Everything about MITSUBISHI ENGINE (CODE)
  • Short URL:  http://modifika.si/3885
    3 Hrs 56 Mins 16 Secs
    The number and lettering system of Mitsubishi engines can be a little
    confusing, so here is how to decipher them:
    Numerical Prefix -
    4 = four cylinder
    6 = six cylinder
    Numerical Suffix -
    12 = 2.0 litre
    13 = 2.5 litre
    36 = 2.0 litre
    54 = 2.6 litre
    61 = 1.6 litre
    62 = 1.85 litre
    63 = 2.0 litre
    64 = 2.4 litre
    72 = 3.0 litre
    73 = 2.5 litre
    74 = 3.5 litre
    91 = 1.5 litre
    92 = 1.6 litre
    93 = 1.8 litre
    Sixes
    The entire range of high performance Mitsubishi sixes is set in a V
    configuration. Starting off with the most powerful, the 6G72 twin turbo
    engine is responsible for pushing the heavy 3000GT/GTO to 100 km/h in
    around five seconds. Its attributes are a displacement of 3.0 litres,
    8.0:1 compression, quad cams, 24 valves, twin (simultaneous) turbos, dual
    air-to-air intercoolers and a sophisticated EFI system - all giving a
    total output of 209kW at 6000 rpm, with a bag of 427Nm at only 2500 rpm!
    Now that would make one awesomely flexible road-car engine! In Japan,
    development of this engine has been quite minor in comparison to the
    Nissan RB26DETT, but we'd expect that you could attain around 300kW with
    simple exhaust, intake, intercooler and boost modifications.
    A high performance naturally aspirated version of this engine (also
    called the 6G72), is available minus all the turbo intake trickery, but
    with a higher static compression ratio of 11.0 to help compensate. It
    makes 179kW at 5750 and 304Nm at 3500. A lower spec trim again can be
    found, which is good for 168kW and 275Nm, and yet another (as in the
    Japanese Diamante/Magna) is capable of 127kW and 248Nm.
    About 17% larger at 3.5 litres, the DOHC 6G74 turbo comes suitable for
    front and all-wheel-drive and produces 194 kW at 6000 rpm.
    The Japanese market Diamante is also powered by a 10.0:1 compression
    ratio atmospherically inducted 6G74 3.5 litre, that produces 194kW at
    6000 and 324Nm at 4500 rpm. In between the 3.0 and 2.0 V6s is the 6G73
    2.5 litre motor. Available in FWD atmo form only, this DOHC powerplant
    shares its basic design with the other engines in the 6G range, and is
    good for 131kW at 6000 revs.
    A way - other than by turbocharging - that Mitsubishi has been able to
    develop big power from their engines has been through the use of the
    latest MIVEC (Mitsubishi Innovative Valve and Lift Electronic Control
    System) technology. This system employs a multi-mode variable valve
    timing mechanism set in three modes - low speed, high speed and MD
    (modulated displacement). The resulting optimised flow of gas through the
    heads enables these engines to deliver a substantial increase in torque
    across the entire rev range - but especially in the higher revs, where
    conventional engines are usually set with conservative valve lift and
    duration.
    Displacing only 2 litres, the atmo MIVEC version of the 6A12 DOHC V6 with
    its 10.0:1 compression ratio is listed at an impressive 149kW at 7500 rpm
    and 200Nm at 6000. This engine is most widely-noted for its fitment to
    the sexy looking Mitsubishi FTO, which it powers from 0-100 km/h in under
    8 seconds. There's also another atmo 6A12 engine (in either FWD or AWD
    configuration) that is the same as above but minus the MIVEC system and
    some compression points. It is capable of delivering a total of 127kW at
    lower revs
    A turbo version of the non-MIVEC 6A12 engine was released too, which
    could pull 149kW - the same peak power as the wonderful atmo inducted
    MIVEC!
    Fours
    Mitsubishi's selection of four cylinders is where the company has earned
    the majority of its performance reputation.
    One of the old-school engines Mitsubishi produced in the 80s is the SOHC
    injected G63B turbo. This engine came available in a number of different
    specs, but the most desirable is the 3 valves per cylinder 2 litre DASH
    engine which came in either FWD and RWD guise. This non-intercooled
    engine was able to stomp out a creditable 149kW at 6000 rpm and 280Nm of
    torque.
    However, the more common version of this engine (also called the G63B) is
    the 2 valves per cylinder SOHC as found in the Starion/Conquest. This is
    still capable of a reasonable 131kW at 5500 rpm and 216Nm at 3500 rpm.
