History About Mazda Engine Family - Page 2
Page 2 of 168 FirstFirst 123456 ... LastLast
Results 11 to 20 of 1678
  • Short URL:  http://modifika.si/3874
  2. #12
    jakarta, malang, mataram
    9 Mins 37 Secs
    V6 Overview mazda_logo.gif (1375 bytes)
    The V6 configuration appears in 1.8, 2.0, 2.25 and 2.5 litre displacements.
    - 2.25V6 - worlds only Miller-Cycle (MC) as opposed to Otto-Cycle engine, using an 8 to 1 compression ratio with 10 to 1 power ratio for improved power to fuel consumption ratio. The MC uses a twin-intercooled Lysholm-screw Autorotor supercharger (the worlds most compact & most efficient) to deliver 210-230lb/ft at 3500rpm with 0-60 of 7.9secs from the 4-speed ATX, power of a 3.2-3.5V6, yet fuel economy of a 2.1V6.
    - 2.5V6 - two variations of the 2.5V6 exist, as well as a Twin-Turbo form. The KL form is a detuned variant of the KL-ZE, offering power & fuel economy of a 2.2V6 (based on output of the 2.0V6). The KL-ZE is the 200bhp sports 2.5V6, achieving up to 94bhp/litre without expense of VVT.
    Picture Courtesy of Dimas (Sephiro), 94 Ford Probe GT
    - All V6s - all Normally Aspirated V6s feature a Variable Resonance Intake System (VRIS), the same concept as later used by Porsche on their 3.6 and Ferrari in much more sophisticated form on their V12. VRIS was first used by Mazda in their older 158bhp 2.0i-16 UK engine in 1989 and ensures the widest possible area under the torque curve rather than a purely headline peak figure. The VRIS efficiency contributes to the V6s noted low fuel consumption, with the 7500rpm (2.5) or 7800rpm (2.0) limits rarely being called upon, and averages of 27-29mpg (imperial) in urban driving and up to 32-36mpg (imperial) highway being the norm.
    Engine Architecture
    V6 engines are all-alloy DOHC 24V 60-degree-V6. A split-crankcase (as 911 flat-6) is used offering exceptional rigidity over traditional bearing-cap solutions and not only to high-rpm capability as proved in SuperTouring Car racing in up to 430-480bhp N/Aspirated form, but also reducing NVH data to set a benchmark in 1992 winning German engine awards. Bearings are four 4-bolt mains, with a further pair of bolts at each bearing section, key journals & bearings are oversized, bearings themselves are triple-layer heavy-duty spec. Crankshaft is forged, nitrided, triple-lapped, mirror finished. Piston squirters in upper bearing journals aid cooling. Exhaust valves are stainless steel. Pistons & rods are lightweight to reduce reciprocating mass, and the very short-stroke design aids longevity considerably. Piston skirts are Moly coated.
    Piston & ring velocities are lower than those for the I4 engines. Quantitatively, the 2.5V6 Mean Piston Speed (MPS) is a very low 3170ft/min at redline and the 2.0I4 MPS is 3928ft/min at redline, the V6s very short stroke producing low crank angles thus minimising main & rod bearing load. For rings the 2.5V6 uses 1.5mm top ring allowing a Maximum Piston Acceleration (MPA) of 77,000ft/sec^2, yet the engine at redline experiencing an MPA of only 51,354ft/sec^2. The 2.0I4 uses a 1.17mm top ring allowing a Maximum Piston Acceleration (MPA) of 105,000ft/sec^2, with the engine at redline experiencing an MPA of 70,157ft/sec^2. Both engines have exceptional design margins, the V6 is particularly under-stressed even in KL-ZE form.
  3. #13
  4. #14
    9 Mins 37 Secs
    MAZDA HISTORY
    Mazda History
    1967
    Mazda builds its first rotary vehicle, the 110S Cosmo Sport.
    1968
    Vehicle sales begin in Canada with the R100 coupe.
    1970
    Mazda establishes Mazda Motor of America (N.W.), Inc.
