Jual Berbagai Winch WARN Tlp/sms 082391775559 (Hati2 Thread dalam Pengawasan)
Silikon Motorsport
CRC Indonesia
Scuto Laminating Race Chip CS II - Dua Lima Autowork
Kami ingin memberitahukan bahwa Sistem Jual Beli Audio Mobil baru telah kami aktifkan
Untuk informasi lebih lengkap dapat dilihat di http://modifika.si/595332
Results 1 to 10 of 13
  • Short URL:  http://modifika.si/391331
    Giro Point
    8 Hrs 21 Mins 12 Secs
    XD9000i SPECS/PART NUMBERS
    Part Numbers: 27550
    Winch Model: XD9000i
    Rated Line Pull: 9,000 lbs. (4080 kgs) single-line
    Motor: Series Wound 12V 4.6 hp
    Electrical controls: Solenoid
    Remote Control: Remote switch, 12' (3.7m) lead
    Geartrain: 3-Stage Planetary
    Gear ratio: 156:1
    Clutch (freespooling): Sliding Ring Gear
    Brake: Automatic Direct Drive Cone
    Drum diameter/Length: 2.5" /9.0" (6.4cm/23cm)
    Weight: 85 lbs. (38.5kgs.)
    Wire rope: 125', 5/16" dia. (38m, 8mm)
    Fairlead: Roller
    Recommended Battery: 650 CCA minimum for winching
    Battery leads: 2 gauge, 72" (1.83m)
    Finish: Argent Gray Powder Coat
    12V DC PERFORMANCE SPECS
    Line Pull
    Lbs.(Kgs.) Line Speed
    FT./min(M/min.) Motor
    Current Pull by layer
    layer/Lbs(Kgs.)
    0 38 (11.58) 56 amps 1/9000 (4082)
    2000 (910) 15 (6.8) 161 amps 2/8190 (3715)
    4000 (1810) 10.3 (3.14) 252 amps 3/7500 (3402)
    6000 (2720) 7.5 (2.29) 332 amps 4/7010 (3180)
    8000 (3630) 5.1 (1.55) 423 amps
    9000 (4080) 3.9 (1.19) 478 amps
  2. Top 1 Oil
    Giro Point
    WINCH WARN M8274-50 Rp.8.000.000 (NEW) Tlp/sms 082391775559
    M8274-50 SPECS/PART NUMBERS
    Part number: 38631 (12V)
    Part Number: 88631 (12V, CE, International sales only)
    Part number: 375832 (24V) Contact WARN Customer Service for Availability
    Winch model: M8274-50
    Rated line pull: 8,000 lbs., (3628 kgs.) single-line
    Motor: Series Wound, 12V 4.6 hp/3.43kw, 24V 2.5 hp/3.43kw
    Gear train: Spur Gear
    Gear ratio: 134:1
    Clutch (freespooling): Sliding Motor Pinion Gear
    Brake: Automatic disc type
    Drum diameter/Length: 3.5"/8.5" (9cm/22cm)
    Weight: 110 lbs. (50kgs.)
    Wire rope: 150' ft, 5/16" diameter (46m, 8mm diam.)
    Fairlead: Roller
    Finish: Powder coat with clear coat
    Line Pull
    layer/Lbs(Kgs.)
    0 79.3 (22.17) 49 amps 1/8000 (3629)
    2000 (910) 23.7 (7.22) 182 amps 2/7460 (3384)
    4000 (1810) 16.4 (5.0) 286 amps 3/6980 (3166)
    6000 (2720) 12.0 (3.66) 385 amps 4/6620 (3003)
    8000 (3630) 8.7 (2.65) 480 amps 5/6290 (2853)
    24V DC PERFORMANCE SPECS
    Line Pull
    layer/Lbs(Kgs.)
    0 65 (19.8) 24 amps 1/8000 (3629)
    2000 (910) 23 (7.01) 96 amps 2/7460 (3384)
    4000 (1810) 17 (5.18) 149 amps 3/6980 (3168)
    6000 (2720) 13 (3.96) 203 amps 4/6620 (3005)
    8000 (3630) 7.9 (2.41) 273 amps 5/6290 (2855)
    Siap Kirim Seluruh INDONESIA
    Giro Point
    Winch WARN M8000 Rp.5.000.000 (NEW) Tlp/sms 082391775559
    M8000 SPECS/PART NUMBERS
    Winch model: M8000
    Part number: 26502 (wire rope, 12V)
    Part Number: 88502 (wire rope, 12V, CE, International sales only)
    Part Number: 265032 (wire rope, 24V)
    Rated line pull: 8,000 lbs., (3630 kgs.) single-line
    Motor: Series Wound, 12V 4.8 hp, 24V 2.1 hp,
    Electrical controls: Contactor
    Gear train: 3-Stage Planetary
    Gear ratio: 216:1
    Clutch (freespooling): Sliding ring gear
    Brake: Automatic mechanical cone
    Drum diameter/Length: 2.5"/9.0" (6.4cm/23cm)
    Weight: 74 lbs. (34 kgs)
    Rope: Steel -- 100', 5/16" diam. (30m, 8mm diam.)