    At about the same time (the early 80s) the Mitsubishi Cordia GSR hit the
    streets with very similar technology to the G63B - albeit in a smaller
    overall package, called the G62B. This 1.85 litre SOHC four was also
    non-intercooled (like most turbos of the time), and in the ultimate
    versions used a large capacity turbocharger to help it on the way to a
    maximum of 119kW at 5800 rpm and 216Nm at 3500.
    The next generation of Mitsu fours was all based on the same blocks as
    those mentioned above, but sported DOHC heads to aid breathing. Amongst
    this late-80s group of engines is the front wheel drive 4G36 that came in
    some of the mid/compact size vehicles, sweeping a volume of 2.0 litres
    and producing 104kW at 6000 rpm.
    One of the engines most widely used in competition (especially rally) is
    the DOHC 4G63 turbo engine. Available in a variety of specs, this engine
    comes in 2.0 litre capacity and is good for up to 209kW at 6500rpm, and
    373Nm at 3000 in the Evolution 6.
    Released in both FWD and 4WD configurations, the double over head cam
    4G93 atmo and turbo moves 1.8 litres, and generates 112kW at 6500 and
    145kW at 6000 rpm respectively. One power-pack for the compact
    Japanese-spec Lancer GSR hatches was the 4G61 engine that pushed around
    1.6 litres, used DOHCs and a single intercooled turbo to create a maximum
    of 108kW at 6000 revolutions. A smaller engine, the 1.5 litre DOHC 4G91,
    was a front-wheel-drive-only engine that was designed for use in
    hatchbacks, mustering up 86kW at 6000 revs with a peak of 137Nm of
    torque.
    The latest MIVEC four cylinder is becoming quite popular in Japan (the
    only country where it is commercially available), and is an optional
    fitment to the Mirage, FTO and Lancer. The engine we're interested in
    here is the 1.6 litre 4G92 front wheel drive, that's good for an
    astounding 131 kW at a substantial 7500 revs per minute, plus 167Nm of
    torque at a sky-high 7000. This awesome little engine therefore has a
    specific power output of 81.8kW per litre - enough to rival even some of
    the best of the current turbo engines!
    Mitsubishi performance motors at a glance...
    Sixes
    6G74 3.5 DOHC turbo
    194kW
    6G74 3.5 DOHC 194kW
    6G72 3.0 DOHC twin turbo 209kW
    6G72 3.0 DOHC 179kW/127kW
    6G73 2.5 DOHC 131kW
    6A12 2.0 DOHC MIVEC 149kW
    6A12 2.0 DOHC turbo 149kW
    6A12 2.0 DOHC 127kW
    Fours
    4G63 2.0 DOHC turbo 164kW
    G63B DASH 2.0 SOHC 12 valve turbo 149kW
    G63B 2.0 SOHC turbo 131kW
    G62B 1.85 litre SOHC turbo 119kW
    4G64 2.4 SOHC 108kW
    G54B 2.6 SOHC turbo 131kW
    4G91 1.5 DOHC 86kW
    4G92 1.6 DOHC MIVEC 131kW
    4G93 1.8 DOHC 112kW
    4G93 1.8 DOHC turbo 145kW
    4G36 2.0 DOHC 104kW
    4G61 1.6 DOHC turbo 108kW
    4g32 - 1600cc
    4g33 - 1800cc
    4g34 - 1400cc
    MORE:
    Example: 4G61T (1.6L I4 turbo motor in the Colt/Mirage turbo)
    4 = 4-cylinder
    G = Gasoline, Iron Block. (D = Diesel ie 4D65)
    6 = Engine Series
    1 = Engine Model (Doesn't equate to capacity, as a higher number can
    belong to a lesser cc'd engine.)
    T = Turbo (This is more of an adopted addition to the engine codes,
    rather than an official part of it. The official way Mistubishi will list
    the motor is "4G61 Turbo".)
