All about Toyota engine.. - Page 2
Page 2 of 336 FirstFirst 123456 ... LastLast
Results 11 to 20 of 3356
  • Short URL:  http://modifika.si/3833
  2. #12
    Jakarta hampir coret
    1 Day 1 Hr 39 Mins 42 Secs
    VIOS & YARIS
    1NZ-FE 4 Cylinder, DOHC, VVT-i, 16 Valve
    Bore & Stroke 75.0mm x 84.7mm
    Compression 10.5:1
    Displacement 1496cc
    Power 109Ps/6000rpm
    Torque 14.5Kgm/4200rpm
    Kijang Innova 2.7L & Toyota Fortuner
    2TR-FE 16-Valves, DOHC with VVT-i
    bore & stroke 95.0mm x 95.0mm
    Displacement 2694cc
    Compression 9.6:1
    Power 160ps/5200rpm
    Torque 241Nm/3800rpm
    Kijang Innova 2.0L
    1TR-FE 16 Valve, DOHC, VVT-i
    Displacement 1,998cc
    Compression 9.8 :1
    Bore x Stroke 86.0mm x 86.0mm
    Power 136ps / 5,600rpm
    Torque 182Nm/4.000rpm
    1GR-FE V6 DOHC 24Valve VVT-i
    Displacement 3955cc
    Compression 10.0:1
    Bore x Stroke 94mm x 95mm
    Power 245Hp/5200rpm
    Torque 382Nm/3800rpm
    klo ada yang salah mohon diperbaiki...silakenn..
    Sekian laporan sementara Sersan Satu
  3. #13
    eNZed
    8 Hrs 56 Mins 27 Secs
    Quote Originally Posted by xesy
    Displacement 3955cc
    Compression 10.0:1
    Power 245Hp/5200rpm
    yg itu mesin mobil apa yah??? gw tebak sih crown... tul ga? gw lmy buta soal toyota nih... hehehehe.
  4. #14
    jakarta timur
    9 Hrs 9 Mins 19 Secs
    tyr mesin toyota cami belom tuh....
    passo juga belom
    mesinya: serinya k3-ve(1300cc 16v dohc vvti)
    sama ej-ve(1000cc 16v dohc vvti)
    ama k3-vet(1300cc 16v dohc turbo intercooler)
    sekian dan terimakasih.....
  5. #15
    satyr
    K3-VE kan aslinya mesin daihatsu. jadi tidak tercantum :lol:
  6. #16
    jakarta timur
    kan kerjasama ama toyota......
  7. #17
    Quote Originally Posted by sugarfree
    Displacement 3955cc
    Compression 10.0:1
    Power 245Hp/5200rpm
    Dipake di toyota tacoma n toyota tundra mesinnya.klo crown sih 1G-FE, gak pake R...hehehehhe
  8. #18
    satyr
    2GR-FSE : Lexus IS350 94 x 83 315 hp @ 6400 rpm, 377 Nm @ 4800 rpm Dual VVT-i
    4GR-FSE: Lexus IS250 83.1 x 76.9 204 hp@6400 rpm, 266 Nm @ 4800 rpm Dual VVT-i
  9. #19
    satyr
    1ZZ-FED 140 hp @ 6400 rpm, 171 Nm @ 4200 rpm. Toyota MRS
  10. #20
    Smatic
    Nambahin dikit mesin barunya 2SZ-FE 1.3 liter utk Toyota Ractis dijual lebih murah dari Avanza di Malaysia
  1. (WTB) cam 66 for 5K engine (toyota)
    By ZBHDEZ in forum Jual Beli Mesin Lainnya
    Last Post: 4th March 2011, 06:54
  2. WTB: ENGINE TOYOTA 2F THN 84
    By desdemona in forum Jual Beli Mesin Lainnya
    Last Post: 19th May 2010, 18:25
  3. WTS:ENGINE 1GE-2.0cc ex.Toyota Crown 24V
    By vvvwww in forum Jual Beli Mesin Lainnya
    Last Post: 24th September 2009, 14:04
  4. WTS: CAM FOR TOYOTA K-SERIES ENGINE
    By mEtalZ in forum Jual Beli Mesin Lainnya
    Last Post: 11th July 2009, 14:36
  5. [ask] toyota engine n/a vs turbo
    By ep71 in forum Diskusi Mesin
    Last Post: 22nd September 2006, 08:13
