PIN : 29CC3DCF
ACM 242x90 Rajawali Autogallery Clean N Tidy
  1. Replies: 13
    Last Post: 20th May 2013, 15:48
  2. WTS: rare item Honda collector ITEM (MUGEN bag's Jordan)only 100 pcs in the world!
    By ockydinata in forum Jual Beli Barang Otomotif Lain-Lainnya
    Last Post: 2nd July 2012, 10:55
  3. Replies: 10
    Last Post: 4th June 2012, 20:36
  4. Jual : Power Rockford Fosgate POWER 300 MOSFET 4 Channel
    By d3cibel in forum Power Amplifier
    Last Post: 26th May 2012, 13:57
  5. Rockford Fosgate POWER T15KW @ $24,999.99 in Action
    By gendutz in forum Diskusi Power Amplifier
    Last Post: 18th November 2007, 09:27
Velgvelg Rajawali Autogallery
