K&N Xstream universal air filter..
Results 1 to 10 of 39
  • Short URL:  http://modifika.si/39455
    Bandung - West java
    2 Hrs 39 Mins 6 Secs
    K&N XStreamŽ Top Universal Air Filters take performance to the next level with the addition of a filter within the filter's top adding more filter area for higher air flow and a longer service interval. The XStreamŽ Air Filter provides awesome air flow and outstanding filtration. When racing, in any environment, racers need all the protection and airflow they can get. K&N delivers. All K&N universal air filters are constructed with ultra-strong molded pliable rubber flanges which absorb vibration and allow for secure attachment and can also be stretched for up to 1/16 inch (1.5mm) to fit in-between sizes. K&N universal air filters are washable and reusable.
    RX-4730 Product Specifications
    Product Style: Round Tapered Universal Air Filter
    Base Outside Diameter: 6 in (152 mm)
    Flange Inside Diameter: 3 in (76 mm)
    Flange Length: 1.875 in (48 mm)
    Flange Type: Centered
    Height: 6.5 in (165 mm)
    Top Outside Diameter: 5 in (127 mm)
    Top Style: X-Stream
    Top Material/Finish: None
    Filter Re-Oiling Amount: 1.17 oz (34 ml)
    Footnote 1: Filter has molded-in velocity stack
    Weight: 1.3 lb (0.6 kg)
    Made in USA
    Status : On stock
    Harga : Rp 1.000.000;
    Udah ga usah coba coba lagi air filter deh beli 1 utk selamanya.
    SS Performance Shop
    Jl. W.R Supratman no.40.bandung.
    Ph : 022-7278335,022-7278337
    Email : ronny@ssperformanceshop.com.
    didalam mobilQu tercinta..
    3 Days 7 Hrs 44 Mins 50 Secs
    sama pipanya ga Om?!?
    Bandung - West java
    Quote Originally Posted by paculbo View Post
    filter aja ga ama pipa.
    SS Performance Shop
    om kalo diameter belakanyanya yg 70 mm ada ga ,soalnya kalo 76 karet sambungan yg utk ke pipa inteknya kg muat om ,kalo ada pm harganya ya om THQ
    Bandung - West java
    Quote Originally Posted by -13- View Post
    ga ada,selama ini kita masang banyak banget ga pernah ada yg mentok boss..
    SS Performance Shop
    Green Garden
    Bos teddy,klo buat bmw e46 bisa nga??waktu kemaren ini kan g kesitu nga ada barang,klo yg ini cocok nga??beda sama yang replacement biasa apa ya??tq...
    Bandung - West java
    Quote Originally Posted by corpus View Post
    ini bukan replacement tapi universal bisa aja pasang di bmw.
    SS Performance Shop
    Bandoenk
    2 Wks 1 Day 17 Hrs 30 Mins 39 Secs
    sori rada oot... bos, kalo pipingnya buat ck4 brapa bos? saya pengen ngitung dulu budget yang diperluin brapa. hehe...
    thanx...
    Bandung - West java
    Quote Originally Posted by evo View Post
    thanx...
    sekitar 400 rb an.
    SS Performance Shop
    Palembang.
    6 Days 10 Hrs 51 Mins 52 Secs
    bos ini inletnya brp inci ?
    SOHC VTEC
Venom 300x250 Mitsubishi
  1. wts filter udara/air filter merek K&N 2nd universal
    By benn_bruce in forum Jual Beli Mesin Lainnya
    Last Post: 10th April 2012, 18:39
  2. WTS - Open filter universal 2nd, OMP box filter ferio
    By redclawer in forum Jual Beli Mesin Lainnya
    Last Post: 27th May 2011, 10:05
  3. WTS : universal air filter
    By dhemus in forum Jual Beli Mesin Lainnya
    Last Post: 9th March 2011, 11:57
  4. filter universal K&N
    By bojji in forum Jual Beli Mesin Lainnya
    Last Post: 21st May 2008, 16:55
