***FIT 700HP K24A***
Results 1 to 10 of 51
  • Short URL:  http://modifika.si/40352
    Jendral Besar
    [ǝƃɐqɹɐƃ ɟo lǝuoloɔ]
    22 Hrs 40 Mins 33 Secs
    Spec
    ERL Performance 2006 K24 engine (2.56L, 9.01 compression ratio; bored 89mm, stroked 102mm); BC 2.6-liter stroker kit, BC2.6 crank (4.016 stroke), stage 2 Forced Induction camshafts (525 lift, 226 deg @ .050 duration); Darton MID Sleeves; balanced and blueprinted rotating assembly; custom JE pistons and rings with double pin oilers, flat bottom dish with matching combustion chambers and accumulator groove featuring 9310 tool seal pins; Stewart Racing Engines High Performance Street Ported head; Ferrea custom modified intake valves, dual spring springs, titanium retainers; Aeromotive A1000 Injected Bypass fuel regulator and Eliminator fuel pump; BDL K Series custom engraved fuel rail, 72mm throttle body with 72mm vacuum spacer, oil cap, and spark plug cover; RC Engineering 1600cc injectors; full return fuel system; Hasport K-Series swap motor mounts; Polished valve cover with Killerglass Pyrex windows; Fujita 4-inch filter and adapter plate; Denso plugs; Koyo aluminum Nissan S13 radiator; Nitrous Express Direct Port nitrous system, Ntercooler, Shark Nozzles, carbon solenoids, 5lb aluminum rollcage bottle mounts; Unorthodox Racing lightweight pulleys; Peak Boost custom aluminum intake manifold, custom equal length tubular top mount turbo manifold, 3-inch aluminum pipe three-row 4-inch core intercooler with Wiggins clamps, and custom exhaust with Magnaflow 3-inch stainless steel tubing; Garrett polished and Jet Hot coated GT35R turbo; TiAL 50mm blow-off valve and 44mm wastegate; Jaz Products fuel cell; ERL-modified S2000 oil pump; B&M oil cooler and relocation kit; Genuine Honda fluids and filters; Optima Blue Top battery
    Drivetrain 2006 Civic Si transmission case; Liberty's High Performance custom four-speed dog and ring style faceplate engagement transmission with Mikronite processed and polished gear set; Driveshaft Shop custom Level 5.9 extreme hubaxle system and five-lug conversion Quaife helical LSD; B&M custom billet short shifter; Unorthodox Racing stage 4 Feramic four-puck unsprung hub and 8lb billet flywheel
    Brains Hondata K-Pro engine management; WORLD Electronics TBC-1 boost controller; Hasport custom chassis harness
    Stiff Stuff Front Megan Racing 32 way adjustable coilover; Rear Big Brother Racing cantilever style suspension with ShowaHonda CBR 600rr motorcycle monoshocks; 2-inches front, 3-inches rear lowering; Time Machine Racecraft custom traction bars with tubular intercooler and radiator mount
    Rollers Work Meister S1 17x8 +14; Toyo Proxes RA-1 23540ZR17 (street); Toyo R888 23545ZR17 (race);
    Stoppers Acura TL Type-S (Brembo OEM) four-piston calipers 12.1-inch front, 11-inch rear rotors; Wilwood dual master cylinders with remote reservoirs and lines; Fast Brakes big brake kit and rear disc conversion; driver adjustable brake bias proportioning lever
    Outside SPS Auto Body 2-inch metal widebody front and rear, shaved gas cap; Couture four-piece GD-R body kit; Carbon Creations GD-R rear wing and hood, and OEM Hatch; PIAA lights; BASF Carizzma colors CZZ-209 Crystal Blue pearl for the Body and CZZ-510 Paradise Blue Pearl for the Cage; Design Haus graphics
    Inside Time Machine Racecraft ten-point chromoly TIG-welded rollcage, stitch-welded chassis, fuel cell mount, rear aluminum door panels and shifter console; Status Racing Carbon Fiber Laguna seats in blue cloth with black on black Gucci design fabric on inserts and front door panels; Takata MPH341 four-point, 3-inch harnesses; Wedge Engineering seat brackets; Team Guarnieri reworked factory dash with 12 Auto Meter Cobalt gauges including 5-inch tach and Digital Pro Shift System; NRG suede steering wheel, Quick Release, and hub adapter; B&M shift knob; D2 Racing air jacks
    Jendral Besar
    KLU SENENG CENDOLIN SAYA AJA~
    :smt002
    jAKARTA
    buset, pgn liat larinya
    @nyam
    doyannya cendol yah? coca cola gw punyanya. mau?^_^
    Jendral Besar
    Quote Originally Posted by gitting44 View Post
    @nyam
    hahahah~
    boleh donk~
    :smt002
    Surabaya - Ambon
    1 Mth 3 Days 21 Hrs 14 Mins 7 Secs
    uda pernah liad.. emang gahar neh.. ckkckckck
    Jakarta^^HP^^0819 3232 999 8
    15 Hrs 51 Mins 1 Sec
    mantap bro....keren nih....kalo dikasi sayap terbang kali ya....hehehe
    Jendral Besar
    Quote Originally Posted by hoehoeman View Post
    oy hoehoe, bagi cendol donk~
    Surabaya - Ambon
    gmn cara nya yeee.. ahuhuahua kolot gw
    Jendral Besar
    di sebelah lampu ijo pnu gua,
    ada timbangan, klik,
    pilih i approve~
    thx hoe hoe~
    :smt002
    Surabaya - Ambon
    ga bisa nih..
    intinya gw harus trima dulu dari orang laen baru bisa kirim lage.. -_-"
    btw, punya lu kok uda ada 3 kotak ijo gitu warna ijo..
    punya gw masi abu2.. napa yah itu
  1. Replies: 167
    Last Post: 12th March 2013, 18:49
  2. WTS: Engine Honda K24A-5 bulet
    By jero in forum Jual Beli Mesin Lainnya
    Last Post: 17th November 2011, 08:22
  3. milih mana budget sama k20a type R ada k24a dioprek2?
    By sardimansanjaya in forum Diskusi Mesin
    Last Post: 13th October 2009, 21:40
  4. tes harga shortblock k24a
    By -oWizz- in forum Jual Beli Mesin Lainnya
    Last Post: 25th July 2009, 19:29