    Example: 6A13TT (2.5L V6 twin-turbo motor in the Galant/Legnum VR-4)
    6 = 6-cylinder
    A = Gasoline, Aluminum block
    1 = Engine Series
    3 = Engine Model
    TT= Twin-turbo
    Mitsubishi Engine Code Reference Chart
    4D55 - 2.3L. Found in Galant 2.3 TD (A167) as well as Pajero (Shogun) 2.3
    TD
    4D56 - 2.5L. Used in Pajero (Shogun) 2.5 TD (L049G)
    4D65 - 1.8L. Found in Galant 1.8 TD (E34A)
    4D68 - 2.0L, 1998cc
    4G11 - 1.2L, 1244cc
    4G12 - 1.4L, 1410cc
    4G13 - 1.3L, 1248cc
    4G15 - 1.5L, 1468cc
    4G16 - 1.2L, 1198cc
    4G18 - 1.6L, 1583cc
    4G30 - 1.3L, 1298cc
    4G31 - 1.5L, 1499cc
    4G32 - 1.6L, 1597cc
    4G33 - 1.4L, 1439cc
    4G35 - 1.7L, 1686cc
    4G36 - 1.2L, 1238cc
    4G37 - 1.8L, 1755cc
    4G41 - 1.4L, 1378cc
    4G42 - 1.2L, 1187cc
    4G51 - 1.9L, 1855cc
    4G52 - 2.0L, 1995cc
    4G53 - 2.4L, 2384cc
    4G54 - 2.6L, 2555cc
    4G61 - 1.6L, 1597cc. Came available with turbo and naturally aspirated
    versions. Most are DOHC, but apparently SOHC versions were used.
    4G62 - 1.8L, 1795cc
    4G63 - 2.0L, 1997cc. Came available with turbo and naturally aspirated
    4G64 - 2.4L. Mostly available as a SOHC, there are DOHC versions
    available.
    4G67 - 1.8L, 1836cc
    4G69 - 2.4L. Motor is a SOHC MIVEC
    4G92 - 1.6L, 1597cc. Known commonly for it's DOHC MIVEC version used in
    the Mirage.
    4G93 - 1.8L, 1834cc. Available as a non-turbo SOCH and DOHC. DOHC turbo
    version was available in '92+ Lancer GSR.
    4G94 - 2.0L. Newer SOHC motor used in the Lancer.
    6A10 - 1.6L
    6A11 - 1.8L
    6A12 - 2.0L. Mostly known to be a DOHC MIVEC used in the FTO. Was also
    availabe in a twin-turbo version in the early 7G Galant VR-4's.
    6A13 - 2.5L. Was commonly a DOHC twin-turbo motor used in the more modern
    7G and 8G Galant VR-4's.
    6G71 - 2.0L, 1998cc. Only known variant is SOHC and supercharged.
    6G72 - 3.0L, 2972cc. This motor came in various forms, including SOHC and
    DOHC naturally aspirated versions. A DOHC twin-turbo version was also
    available in the 3000GT/GTO VR-4.
    6G73 - 2.5L, 2497cc. Available naturally aspirated in SOHC and DOHC form.
    6G74 - 3.5L. Available naturally aspirated in SOHC and DOHC form.
    6G75 - 3.8L. Available naturally aspirated in SOHC and DOHC form.
    G15B - 1.5L SOHC 12v Carb found in early Mirage and Precis.
    G32B - 1.6L. Came as a SOHC turbo.
    G54B - 2.6L. Found in early Montero and Truck.
    G62B - 1.8L. Came as a SOHC turbo.
    G63B - 2.0L. Came as a SOHC sometimes with turbo. Found in JDM Starion as
    well as the Cordia and Tredia.
    G63B - 2.4L. SOHC found on the early Galant and Expo.
    Lancer 4g63T AWD MANTAP 11.4s 346WHP
    Galant 4g63T AWD MANTAP 11..s 423WHP
    Galant 6a13 std+unichip 190HP 250Nm
    4 Wks 14 Hrs 24 Mins 14 Secs
    Maaf om herman, newbie mau nanya. Jadi mesin mitsu yang paling kuat dan keceng yang mana om ? kalo mesin 4G63t vs 6G75 vs 4b11t yang paling kuat/kenceng yang mana ya ? kalo duitnya gak terbatas. (padahal saya kere)
NGK Busi GT Radial
  1. Replies: 1424
    Last Post: 3rd May 2018, 13:59
  2. (ASK) Supra Engine Code 2JZ-GTE
    By Mad_MAX in forum Diskusi Mesin
    Last Post: 4th February 2013, 01:41
  3. engine code nissan livina & sentra & latio
    By [Ctrl]+[Alt]+[Del] in forum Diskusi Mesin
    Last Post: 4th November 2009, 15:42
  4. WTA: mitsubishi engine series Confuse
    By vosso in forum Merk Lainnya
    Last Post: 6th June 2009, 22:13
  5. Honda Engine Code
    By Super Bejo in forum Diskusi Mesin
    Last Post: 19th December 2005, 11:43