    Vehicle sales in the U.S. begin with the R100 coupe, the first mass-produced rotary-powered car in America.
    1971
    Mazda debuts the rotary-powered RX-2.
    1972
    Mazda Technical Center (MTC) and Toyo Kogyo U.S. Representative office (TKUS) established.
    Mazda debuts the piston-engine 808 sedan, coupe, and wagon.
    Mazda debuts the rotary-powered RX-3.
    1973
    Mazda RX-3 becomes the first vehicle in the world to pass strict new U.S. standards for regulating exhaust emissions.
    1974
    Mazda debuts the RX-4.
    1975
    Mazda Motor of America (Central), Inc. established.
    1977
    Introduction of the Mazda GLC "Great Little Car."
    1978
    Mazda introduces the rotary-engined RX-7 sports car.
    Mazda introduces the 626 series.
    Introduction of the Mazda B2000 compact pickup truck.
    1979
    Ford Motor Company purchases a 24.5 percent stake in Mazda Motor Corporation.
    1980
    Mazda introduces the front-wheel-drive Mazda 323.
    1981
    MTC and TKUS merge to form Mazda (North America), Inc. (MANA).
    1982
    Introduction of the front-wheel-drive 626.
    Mazda sells its one-millionth passenger car in the U.S.
    1983
    MANA opens Detroit office to conduct EPA emission testing and trend research.
    Mazda RX-7 named as a Car and Driver "10Best."
    Mazda 626 is awarded Motor Trend "Import Car of the Year."
    1984
    Mazda announces plans to build an assembly plant in Flat Rock, Michigan.
    Mazda changes its company name from Toyo Kogyo Co., Ltd. to Mazda Motor Corporation.
    Mazda 626 named as one of Car and Driver "10Best."
    1985
    Mazda Motor Manufacturing (USA) Corporation (MMUC) holds groundbreaking ceremony for new Flat Rock plant.
    Mazda introduces second-generation RX-7.
    Introduction of the completely redesigned B-Series Truck.
    1986
    Specially prepared Mazda RX-7 sets land speed class record of 238.442 miles per hour at Bonneville National Speed Trials.
    Mazda RX-7 is awarded Motor Trend "Import Car of the Year" and "Best New Sports Car" by the Automobile Journalists Association of Canada.
    1987
    Mazda introduces the MX-6 sports coupe and restyles the 626 series.
    Assembly of the Mazda MX-6 begins in Flat Rock. In little more than a year, MMUC fulfills virtually all North American demand for the MX-6.
    Mazda RX-7 Turbo named as a Car and Driver "10Best."
    Mazda introduces the 929 luxury sedan, giving the company a complete line of vehicles for its North American customers.
    1988
    MMUC commences assembly of the Ford Probe and announces plans to export the Probe model to Japan for sale through Mazda’s Autorama dealer network. Export of the MX-6 to Taiwan and Canada follows.
    Mazda dedicates all-new $23 million R&D center in Irvine, California.
    Mazda’s U.S. operations undergo reorganization, with the consolidation of Mazda Motor of America (Central), Inc. and Mazda Motor of America (East), Inc. into Mazda Motor of America, Inc. (MMA), and the creation of Mazda Research & Development of North America, Inc. (MRA).
    Introduction of the MY1989 Mazda MPV minivan.
    1989
    Mazda introduces the MX-5 Miata sports car as a 1990 model.
    Introduction of the all-new 323 3-door hatchback and 1990 Mazda Protegé, which replaces the Mazda 323 sedan.
    Assembly of the Mazda 626 4-door sedan begins at MMUC.
    MX-5 Miata named as one of the five "World’s Best Cars" by Road & Track.
    MPV named "Best New Van" by Automobile Journalists Association of Canada.
    1990
    Formation of Mazda Systems Services of North America, Inc. (MSS) in Flat Rock.
    MRA Flat Rock expansion to include testing for local parts development.
    MX-5 Miata and MPV each receive a "10Best" award from Car and Driver.
    Mazda enters the U.S. sport-utility market segment with the 2-door Mazda Navajo.
