For Sale AudioControl EQX Pre-Amp Equalizer/Crossover
Description:
AudioControl designed the EQX to make your car audio system sound better. This 2-channel equalizer features 13 bands of adjustment for sonic fine tuning, along with a 2-way crossover that allows you to add a powered sub to your setup. And speaker-level inputs allow you to connect the EQX to just about any car stereo, even to factory amps up to 400 watts.
Most car audio problems occur in the bass frequencies, so the EQX gives you six bands of equalization between 31.5 and 180 Hz, along with a rolloff filter that keeps bass below the range of human hearing out of your subwoofer system. You also get seven bands of equalization at octave intervals from 250 Hz all the way up to 16,000 Hz.
Features:
dual 13-band equalizers with level matching controls
gray steel chassis with gold-plated RCA jacks
Linkwitz-Riley 2-way crossover (90 Hz at 24 dB/octave)
top-mounted controls for easy adjustment
preamp- and speaker-level inputs
6-channel outputs: full range, high-pass, and low-pass
balanced inputs eliminate noise
33 Hz subsonic filter eliminates extreme low bass (rolloff point can be adjusted with optional module)
EQ points: 31.5, 45, 63, 90, 125, 180, 250, 500, 1000, 2000, 4000, 8000, 16000 Hz
frequency response: 10 to 20,000 Hz
signal-to-noise ratio: 110 dB at full output
maximum output level: 9.5 volts
fuse rating: 2 amps
size: 6-15/16"H x 8-15/16"W x 1-1/4"D