    Fairlead: Roller
    Finish: Argent gray powder coat
    Line Pull
    layer/Lbs(Kgs.)
    0 30.2 (9.20) 80 amps 1/8000 (3629)
    2000 (910) 14.2 (4.33) 200 amps 2/7280 (3302)
    4000 (1810) 9.9 (3.02) 285 amps 3/6670 (3026)
    6000 (2720) 7.3 (2.22) 350 amps 4/6230 (2826)
    8000 (3630) 4.8 (1.46) 435 amps
    Line Pull
    layer/Lbs(Kgs.)
    0 27.3 (8.32) 46 amps 1/8000 (3629)
    2000 (910) 17.1 (5.21) 99 amps 2/7460 (3384)
    4000 (1810) 12.6 (3.84) 145 amps 3/3980 (3166)
    6000 (2720) 10.3 (3.14) 190 amps 4/6620 (3003)
    8000 (3630) 8.8 (2.68) 235 amps
    Giro Point
    Winch WARN M6000 Rp.4.000.000 (NEW) Tlp/sms 082391775559
    M6000 SPECS/PART NUMBERS
    Part Number: 45880 (12V)
    Part Number: 465052 (24V) Contact WARN Customer Service for Availability
    Rated line pull: 6000 lbs. (2720 kgs.) single-line
    Remote Control: Remote switch, 12 ft (3.7m) lead
    Gear ratio: 156:1
    Drum diameter/Length: 2.5 in/9.0 in (6.4cm/23cm)
    Weight: 74 lbs. (34kgs.)
    Wire rope: 80 ft, 5/16 in diameter (24m, 8mm diam.)
    Fairlead: Roller
    Battery leads: 2 gauge, 72 in (1.83m)
    Line Pull
    layer/Lbs(Kgs.)
    0 48.5(14.8) 85 amps 1/6000(2722)
    2000(910) 23.7(7.22) 175 amps 2/5460(2477)
    4000(1810) 12.9(3.93) 360 amps 3/5000(2268)
    6000(2720) 10.0(3.05) 465 amps 4/4670(2118)
    Line Pull
    layer/Lbs(Kgs.)
    0 37.1(11.31) 46 amps 1/6000(2722)
    2000(910) 20.3(6.19) 121 amps 2/5460(2477)
    4000(1810) 14.4(4.39) 185 amps 3/5000(2268)
    6000(2720) 11.2(3.41) 249 amps 4/4670(2118)
    Giro Point
    Winch WARN 9.5xp Rp.6.000.000 (NEW) Tlp/sms 082391775559
    9.5XP SPECS/PART NUMBER
    Winch model: 9.5xp
    Part number: 86500 (wire rope, CE)
    Rated line pull: 9,500 lbs., (4310 kgs.) single-line
    Motor: 12V 6 hp (4.48kw), High output parallel series wound
    Remote controls: Remote switch, 12' (3.7m) lead and
    Geartrain: 3-stage planetary
    Gear ratio: 156:1
    Brake: Automatic direct drive cone
    Rope: Steel - 100', 5/16" diameter (30m, 8mm diam.)
    Fairlead: roller fairlead
    Recommended battery: 650 CCA minimum for winching
    Finish: High-gloss powder coat over primer undercoating
    Weight: 87 lbs. (39.5 kgs)
    Line Pull
    layer/Lbs(Kgs.)
    0 38 (11.6) 70 amps 1/9500 (4313)
    2000 (910) 16.8 (5.1) 175 amps 2/8650 (4927)
    4000 (1810) 12.8 (3.9) 262 amps 3/7920 (3595)
    6000 (2720) 10.1 (3.1) 335 amps 4/7400 (3359)
    8000 (3630) 8.8 (2.7) 425 amps 5/6940 (3150)
    9500 (4310) 7.6 (2.3) 480 amps
    Giro Point
    Winch WARN 9.0Rc Rp.6.800.000 (NEW) Tlp/sms 082391775559
    9.0Rc SPECS/PART NUMBER
    Winch Model: WARN 9.0Rc
    Part Number: 71550
    Gear ratio: 216:1
    Brake: Automatic mechanical cone brake
    Drum diameter/Length: 2.75 in/4.75 in (7.0cm/12cm)
    Weight: 54 lbs. (24.8kgs.)