    MPV 4WD named "Best New Van" by Automobile Journalists Association of Canada.
    MX-5 Miata receives "Automobile of the Year" award from Automobile Magazine.
    1991
    MX-5 Miata and MPV 3.0-liter V6 each receive a Car and Driver "10Best" award.
    Agreement with Ford Motor Company to develop and manufacture a new Mazda compact B-Series Truck for the North American market, starting in 1993.
    Introduction of the all-new MY1992 Mazda 929 luxury sedan and MX-3 sports coupe, the first in its class offered with a 1.8-liter V6 engine, the smallest V6 in mass production.
    MX-3 awarded "Best New Sports Car" by Automobile Journalists Association of Canada.
    One-millionth Mazda B-Series Truck sold in the U.S.
    Automobile Magazine names MX-5 Miata to its "All-Star" list.
    RX-7 wins "Best New Performance Car" by Automobile Journalists Association of Canada.
    Mazda’s four-rotor 787B wins Le Mans, becoming the first and only Japanese manufacturer to win this famous endurance race.
    1992
    Introduction of the MY1993 RX-7.
    Opening of the new $9 million MRA/MSS building in Flat Rock.
    MMUC becomes a joint venture between Mazda and Ford Motor Company, named AutoAlliance International, Inc. (AAI).
    Assembly of the all-new 1993 Mazda MX-6, 626, and Ford Probe begins at AAI.
    Completion of MANA’s Quality Research Building and the $25.6 million Woodhaven Inland Port facility in Woodhaven, Michigan.
    Mazda MX-6 and 626 classified as a domestic fleet under EPA guidelines.
    MX-5 Miata receives a "10Best" award from Car and Driver.
    1993
    Assembly of the one-millionth vehicle at AAI.
    Introduction of Mazda’s all-new MY1994 B-Series Truck, assembled in Edison, New Jersey.
    1994
    Introduction of the 1995 Mazda Millenia, an all-new luxury sedan.
    Introduction of the high-output, fuel-efficient Miller-cycle engine (in the Millenia S), the first automotive application of Miller-cycle technology.
    Mazda sets sixth year of record passenger car sales in the United States.
    Mazda introduces the MY1995 Protegé, featuring OptiSpace design.
    1995
    Mazda RX-7 receives fifth "10Best" award from Car and Driver.
    Automobile Magazine names MX-5 Miata and Millenia to its "All-Star" list.
    Millenia S named "Best New Luxury Car" by Automobile Journalists Association of Canada.
    Millenia S Miller-cycle engine named as one of the "Best Engines" by Ward’s Auto World.
    1996
    J.D. Power and Associates Initial Quality Study rated the following among the top three vehicles per segment in initial quality: Compact Car — Mazda Protegé; Compact Pickup — Mazda B-Series; Sporty Car — Mazda MX-5 Miata; Entry Luxury Car (Under $35,000) — Mazda Millenia.
    Ford Motor Company increases its equity in Mazda Motor Corporation to 33.4 percent.
    1997
    MSS, MRA, MANA, and MMA consolidate operations under the new business name Mazda North American Operations (MNAO), headquartered in Irvine, California.
    Mazda introduces its new "Winged M" brand marquee worldwide.
    1998
    Mazda redesigns the MX-5 Miata for the first time since its introduction nine years earlier, debuting the new car as a 1999 model.
    The MX-5 Miata receives a Car and Driver "10Best" award.
    Debut of the MY1998.5 Mazda B-Series Cab Plus 4, the first 4-door import brand truck.
    Introduction of the all-new third-generation Protegé as a 1999 model. The Protegé receives Ultra Low Emission Vehicle status in California.
    Mazda Protegé DX named "Best New Car" under $13,000 by Kiplinger’s New Cars and Trucks 1999 Buyers Guide.
    Consumers Digest names the MX-5 Miata, Protegé, and B-Series Truck to its 1999 "Best Buy" list.
