For Sale SONY XEC-1000 ( Masterpiece of SONY Electronic Crossover) kondisi muluuuuuss
SONY XEC-1000 ( Masterpiece of SONY Electronic Crossover) kondisi muluuuuuss.....
The XEC-1000 is Sony's electronic crossover masterpiece.
The XEC-1000 can control up to five amplifiers and bring the sounds in your car audio system together in a symphonic convergence.
The 3-way crossover network is designed to control a subwoofer amp plus two midrange amps and two tweeter amps.
You get three pairs of inputs and five pairs of outputs.
Each pair of outputs has a separate level control.
The subwoofer output includes a phase switch, a mono/stereo switch, and an adjustable bass boost at 40 Hz.
Low-pass crossover points for subwoofer are 50/80/120/180 Hz.
Bandpass frequencies front and rear are between 80/120/180Hz and 2.4k/3.5k/5kHz.
There is also an adjustable midrange cut at 180 Hz to help you flatten unwanted peaks in the response curve. High-pass frequencies front and rear are 2.4k/3.5k/5k/7kHz,
and you get tweeter phase switches for front and rear.
(10-1/4"W x 1-5/8"H x 7-7/8"D.)
Features :
ELECTRONIC CROSSOVER, 10 CHANNEL 3-WAY Front & Rear
10-Channel 3-Way Front & Rear
Independent Hi and Low Pass Frequencies
5 Output Level Controls
Low and Mid Equalization
Front, Rear, and Sub Inputs
Specifications :
Low Frequency response: 50 Hz
High Frequency Response: 7000 Hz