    Rope: 50 ft, 3/8 in (15m, 9.5mm) Synthetic Rope
    Fairlead: Polished Aluminum Hawse
    Finish: Gloss red paint over primer undercoating
    PERFORMANCE SPECIFICATIONS
    Line Pull
    layer/Lbs(Kgs.)
    0 32 (9.75) 85 amps 1/9000 (4082)
    2000 16 (4.88) 187 amps 2/7280 (3302)
    4000 11.4 (3.47) 284 amps 3/6670 (3026)
    6000 8.9 (2.71) 367 amps 4/6230 (2826)
    8000 6.8 (2.07) 458 amps
    9000 5.6 (1.70) 408 amps
    Giro Point
    Winch WARN 9.5cti Rp.6.500.000 (NEW) Tlp/sms 082391775559
    9.5cti SPECS
    Winch model: 9.5cti
    Part numbers: 95000
    Rated line pull: 9,500 lbs., (4310 kgs) single-line
    Motor: Series wound
    Remote Controls: Remote switch, LED indicator, 12' (3.7m) lead and hand-held wireless
    Geartrain: 3-Stage planetary
    Gear ratio: 156:1
    Drum diameter/Length: 2.5"/9.0" (6.4 cm/23 cm)
    Weight: 89 lbs. (36.3 kgs)
    Rope: Steel - 125', 5/16" diameter
    Fairlead: roller
    Line Pull
    layer/Lbs(Kgs.)
    0 62 (18.9) 47 amps 1/9500 (4313)
    2000 (910) 16.3 (4.97) 160 amps 2/8650 (3927)
    4000 (1810) 11.8 (3.60) 230 amps 3/7920 (3595)
    6000 (2720) 9.31 (2.84) 305 amps 4/7400 (3359)
    8000 (3630) 7.59 (2.31) 370 amps 5/6940 (3150)
    9500 (4310) 6.67 (2.03) 425 amps
    Giro Point
    Winch WARN PowerPlant HP Rp.9.500.000 (NEW) Tlp/sms 082391775559
    POWERPLANT HP SPECS/PART NUMBER
    Winch Model: PowerPlant HP
    Part Number: 71800 (12V)
    Rated Line Pull: 9,500 lbs. (4310 kgs) single-line
    Motor: Series-wound 4.6 hp 12V, with thermal protection shutoff switch
    Remote Control: Remote switch with thermometric LED and 12' (3.7m) lead
    Gear train: 3-stage planetary
    Gear ratio: 156:1
    Wire rope: 125' of 5/16" (38m of 8mm diam.)
    Fairlead: Roller
    Finish: High-gloss black powdercoat
    Drum diameter/Length: 2.5"/9" (6.4cm/23cm)
    Weight: 100 lbs (45 kgs)
    Air Reservoir: 1/2 gallon tank with Integrated Air Intercooler
    High Air Flow Rating: 12 CFM @ 0 psi, 5 CFM @ 90 psi
    Max Air Pressure: 100 psi
    Air Pressure Switch: Yes
    Air Hose: 12' nylon, with quick-disconnect. Brass air fittings and couplings
    Line Pull
    layer/Lbs(Kgs.)
    0 28.8 (8.78) 94 amps 1/9500 (4313)
    2000 (910) 16.4 (4.50) 165 amps 2/8650 (4927)
    4000 (1810) 12.3 (3.75) 238 amps 3/7920 (3595)
    6000 (2720) 9.5 (2.90) 307 amps 4/7400 (3359)
    8000 (3630) 7.5 (2.29) 383 amps 5/6940 (3150)
    9500 (4310) 6.2 (1.89) 451 amps
    City of Smiling People
    Giro Point
    3 Mths 2 Wks 6 Days 9 Hrs 31 Mins 12 Secs
    Sadis om ... jualannya keren semua ... murah lagi dibanding harga pasaran ...
    tapi kok agak2 ...
    nunggu om ads ah ...
    Bisa minta alamat lengkapnya nya om ?
    Giro Point
    1 Hr 23 Mins 44 Secs
    Quote Originally Posted by voidzzz View Post
    tapi kok agak2 ...
    pengen tau beneran ada ga sih nih toko, kalo ada surga dunia offroad kita...
  1. Replies: 51
    Last Post: 12th July 2013, 23:28
  2. Replies: 4
    Last Post: 6th February 2013, 09:46
  3. Wts : Winch WARN 9.5ti
    By thewho in forum Bursa Eksterior Lainnya
    Last Post: 14th April 2011, 21:47
  4. WTB: Winch Warn
    By Coffee_Late in forum Bursa Eksterior Lainnya
    Last Post: 18th February 2011, 19:17
Tritala