    1999
    The MX-5 Miata celebrates its 10th anniversary with a Special-Edition model and receives numerous accolades, including:
    * Fifth "10Best" award from Car and Driver.
    * Named to Consumers Digest "Best Buy" list.
    * "Best Convertible" in MotorWeek’s Driver’s Choice Awards.
    * One of Sport Compact Car’s "Eight Great Rides."
    Protegé named "Best New Family Sedan (Under $25,000)" by Automobile Journalists Association of Canada.
    Mazda debuts MY2000 MPV.
    2000
    Car and Driver ranks Mazda Protegé ES "#1 Compact Sedan."
    Tribute introduced as a 2001 model year vehicle.
    2001
    Mazda Motor Corporation celebrates 70th anniversary of automobile manufacturing.
    Introduction of the MP3, a production-quality sport compact car.
    Mazda MX-5 Miata, MPV, and Tribute named Consumers Digest "Best Buys."
    Introduction of the Mazda Protegé5 as a 2002 model.
    Tribute named "Best New Compact Sport Utility" and "Canadian Truck of the Year" by Automobile Journalists Association of Canada.
    MNAO acquires naming rights to one of the nation’s premier road racing circuits, now called Mazda Raceway Laguna Seca.
    2002
    Mazda Tribute receives several awards, including:
    * Automobile Magazine’s Reader’s Choice Award for "Best Small Sport Utility Vehicle."
    * Edmunds.com Editor’s Choice Award for "Small SUV of the Year."
    The MX-5 Miata named to Automobile Magazine "All-Star" list for the 12th time.
    MNAO launches MAZDASPEED performance badge.
    Mazda introduces turbocharged MAZDASPEED Protegé as a 2003 model.
    MAZDASPEED Protegé, parts, accessories, and merchandise go on sale at Mazda’s exclusive MAZDASPEED dealers.
    Mazda launches U.S. production and North American sales of 2003 MAZDA6 sports sedan.
    2003
    Mazda introduces 2004 RX-8 sports car. The world’s only rotary-engine sports car is first with "Freestyle" door system and room for four adults.
    Mazda introduces the 2003.5 MAZDASPEED Protegé.
    Mazda introduces 2004 MAZDA3 4-Door and 5-Door.
    RX-8 RENESIS rotary engine wins 2003 International Engine of the Year.
    MAZDA6 wins more than 60 domestic and international awards during its first year, including a Car and Driver "10Best," Automobile Magazine "All-Star," and MONEY® magazine "2003 Best Mid-Sized Sedan."
    2004
    Mazda introduces 2004 MAZDA6 5-Door and Sport Wagon, and 2004 MAZDASPEED MX-5 Miata.
    Edmunds.com awards MAZDA3 the "Most Wanted Sedan Under $15,000."
    Kiplinger’s Personal Finance awards MAZDA3 "Best New Car Under $17,000" and "Best New Sports Car" honors to the RX-8.
    RX-8 receives Car and Driver "10Best" award, MONEY® magazine’s "Best Sports Car" award, and is a 2004 Automobile Magazine "All-Star"
  5. #15
  6. #16
    satyr
    lengkap ni. sticky please
  7. #17
  8. #18
    9 Mins 37 Secs
    1991
    Mazda's four-rotor 787B wins Le Mans, becoming the first and only Japanese manufacturer to win this famous endurance race.
  9. #19
    Bekasi
    4 Days 13 Hrs 6 Mins 27 Secs
    mazda e2000 boleh ikutan g bos..??
    TD01W | SJI 283
  10. #20
GT Radial NGK Busi
  1. Replies: 1424
    Last Post: 3rd May 2018, 13:59
  2. part mazda family
    By trinursesutyo in forum Jabodetabek
    Last Post: 22nd November 2011, 13:21
  3. Velg OEM Mazda Family PCD 4x100 + Ban Goodyear
    By Gutchu in forum Ragam Ukuran
    Last Post: 18th November 2010, 15:44
  4. WTS MAZDA MPV, FAMILY WAGON
    By gsandhia in forum Mazda
    Last Post: 17th December 2009, 10:40
