DIY engine swap
Results 1 to 10 of 10
Thread: DIY engine swap
  • Short URL:  http://modifika.si/4020
    Earth
    1 Day 1 Hr 51 Mins 14 Secs
    DIY engine swap
    penasaran doank nih.. apa aja yg dibutuhin toolsnya.. and where to get them? such as engine lift, etc etc.. thx b4
    eNZed
    8 Hrs 56 Mins 27 Secs
    elo dimana? gw ga lama lagi mo engine swap nih.
    yg lo perlu:
    donor engine, gearbox, wiring looms, ecu (complete kit)
    kalo ga sama seri mesin donor dgn orisinilnya, lo perlu:
    donor engine mountings, drive shafts, probably wheel hubs
    alat2:
    ratchet set, spanner set, punch tools, engine crane, & air tools if u hav access on it.
    basically sih gitu doang.... but i could b wrong.
    mo swap mesin apa nih???
    2 Hrs 59 Mins 27 Secs
    To, percaya gw deh, leave it to the professional. Lo 1 kabel ga kepasang aja, mobil bisa ga nyala, bayangin kalo mau bedah mesin and cangkok mesin....
    eNZed
    kalo mo swap mesin, paling gampang sama yg udah umum, contohnya b-series di EG civic, either hatch or sedan (or coupe). kalo mo simple, cari complete engine swap kit (engine including gearbox/clutch assembly, ecu, wiring loom, engine mounts & brackets, driveshaft & speedometer if needed.
    btw to, gw lg siap2 mo swap mesin nih. hehehe.
    Earth
    sugarfree: mau bujukin bokap cefiro lg neh.. gila aj, cuma 15 juta bro.. probably get something like RB20DET, they're around $2200 for the halfcut from an R32.. tapi bokap ogah ama cefi.. btw, lu skrg pake mobil apa n mau swap ke apa..?
    jtanoyo1: hehe.. klo RB20E ke RB20DET ga susah kan om? wiring diagram sih uda punya, tapi ad yg nyaranin mending wiringnya suruh orang aja.. katanya liat kabel2 banyak gitu bisa langsung botak
    eNZed
    well... kl mo pengalaman sih kerjain sendiri. hehehe. tp emang sih, susa kl lo ga punya pengalaman elektronik ato perkbaelan gitu.
    halfcut brarti dapet ecu jg yah. halfcut mbl apa nih??? rb20det gw rasa sylvia s14. makesure its from a manual halfcut.... jgn yg matic. soalnya ecu-nya beda. this thing applies for all brand of cars.
    Bahamuth
    cefiro juga pake rb20 kan?
    mungkin halfcut dari r32 kali. sekalian aja yg rb25det
    silvia s14 mesinnya sr20de n det, gak ada silvia yg rb kecuali transplant enginenya.
    satyr
    sayang silvia di indo cuma pake sr20de doank (160 hp)
    Earth
    sugarfree: dari R32 wil.. di NZ brapa duit? yup, i'll make sure it's manual
    bahamuth: bener om.. tapi cefiro pake RB20E doank disini, ga ada yg RB20DE ato RB20DET..
    eNZed
    Quote Originally Posted by Pelan²
    oh iya2.... sylvia sr20. lol. im not a nissan guy... so yeah.
    bahamuth: nah loh... dipanggil om..!!! hahahaha. pantes sih. brp tuh rb20 disini??? si edo pasti tau... tanyain gih.
GT Radial NGK Busi
  1. Swap Engine Honda Nova to B-engine
    By soundpump in forum Diskusi Mesin
    Last Post: 29th June 2015, 14:50
  2. Replies: 19
    Last Post: 12th July 2012, 23:45
  3. ENGINE SWAP
    By Alex1 in forum Diskusi Mesin
    Last Post: 30th November 2009, 08:12
